Old 12-05-2008, 05:15 AM   #1
bereda
Scooby Scammer- Do Not Buy From User
Member#: 192034
2004 2.5rs
red
Default are light weight pulleys and underdrive worth it
i found some on ebay but will the set seriously give me some more ???
heres a set i found
http://cgi.ebay.com/ebaymotors/UNDER...Q5fAccessories
and what should i look for spec wise ( weight, diameter,etc.)
i have an 04 rs
and whats a over drive pulley what advantages over under drive?
http://cgi.ebay.com/ebaymotors/OBX-O...Q5fAccessories
bereda is offline   Reply With Quote
Old 12-05-2008, 05:20 AM   #2
2.5ReallySexy
Member#: 167943
You may not see any power differences but them being lighter makes it easier for them to spin. So you may make a difference but you prob wont notice it
2.5ReallySexy is offline   Reply With Quote
Old 12-05-2008, 06:25 AM   #3
soulhassorrow
Member#: 150732
2011 WRXXXX
LRP
many people stay away from underdriven pulley,i guess they're bad for the engine!@##@!
soulhassorrow is offline   Reply With Quote
Old 12-05-2008, 10:43 AM   #4
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
worth it.
Jerry Xu is offline   Reply With Quote
Old 12-05-2008, 10:44 AM   #5
alejo
Member#: 170081
2004 2.5RS
blue
They spin faster so they actually help the engine rev faster. They kinda ¨free¨ the engine of some weight. The problem with the underdriven is they are smaller so you have to change your belts. Another thing is, they reduce the amount of power on the power steering and the alternator, so it might be wise to stay with the lightweight. Good luck
alejo is offline   Reply With Quote
Old 12-05-2008, 12:00 PM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
I have never heard of overdrive pulleys. I do not understand any advantage it would have 'over' under drive pulleys. It says they have been dyno proven. Honestly, I believe the buyer meant to say underdrive pulleys.
Kevin Thomas is offline   Reply With Quote
Old 12-05-2008, 12:17 PM   #7
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
anytime you remove rotating mass it's good....up to a certain point. The engine needs some rotational inertia in order to get going. but yes, a LW pulley will make your engine seem peppier since it is no longer using its' power to spin mass.
Old 12-05-2008, 03:18 PM   #8
OfCoarseItGoesFast
Member#: 170183
2008 Impreza 2.5i
Less rotating mass can be good, as long as your gearing isnt too close together. Lack of inertia can make your revs drop below the power band if you dont feel like shifting fast all of the time
OfCoarseItGoesFast is offline   Reply With Quote
Old 12-05-2008, 03:36 PM   #9
shanemono4
Member#: 173332
2003 2.5rs
PSM.
get cobb or perrin. same size as stock, just a lot lighter. you don't have to change your belts or anything.
shanemono4 is offline   Reply With Quote
Old 12-05-2008, 03:53 PM   #10
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
my cobb pulley really helped me to enjoy my subaru . its like night and day. just make sure you have the car in a nice strong gear like 5th when you crack that bolt.
watchunglava is offline   Reply With Quote
Old 12-05-2008, 04:37 PM   #11
It Hertz
Member#: 152898
2007 Impreza 2.5I
UGM
maybe someone can comment on this, I was talking to my local shop here... and they advised against the LW pulley stating that they cause problems with the balance of the crank.....
I am really interested in one.. but want to be sure they is not going to be a problem.
Thanks
It Hertz is offline   Reply With Quote
Old 12-05-2008, 04:40 PM   #12
watchunglava
Member#: 168862
if you search hard enough on here you'll find a letter from subaru stating that a pulley is a pulley. furthermore the subaru crank pulley is just that it is not a harmonic balancer.
you will be fine just buy a good quality pulley, stock sized , like cobb or perin or kartboys
Old 12-06-2008, 02:23 AM   #13
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
5th and have someone stand on the brakes too.
+10 for truth.
I'm partial to the agency power, but most of them are within a few tenths of a pound anyway.
Counterfit is offline   Reply With Quote
Old 12-06-2008, 04:47 AM   #14
bereda
Member#: 192034
2004 2.5rs
red
so whats the lightest and best priced? and is there a full light weight pulley kit? to change every pulley to light weight
Old 12-06-2008, 05:07 AM   #15
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Thanks
It has been said that the stock crank pulley has rubber inserts in it to help dampen engine vibrations. I have even seen pictures of it. Is it needed? That I'm not sure of. I am contemplating this mod as well, but it's hard to say if it can hurt components over time. There is a lot of speculation on the internet, and even those that are "informed" can still be wrong.
