Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-05-2008, 04:33 PM   #1
operating engineer
Member#: 62893
2008 STi
Default reuse valven stem?
I just purchased a used set of Volks that still had the red valve stem installed. Can I reuse them or pay 70 bucks for another set? thanks
operating engineer is offline   Reply With Quote
Old 12-05-2008, 04:34 PM   #2
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
metal valve stem are fine and can use reused as long as they are not damaged or leaking
Kenji815 is offline   Reply With Quote
Old 12-05-2008, 10:22 PM   #3
Web Foot STi
Member#: 39086
2004 STi
You can even replace the valve cores and keep the valve stems if you're worried.
Web Foot STi is offline   Reply With Quote
Old 12-05-2008, 11:02 PM   #4
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
replace the valve core to play it safe. I would drop buy a tire shop and just ask a tech for four new valve cores. i wouldnt think they would charge u
turb04 is offline   Reply With Quote
Subaru self-locking nuts: replace? reuse? davearm Brakes, Steering & Suspension 10 05-21-2010 08:09 PM
Any difference between STi valve stem seals and 2.0L WRX valve stem seals? CoolRex Built Motor Discussion 3 10-02-2009 10:57 AM
Reusing valve stems after swapping in new tires...Anything bad will happen? SinhCredible Tire & Wheel 3 11-09-2004 06:50 PM
For an aftermarket downpipe and cat back on do you need to reuse the stock donut? kitbar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2003 08:35 PM
Suspension nuts... Is it ok to reuse the original ones? MrP0nch0 Brakes, Steering & Suspension 4 06-14-2001 09:52 PM
