Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 12-03-2008, 06:51 PM   #1
Aspenbullet
Member#: 71240
2002 WRX Cobb Stg II
Aspen White w/Yakima Rack
Default Very uneven treadwear. Pics inside.
I get my car aligned usually once a year at the Subaru dealership. Can anyone shed some light on why the treadwear would be so uneven on only the passenger side of the car (front and rear tires look almost the same). The tires wear much more evenly on the drivers side. My summer tires showed the same strange treadwear pattern too.
Passenger side front tire:
Close up of the outside of the front passenger tire:
Close up of the inside of the front passenger tire:
Driver side front tire:
I'd like to get this straightened out before I buy and ruin a set of new winter tires.
Thanks in advance!
Matt
Aspenbullet is offline   Reply With Quote
Old 12-03-2008, 07:16 PM   #2
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
Negative camber wear?
EdHilario is offline   Reply With Quote
Old 12-03-2008, 07:26 PM   #3
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Looks like something is causing dynamic toe on the passenger wheel, which makes the (slight?) neg camber an uneven wear issue. Dynamic toe can be caused from play in the wheel: worn hub bearings, worn suspension bushings, bent arms, unevenly worn struts left/right, etc.
Jack up the front, get a firm grip on the passenger wheel and see if there's much play.
I had a similar problem with a previous car. Align specs were great, etc. But the unevenly wearing tire got that way I think with braking... ABS kept activatng just on that wheel; suggesting "low traction"... even though it was straight braking. Never got it solved though before the car got sold.
chimchimm5 is offline   Reply With Quote
Old 12-03-2008, 09:58 PM   #4
grippy monkey
Member#: 131067
your "stance"
sucks
research before posting
grippy monkey is offline   Reply With Quote
Old 12-03-2008, 10:17 PM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
WRONG-O...guess again
_______________________________________
OP....get the toe set to '0' and be
Old 12-04-2008, 12:58 AM   #6
pnutbutta
Member#: 192572
2007 Impreza
CGM
like stated above likely a toe issue. also make sure to regularily check your tire pressures!
pnutbutta is offline   Reply With Quote
Old 12-05-2008, 12:27 AM   #7
Aspenbullet
Member#: 71240
Ok, so there's no play in the wheel when I grab the wheel at 12 and 6 and wiggle it. I do hear a strange creaking/squeaking coming from the rear of the car when I go over speed bumps or drive into my garage up a 4 inch step up. I guess that noise could indicate worn suspension parts but the noise is only from the rear of the car.
To pnutbutta:
I do check tire pressure every time I fill up the car so I don't think that's an issue.
Uncle Scotty:
So I would just ask the dealership to set the toe to 0 on the passenger side wheels only?
I guess I should have them check for any damage to suspension parts on that side while I'm at it. I have a feeling if I ask the dealership to look for damage, they'll find some.
Old 12-05-2008, 01:20 AM   #8
dubya-R-ex
Member#: 113698
Fat passenger changing the alignment of your car?
dubya-R-ex is offline   Reply With Quote
Old 12-05-2008, 01:26 AM   #9
Aspenbullet
Member#: 71240
I'm glad it's the passenger side with the uneven wear and not the drivers side.
Old 12-05-2008, 06:28 AM   #10
Daishi00
Member#: 78952
2005 WRX
CGM
Have them set 0 toe on ALL tires.
Some in the motorsports say you have to take the axle nut off to really let the hub/bearing move enough to show if it's bad. I think it was dunk who had a bad bearing and until he did that the usual 12/6 test didn't work at all.
What are your alignment specs anyways?
Daishi00 is offline   Reply With Quote
Old 12-05-2008, 08:36 PM   #11
EdHilario
Member#: 137398
2004 Impreza 2.5RS
lol...the inside of the tire was worn so it wasn't a bad guess. Hence the question mark after my post.
The intranets r serious bizness!! rawrarar
Old 12-05-2008, 08:50 PM   #12
Daishi00
Member#: 78952
2005 WRX
CGM
A guess is not something you really want to throw out on something like this. Camber almost never causes a wear issue on impreza based vehicles unless you never do anything but go in a straight line or turn only at parking lot speeds.
Old 12-05-2008, 09:26 PM   #13
Aspenbullet
Member#: 71240
I can't seem to find the alignment specs but AFAIK it's set to factory specs since it was taken to the dealership.
Do Subaru factory alignment specs on a 2002 WRX call for the toe to be set to 0 on all tires?
Old 12-05-2008, 09:46 PM   #14
Uncle Scotty
OK buy Nates beans
'factory' specs are garbage
and a 'green' alignment---all the arrows in the 'green' on the alignment screen... is the easy way for the tech to get paid for doing nothing.
specify '0' toe and it doesnt have to be exactly '0'....but >.05 is what ya want
max neg camber up front--whatever they can get ...even side to side
Old 12-06-2008, 11:18 AM   #15
recnelis
Member#: 92778
2000 Impreza 2.5RS
#74 ST - RCE Tarmac 2
The alignment specs should be in your factory manual. They are for my RS.
If you want to double check the work the dealership did, you could always try out the alignment thread in the suspension forum. With strings running parallel to the car, you can get a pretty good measurement of toe. If it's off, you can go yell at your dealership or fix it yourself. If it's good, then it might be something else.
My dad's RS had a similar looking wear pattern on his tires. When we finally checked it with the strings, we found about 3-4 mm of toe out on the worst wheel. The factory specs are supposedly +/- 3 mm (which is why being "in the green" or "factory spec" is not necessarily zero).
recnelis is offline   Reply With Quote
FS : (LA) 2006 Subaru WRX STi Aspen White PRICE DROP $19000 obo More Pics page 3 Dustin77 Private Vehicle 'For Sale' Classifieds 68 06-16-2010 02:43 PM
So I just got my very first Subaru. Pics inside 98_L Newbies & FAQs 10 04-21-2008 08:50 AM
Brake Dust, Very Uneven Buildup ViperJ Newbies & FAQs 3 07-16-2007 11:43 PM
04-05 WRX/STI/RS Grille VERY NICE - Pics inside Rick Dizzle Exterior/Styling 16 08-30-2006 11:14 PM
My Falken Azenis tires have uneven treadwear S-WRX Tire & Wheel 5 02-23-2004 09:53 PM
