Old 12-07-2008, 02:12 AM   #1
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default Which wire to the ECU id the MAP wire?
Car is an Aussie spec 1998 WRX. The ecu has S8 on it.
I wanty to wire in my OLM 2 to it and just need to figure out which is the MAP wire. Anyone know?
renhoek is offline   Reply With Quote
Old 12-07-2008, 12:51 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
from what i can see. it should be pin B17. thats in the B136 connector witch is the 22 pin connector, the wire color is Yellow Black.
hope this helps.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 12-08-2008, 02:10 AM   #3
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Thanks Dave. I'll check it out.
Help me decide on which vacation to go on with the gf Donzo Off-Topic 58 03-23-2007 06:03 PM
which cat to put back into the system to pass emissions? dothespeedlimit Mid Atlantic Impreza Club -- MAIC 7 03-22-2004 03:46 PM
Is the ECU closing the injectors? HRE | giulio Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-15-2001 03:56 PM
Where is the ECU in the WRX? Ginseng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2001 07:21 PM
Does it needed to reset the ECU for the following changes? V6 Normally Aspirated Powertrain 5 10-27-2000 10:32 AM
