#1 |
Member#: 142954
NWIC
Vehicle:2003 WRX Wagon Sedona Red Pearl |
I have cracked a radiator and now have made a leak in another. 2 radiators in 3 weeks. I drained the coolant and it was clear (no contamination). Anyone out there have any thoughts. I have a brand new radiator in my car right now and I am afraid to drive it because I do not want to break this one.
#2 |
Member#: 131509
Vehicle:2006 Impreza WRX WRB |
i dont know what the climate has been like where you live but if it has been below freezing there may be a possibility that your coolant had to much water content after the initial replacement. i have seen some cases where the so called 50/50 water coolant premixes havent done very well causing the coolant to freeze and create leaks. this is just an idea and doubtfull that this is the problem but its something to think about.
other than the obvious coolant quality concern you should have the cooling system including the cap pressure tested. very possible that a cylinder head gasket is starting to go as well. good luck |
#3 |
Member#: 85763
I'd check the radiator cap. In my previous car, Integra GS-R i had the same problem. The shop I took went through 5 radiators within a week and a half (blown radiator after driving less than miles - dripping coolant) until I suggested replacing radiator cap. The radiator never cracked ever since until the frickin thieves stole my car until 6 mo. later. Let me know if this worked for you.
#4 |
Member#: 174147
Vehicle:2002 WRX wagon Silver |
Sorry to bring up a REALLY old thread but I'm having the same issue and its easier to just bump this one. Anyone else have any suggestions?
#5 |
Member#: 13815
SCIC
Vehicle:02 GCRally prepped 277TQ 281HP 19PSI |
Do a leak down and compression test. The last 2002 I worked on did the same thing at another dealership. I found that the head gasket had been toast. I am not saying that is your problem, but it is worth the test.
#6 |
Member#: 74321
Vehicle:2004 wrx wag black UTEC stg 4 |
breaking radiators repeatedly is almost always a sign of head gasket problems. I would recommend getting a leak down test performed
#7 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
are they oem radiators?
| Thread Tools | |
| Display Modes | |
| NEED HELP!!! My Car is slipping like CRAZY!! | jonpark | Transmission (AT/MT) & Driveline | 24 | 12-28-2008 01:29 PM |
| HELP!! My car is going crazy! | 00scoobyrs | Electrical & Lighting | 1 | 12-29-2006 01:18 PM |
| Wish me luck, my car is going in! | codean | Mid West Subaru Owners Club Forum -- MWSOC | 15 | 11-13-2002 10:31 PM |
| Help! My car is going nuts! | Fusion | Normally Aspirated Powertrain | 12 | 11-06-2001 03:08 AM |
| My car is going under the knife! (and a sighting!) | Fido | Tri-State Area Forum | 0 | 02-13-2001 06:43 AM |
