Old 12-06-2008, 12:22 AM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default What's Your Target AFR?
If you have an NA engine (no turbos, supers, N2O, etc) and have tuned it yourself or had it tuned, what is your target AFR at WOT?
Just seeing how other people are handling this.
Old 12-06-2008, 12:28 AM   #2
GrundleJuice
Member#: 165749
im going for low-mid 13ish in the WOT lower RPM cells and getting to 12.4 @ WOT 4400RPM to redline . Honestly, i am shooting for that because it the MBT in theory. But i think i got that info from you, or someone on here/RR forum. So I might be in the same boat as you as far as fueling strategy. I meant to ask you, what was your factory O2 sensor reading compared to your WB at high load (WOT) above 4k RPM? Mine wasnt as far off as i expected. far enough to make a difference, though.
Old 12-06-2008, 11:16 AM   #3
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
12.56 in high load / high RPM, tapered all the way to high 13's in low load/RPM.
LTracer is offline   Reply With Quote
Old 12-06-2008, 09:48 PM   #4
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
wikipedia is claiming , In Naturally Aspirated engines powered by octane, maximum power is frequently reached at AFRs ranging from 12.5 - 13.3:1 or λ of 0.85 - 0.901.
watchunglava is offline   Reply With Quote
Old 12-08-2008, 12:29 AM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I find it hard to believe we've got only 4 tuned RSes on here...
Old 12-08-2008, 07:22 PM   #6
GrundleJuice
Member#: 165749
Ty, have you asked over at RR forum?
Old 12-08-2008, 07:24 PM   #7
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
What percent of the people with CAIs would you say actually know what MBT stands for?
LetItSnow is offline   Reply With Quote
Old 12-08-2008, 07:30 PM   #8
GrundleJuice
Member#: 165749
Not nearly enough.
Old 12-08-2008, 08:07 PM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Which MBT? There are two relating to tuning, you know.
Old 12-08-2008, 08:17 PM   #10
watchunglava
Member#: 168862
i am only familiar with minimum best timing pertaining to ignition. ? whats the other?
Old 12-08-2008, 08:19 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Maximum Best Timing
Mean Best Torque
Old 12-08-2008, 09:04 PM   #12
watchunglava
Member#: 168862
u mean MINIMUM best timing right?
Old 12-08-2008, 09:21 PM   #13
gecko7
Member#: 195984
my AFR getting a reading from 14.1 ~ 14.7 is it okie with it?
gecko7 is offline   Reply With Quote
Old 12-08-2008, 09:36 PM   #14
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well now, that's an interesting question. The internet has about the same support for Maximum as it does for Minimum. The only textbook I have in the house that refers directly to MBT in relation to timing defines it as "Maximum Brake Torque". So I don't think we're going to resolve this one easily.
Old 12-08-2008, 09:46 PM   #15
watchunglava
Member#: 168862
im looking it up in my ase text now , but ive allways known it as minimum best timing , refering to advancing the timing only so far as would provide maximum power output.
Old 12-08-2008, 09:50 PM   #16
watchunglava
Member#: 168862
ahh it seems we are both correct.
and to all those that didnt weigh in its cool
(13) MBT:
minimum best timing, the industry-recognized expression for the ignition
timing (spark occurence as degrees in advance of top dead center, or
"spark advance") that yields best torque (maximum brake torque) for the
engine.
Old 12-08-2008, 09:55 PM   #17
watchunglava
Member#: 168862
well accually i think i was more right but whatever
Old 12-08-2008, 10:09 PM   #18
GrundleJuice
Member#: 165749
I was specifically referring to "mean best torque" but i think max best timing, min best timing and mean best torque are different names for the same thing.
Old 12-08-2008, 10:13 PM   #19
watchunglava
Member#: 168862
i think they are different . look at the definition , they define minimum best timing , just read the definition. maximum best timing is like what you would think it would be called and alot of people call it that. but as far as ase certification goes its minimum best timing , and mean best torque is a result of minimum best timing
Old 12-09-2008, 12:55 AM   #20
GrundleJuice
Member#: 165749
Wha??? Mean Best Torque is a reference for the AFR that should achieve the most torque. Min/Max best timing dont refer to AFR's, do they? I thought they were in reference to actual spark advance before TDC. Now im thouroghly confused and tired.
Old 12-09-2008, 01:03 AM   #21
watchunglava
Member#: 168862
ohh true lol !!! i dont know some random guy was like does anyone know what mbt is lol . and wility was like which one , talking about tuning , i guess it went off topic. god darn cold air intake havin freaks!
Old 12-09-2008, 11:00 AM   #22
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
13:0.1
That has always been my target for N/A performance with basic mods (Intake, exhaust, header). Once you mod to the point of having to go with a different octane, I would no longer go by air/fuel ratio as a primary tuning measure but exhaust gas temperature (Along with air/fuel ratio).
Kevin Thomas is offline   Reply With Quote
Old 12-09-2008, 07:30 PM   #23
GrundleJuice
Member#: 165749
Originally Posted by Kevin Thomas View Post
13:0.1
That's interesting. What octanes do you suggest using a pyro reading along w/ AFR for tuning and why? are you targeting just rich of peak for most torque? If not, what do you target in terms of EGT?
Old 12-09-2008, 08:55 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The EGT is just a poor man's O2 sensor. It's in no way any better than a WBO2, regardless of octane. The reason an EGT gauge can be useful is that EGTs peak at stoich. So you find the fueling that returns peak EGT, then lean out or enrich the mixture until the EGT drops the amount the engine manufacturer recommends. The amount of EGT drop per lambda change varies from engine to engine, so without a published spec from Subaru, or without having both a WBO2 and a EGT to calibrate the EGT results, EGT change has no meaning.
Wait a minute, you're an airplane mechanic, right? Adjusting fueling based on EGTs was developed initially with piston aircraft engines. Google "Wright Aeronautical Division Recommended Leaning Procedure".
Old 12-09-2008, 09:56 PM   #25
GrundleJuice
Member#: 165749
Yes I am. Thats why i asked what his theory and strategy for using EGT was. I use EGT all the time to adjust fuel mixture for all kinds of reasons. Economy, peak power output, peak cruise speed, burning some crap off a dirty plug, etc etc. But its not a sceintific technique when we do it, its just a use of fuel mixture to "get close" to what were going for. I was curious how Kevin uses it to tune. I had doubts about how accurate and precise it could be but i was giving him the benefit until i knew otherwise.
UEGO owners - what's your AFR reading? txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-09-2008 08:48 PM
Yay! 17psi peak, 10.9-11:1 Target AFR no more knocks! bpwatts UTEC 5 11-27-2006 09:39 AM
target afr wrxtremeWGN Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-22-2006 08:37 PM
Target AFR with water/alchy injection vica153 Engine Management & Tuning 18 04-10-2006 06:25 PM
Big vacuum target AFRs jblaine Engine Management & Tuning 8 04-08-2005 08:23 AM
