Old 12-06-2008, 06:37 PM   #1
GraimeG
Member#: 64865
1993 Impreza L AWD
Default Power from general maintenance
I have a 1993 Subaru Impreza L AWD coming close to 180,000 miles.
Recently on a TopGear Episode, they said they did a "Standard tune up" on a 7 year old Renault van, and gained 40hp at the wheels... (This was with new fuel injectors, air filter, and intake manifold - so they said)
While this seems rather ambitious to me, what standard maintenance can I perform on the Subie to add back lost power from years of service?
I'm really new at this and haven't performed any serious work on the car before, even though it has been owned by my family for 16 years. Any DIY or walk-throughs for said maintenance steps would be appreciated as well!
GraimeG is offline   Reply With Quote
Old 12-06-2008, 10:49 PM   #2
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
seafoam!!!!!! air filter, spark plugs , oil change
watchunglava is offline   Reply With Quote
Old 12-07-2008, 03:36 AM   #3
GraimeG
Member#: 64865
1993 Impreza L AWD
What about fuel injectors? Pulleys?
Old 12-07-2008, 03:42 AM   #4
watchunglava
Member#: 168862
http://www.amsoil.com/storefront/api.aspx for your injectors. but definatly change the fuel fliter .
the seafoam though wow hook it up!!!!! 193k hell yea!!!!!!!!
Old 12-07-2008, 03:44 AM   #5
watchunglava
Member#: 168862
there is so much to a service like that lol it takes me a week to tune my car up and i do it like 3 times a year .
Old 12-07-2008, 04:43 AM   #6
GraimeG
Member#: 64865
1993 Impreza L AWD
seafoam? what is that exactly?
Old 12-07-2008, 03:32 PM   #7
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
I would do the following in this order to get it back in shape:
1. Compression test all the cylinders
2. Remove carbon from the intake with throttle body cleaner with engine running
3. Remove carbon from the cylinders with seafoam poured through a vacuum hose. PCV works
4. Remove and send the injectors off to be professionally ultrasonically cleaned and tested.
5. Change all fluids. Coolant, Brake, Steering, Engine Oil, Transmission, Differential
6. Install all new brake rotors and pads, check each caliper for wear and play.
7. New spark plugs, wires, coils if necessary. New distributor cap.
8. New PCV valve
9. Install new O2 sensor if it has one (not sure on a 93)
Optional 10. You may elect to early change the timing belt, tensioner, water pump if it needs it.
If your electrical system is working well, the compression test passes, and the engine is fully clean with new oil - then you're getting all the power it will muster.
I would also check the oil analysis on the new oil after 3000 for any signs of a coolant leak or problem.
Eyedoc Orlando is offline   Reply With Quote
Old 12-07-2008, 03:47 PM   #8
watchunglava
Member#: 168862
seafoam is an engine treatment. well known for its quality. and usefulness. its this stuff from back in the day. my buddy's dad would allways use it on their boat in the hamptons . but it works with auto engines too . its real good stuff and just what the dr. ordered for your high milage motor.
you have some dirty work ahead of you for sure. but nothing too hard. i love tuning up old cars . its going to feel awesome when your done.
compression tests, vaccum tests ,coolant system pressure test, many tests you can run. first things first the last poster is right , hook up throttle body cleaner then seafoam. i would even seafoam the block. the directions are on the can. yes definatly use the pcv line to sea foam the combustion chambers .
Old 12-07-2008, 03:47 PM   #9
watchunglava
Member#: 168862
Old 12-07-2008, 03:52 PM   #10
EdHilario
Member#: 137398
2004 Impreza
You can also try Motul Fuel System Clean and Engine Clean.
EdHilario is offline   Reply With Quote
Old 12-07-2008, 03:56 PM   #11
Russ45
Member#: 170237
2001 Miata
This!
Seafoam is amazing stuff. My buddy has a little 1992 or so toyota pickup that has been seafoamed religiously every 10,000mi since his dad first bought it. It runs almost better than my car.
Also switching to a high quality synthetic oil has to be worth a few hp?
Russ45 is offline   Reply With Quote
Old 12-07-2008, 05:12 PM   #12
GraimeG
Member#: 64865
1993 Impreza L AWD
Would it be easier/cheaper to buy new injectors?
Old 12-08-2008, 04:06 PM   #13
Rocketjones
Member#: 142754
2009 Forester XT
Clean the stock grounding points and do Big 3.
Rocketjones is offline   Reply With Quote
Old 12-08-2008, 06:48 PM   #14
GraimeG
Member#: 64865
1993 Impreza L AWD
Thanks for the help guys! However I'm not used to the lingo yet, what is "Big 3"?
Old 12-08-2008, 07:11 PM   #15
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
I would stay away from putting syn in a motor with that many miles. You'll most likely end up with nice coat of fresh, expensive synthetic on your driveway.
Reebis is offline   Reply With Quote
Old 12-08-2008, 07:28 PM   #16
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
if you don't understand the lingo..SEARCH. there's a lot to learn out there, and most of it has been covered.
yarrgh is online now   Reply With Quote
Old 12-08-2008, 11:31 PM   #17
Back Road Runner
Member#: 60082
2004 Forester STI
Old 12-09-2008, 01:19 AM   #18
GraimeG
Member#: 64865
1993 Impreza L AWD
Yeah, I'll search more. I did find tons of Big3 related threads both on this forum and others. Thanks again
Old 12-10-2008, 09:45 PM   #19
dougfeature
Member#: 196971
some major parts store have a core charge on injectors....they send them to get cleaned and tested and then resold...ive had amazing results with the BG injector cleaner...you disconnect the fuel pump and block the return line...hook air pressure up to the tank...wow..
dougfeature is offline   Reply With Quote
Links to general maintenance tips for Subarus? jrork Newbies & FAQs 1 11-02-2007 05:51 PM
General Maintenance Terms clemsonteg Newbies & FAQs 5 08-24-2007 11:30 PM
BG5 2.5 Auto tranny general maintenence K-A-O-S Legacy Forum 19 06-07-2006 10:03 PM
General Maintenence 02 WRX TheShadowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-10-2004 01:10 AM
General maintenance (What do you do to your car??) Karl Newbies & FAQs 11 12-11-2001 03:45 PM
