Old 12-05-2008, 01:53 PM   #1
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Default 98rs block in 07 2.5i
hey, so my engine is toast in my 07 2.5i (long story) and i don't think subaru is gonna cover it. but anyways my buddy has a 2.5rs shortblock out of his 98 rs. and i was wondering if it would be a direct plug and play scenario? we have done a couple swaps before, so we plan to do all of the labor ourselves.
my main question is will a 98 2.5rs short block plug and play into a 07 2.5?
any help will be appreciated
olsen726 is offline   Reply With Quote
Old 12-05-2008, 02:13 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
im not sure but i dont think its exactly plug and play. what happened to your motor?
watchunglava is offline   Reply With Quote
Old 12-05-2008, 02:54 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
i also doubt it will be an easy direct swap, you may have to tweak a thing or 2, but it should work. I put a 2005 short block into my 2001 rs and there were a few odd changes. well, just one stands out, the PCV valve location.
Old 12-05-2008, 02:58 PM   #4
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
I gotta hear this. Subscribed.
Gr3en is offline   Reply With Quote
Old 12-05-2008, 04:29 PM   #5
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
thanks for the help guys. just trying to get as much info as possible.
Old 12-05-2008, 10:33 PM   #6
ralliboi
Member#: 174924
2001 impreza rs
blue
I'm not sure, but i'll assume your old block was the sohc, similar to the phase 2 ej251(99-01) rs motor among other models. From all the work i've done it would appear to be a simple swap of the block if you retained your current 07's heads (if their any good). There is a slight degree change in the valve slots in the pistons, however nothing to be worried about unless considering major modifications (ex. turbo). I currently have an ej251 running on dohc pistons, cranks, and rods with no issues. Hope this helped.
regards,
pat
ralliboi is offline   Reply With Quote
Old 12-06-2008, 03:14 AM   #7
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
yeah, that helped. i think i could pull it off using thicker headgaskets maybe
Old 12-06-2008, 03:15 AM   #8
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
thanks for the help
Legacy steering wheel with audio controls in 07 2.5i? cprincipe Interior & Exterior Modification 1 01-11-2016 02:55 PM
maplight install in 07 2.5i wagon? Nicky B. Interior & Exterior Modification 4 02-24-2008 01:14 AM
auto-dim/compass in 07 2.5i Nicky B. Interior & Exterior Modification 5 02-22-2008 02:08 PM
R180 in 07 2.5i 2.5iSTI Transmission (AT/MT) & Driveline 2 11-05-2007 08:07 PM
Difference's in 07 2.5i, wrx and sti sway bars? mxpro252 Brakes, Steering & Suspension 14 08-30-2007 02:57 PM
