Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 12-10-2008, 04:53 PM   #1
Member#: 110412
2006 WRX
Default Tire size ?'s
Ok, stock suspension on an '06 WRX Sedan with '04 STi BBS's, I want to go as wide as I can without having issues with the stock suspension, and I want to get a little bigger diameter too. Any suggestions?
rodzilla72 is offline   Reply With Quote
Old 12-10-2008, 05:31 PM   #2
Member#: 43393
2014 Audi a6
Daytona Gray
If you stay on your stock suspension you can go wider and larger. The compensation is made up with the rubber. Keep in mind that there is a balance here, if you screw it up your speedometer is off, and I am sure that there are a few other guys that can go into more depth about the other ramifications of not doing it right.
I personally used 255/35-18 tires (falken fk452) on a 18x8.5 rim +35 offset. I believe that my speedometer is off by less than 1% than on the OEM size. I had some rubbing when I put cobb sport springs on the car, but I got that fixed for about 80 bucks. I would imagine I could go to an 18x9 with less offset +40 and still not have any rubbing because I reduced the offset and widened the tire while using the same tire. (I have about 4cm clearance from the strut on the backside.)
Sticky for Rim sizes and tire sizes? TomsSound Brakes, Steering & Suspension 8 02-01-2012 09:30 PM
Tire sizes and speaker sizes... samtheblur Legacy Forum 9 06-03-2005 08:04 PM
Racing Tire Size to Street Tire Size mav1c Brakes, Steering & Suspension 0 11-18-2002 03:16 PM
Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels rao Brakes, Steering & Suspension 6 06-19-2001 04:08 PM
Here is tire sizes chart. No more tire size Qs? Yeah, right! 25psi Brakes, Steering & Suspension 18 04-18-2001 03:29 PM