If you plan to do it, do it right - go lightweight not underdriven and choose a good brand name.
axelthrasher is offline   Reply With Quote
Old 12-06-2008, 06:03 AM   #16
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Subaru crank pulleys don't have harmonic dampers though
Spore is offline   Reply With Quote
Old 12-06-2008, 03:38 PM   #17
Counterfit
Member#: 124254
"The Scoobinator"
I haven't found any lighter than the Agency Power, which is 1.0lbs. I ordered mine from RalliTek, and they seem to have a different picture on their website, but you get the right part.
Old 12-06-2008, 04:40 PM   #18
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Light weight and under driven pulleys will not do any harm to much of any thing. IMO they are far more bling than bang for your buck.
-Yes you may experience minor Power Steering differences. If you are using your PS to it limits. like turning the wheels while not moving
-Yes you may experience some power fluctuation if you have some serious amps or ridiculed head light setup.
You will have more noticeable changes/problems with a Light Weight Flywheel than a Pulley Set
dangerousatom is offline   Reply With Quote
Old 12-06-2008, 04:43 PM   #19
Storm
Member#: 5218
96L Most Over-
Developed Beater
I've been running an old JC Sports UD pulley for years and years......It hasn't done anything to hurt any of the motors that have been in my car. I've read more about botched installs of pulleys than anything else.
Cutting the weight is most important, and underdriving the accessories is an added benefit if you choose to go that route.
Jay Storm
Old 12-06-2008, 04:54 PM   #20
mdungelman
Member#: 97251
'13 Impreza 2.0i
I've got the gruppe-s pulley currently. A little heavier than the perring that I had previously. But either way, they both reduce the rotational mass. Both are stock diameter. For those who don't think they help...switch back to the oem 5lb. (ftl) It sounds like the underdriven pulleys don't bother those who have previously posted.
Storm, do you notice any downfalls to the UD pulley?
mdungelman is offline   Reply With Quote
Old 12-06-2008, 07:36 PM   #21
civic_82
Member#: 189668
2007 2.5i sp ed
i take that this will improve my low end torque??? also has anyone notice better mpg???
civic_82 is offline   Reply With Quote
Old 12-06-2008, 07:55 PM   #22
EdHilario
Member#: 137398
2004 Impreza 2.5RS
It does make a little bit of difference for low/mid-end but as far as better mileage, nope..
EdHilario is offline   Reply With Quote
Old 12-06-2008, 11:20 PM   #23
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I have a LW flywheel, so I took my Perrin off. But I did notice a slight difference, even with my old auto snotbox.
This has been discussed many times, as far as engine balancer goes. You might have more risk of your "balancer" failing because of the rubber degrading than any damage done by a LW pulley (correctly installed of course).
Just stick with stock diameter and LW, no under driven. The one under driven I bought off ebay was light, but the ridges in the pulley are not machined correctly. They have a plateu instead of a ridge.
............. _
Like this: / \ instead of this: /\
Using this for a long enough time would more than likely damage your belts.
~Josh~
Old 12-07-2008, 11:25 AM   #24
Storm
Member#: 5218
96L Most Over-
Developed Beater
No problems with my underdriven pulley. My GFs bone stock Corolla lights dimmed at idle much-much more than mine ever do. I've gone through the big amplified stereo phase of my life as well, and never had any issues at all with the UD pulley. I run a 9.5lb flywheel too.......It's all pure bullcrap. I will say that I'm also not stupid enough to have every electrical system on the car at max current draw at the same time while idling....so that may be a big reason why I don't have problems and others seem to. Turn off the defroster and big rally lights, turn down the music and cut the blower fan down a couple notches.......
Ballitch: Take a close look at the inside of your belt. That flat portion of the pulley rib is there for a reason.
Jay Storm
Old 06-12-2009, 06:17 PM   #25
PelvaanAli
Member#: 190157
2003 WRX
stick with the stock sized pullye...you will kill your alternator with a underdrive
PelvaanAli is offline   Reply With Quote
Does any 2.5i owners have both the light weight pulley and flywheel? Jerry Xu Normally Aspirated Powertrain 8 02-28-2008 10:59 AM
APS turbo inlet and Perrin light weight pulley breathinez Private 'Wanted' Classifieds 3 04-26-2007 02:57 PM
light weight flywheel and pulleys. thoughts please Waking The Fallen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2006 10:27 AM
Light weight pulley, exhaust plate and sti pedals WRXXXXXXXXXXXX Private 'For Sale' Classifieds 12 10-01-2004 06:43 PM
Is the light weight pulley worth it? TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2001 12:50 AM
