Old 12-07-2008, 01:56 AM   #1
sUpRSikwRx
Member#: 178813
BLUE
Default disable day time running lights?
i bought some H.I.D's and in order to have the high beams work i need to disable the day time running lights any help would be greatly appreciated, thanks again
sUpRSikwRx is offline   Reply With Quote
Old 12-07-2008, 02:27 AM   #2
Jncominco2
Member#: 170212
Jncominco2 is offline   Reply With Quote
Old 12-07-2008, 03:18 AM   #3
subaru3169
Member#: 55252
* pullup bar *
: sigh :
subaru3169 is offline   Reply With Quote
Old 12-07-2008, 03:28 AM   #4
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I don't think you need to remove DRL to make your HID kit work. Your HID kit needs DRL remove so you won't get the flickering lights. And since people already pointed you towards the search button and the HID FAQ thread, I'll just give you the jist of both threads....
Throw away the HID kit because it blinds people. But if you are still choosing the selfish choice of increasing visibility by decreasing others', then here's the way of removing DRL. There is a white plug to the passenger side of the interior (right next to the glove box). Remove it and your DRL will be off. But if you are going that route, I'm glad I'm not in CA area because I don't want another HID kit car to make my night time driving miserable.
Spore is offline   Reply With Quote
Old 12-07-2008, 01:46 PM   #5
Jncominco2
Member#: 170212
HID's decrease your usable light...so its actually decreasing your visibility as well, while blinding others
Old 12-08-2008, 11:00 AM   #6
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
SEARCH!!!
if not... Remove 10 phillips head screws in around glove box, remove glove box, unplug little whitish yellowish plug labeled DRL on the lowermost rightmost side of the box near the pass side door card/speaker. There should also be a blue plug next to it but only unplug the white. GL
JavaBot is offline   Reply With Quote
Old 12-08-2008, 11:17 AM   #7
Jncominco2
Member#: 170212
you can just look under the dash and see a black box with a whitish/yellow plug and unplug it
dont need to take out the glovebox
Old 12-08-2008, 11:43 AM   #8
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
I think you're right, may not have to take out glove box to reach on bugeyes, but 10 ph screws aren't tough to get around if you want to be sure you're pulling the right plug. Took me 15 mins total to remove, unplug, and remount glove box. GL
How 2: Disable Day time running lams in 07 WRX?? SLCDUB Electrical & Lighting 2 05-31-2007 02:57 PM
How to Disable or Turn off the Day time Running light mop Electrical & Lighting 1 06-23-2006 06:16 PM
Disabling day-time running lights? Subvert Newbies & FAQs 8 06-27-2004 12:12 AM
Disabling Day Time Running Light? White4drWRX Interior & Exterior Modification 6 09-28-2001 03:42 PM
Disabling Day-time Running lights mcv9802 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-17-2001 03:55 PM
