Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-07-2008, 08:24 AM   #1
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Question grinding noise in right rear when making sharp fast left turns
Like the title says, whenever I make a sharp fast left turn, I get a grinding noise from the right rear of the car. It sounds kind of like a brake pad dragging, and I do need new rear brakes, but it doesn't do it when braking or at any other time. The only other thing I can think of is a wheel bearing starting to go ie the turn is loading enough weight on the right rear wheel to make the bearing grind. Car has 55k on it, rear brakes and bearings are original (never touched) I recently swapped my snow tires onto it but I don't see how that could affect it unless I somehow bent something? Ideas?
Mike Wevrick is offline   Reply With Quote
Old 12-07-2008, 10:26 AM   #2
Bottom Feeder
Member#: 2808
Top of the tire rubbing against the inside of the fender? But that would be pretty apparent...?
Bottom Feeder is offline   Reply With Quote
Old 12-07-2008, 12:40 PM   #3
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^No sign of rubbing. Plus its only on one side and it never happened in the 1st 2 winters with the same tires.
edit: Plus its a very metallic noise
Old 12-07-2008, 01:26 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bearing
Old 12-07-2008, 03:30 PM   #5
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^That's what I'm thinking too. Any way to confirm? (I jacked that corner up and rotated/shook the wheel but it seemed fine.)
Old 12-07-2008, 09:32 PM   #6
Newbuggy
Member#: 152042
To me it doesnt seem like a wheel bearing. when i read the OP i instantly thought tire rubbing. i have the same problem. wheel bearing usually are a more constant noise like you should be able to hear it going down the road. no offence but i would double check fro rubbing. try loading down your wagon and take some hard corners and see if it makes the same noise when making a right turn in the left rear. take the wheel and tire off and check to see if maybe your fender liner on one side may have fallen down a bit. look at the tire to for wear marks near like the lettering. and maybe some pics may help too.
Newbuggy is offline   Reply With Quote
Old 12-07-2008, 11:13 PM   #7
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
bad cv joint perhaps?
STi-Nismo Dood is offline   Reply With Quote
Old 12-07-2008, 11:14 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
there ya go
Old 12-08-2008, 09:38 AM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I agree with Scotty though his terse ass response leaves a little to be desired. Plus this cold weather doesn't help, hence you just hearing it now.
Old 12-08-2008, 11:06 PM   #10
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^Cold weather makes bearings worse? Never heard of that.
Old 12-08-2008, 11:17 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
well.....temperature extremes will often make progressive issues accelerate
cold grease is stiffer and can accelerate wear issues
Old 12-09-2008, 09:54 AM   #12
Metallrulz
Member#: 100148
2003 WRX Wagon
Can you physically see if you need a new wheel bearing by jacking up the car and putting force on the rim in different directions to see if there's movement? I've done that on other cars and felt play, knowing it was the bearing, but wondered if it was always like that.
Metallrulz is offline   Reply With Quote
Old 12-09-2008, 11:17 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
this is NOT always true....but keeps getting posted
you can NOT always tell if bearings are bad in this manner
sound while driving is usually the first indicator of a bad bearing
Old 01-05-2009, 04:38 PM   #14
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^Yup; I think that method worked for older bearings but the newer ones can have no play and still be shot.
Update: I finally took it in and it wasn't a bearing. It was the backing plate rubbing on the rotor, which was badly rusted. It needed new rear brakes soon anyway, so I am having them done. First major work on the car in 55k, so I can't complain.
Old 01-05-2009, 04:39 PM   #15
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Old 01-05-2009, 04:50 PM   #16
z&cobb
Member#: 12344
2002 2JC
blue
A long time ago, a Subaru mechanic told me about the backplate issue. Rather common. So they fix and/or prevent the issue when they do a brake job.
I do my own brake jobs, but I share maintenance experience with the owner of the shop. Plus, I give him business when he can handle work more efficiently than I can.
I didn't respond to this thread since I didn't want to be told it was a wheel bearing, which it might have been. Remote diagnosis is always kind of iffy.
z&cobb is offline   Reply With Quote
Old 01-05-2009, 05:25 PM   #17
LRZ03WRX
Member#: 182377
Hmm, I have had the same problem with my wrx. I'm glad I saw this post!!
LRZ03WRX is offline   Reply With Quote
Old 07-20-2009, 10:35 AM   #18
artyj29
Member#: 217746
2011 WRX Ltd.
I just had the rotors and pads done by a friend on my MY02 WRX and I'm having this problem as well. My rear bearings were replaced less than a month ago by Subaru so I thought it had to be a brake issue... Any ideas on how to fix the plate issue? Does it need to be taken into the dealer or can it be done myself?
artyj29 is offline   Reply With Quote
Old 07-20-2009, 12:02 PM   #19
z&cobb
Member#: 12344
2002 2JC
blue
The Subaru mechanic just grinds the little bit of corrosion off the rotor edge as a trick of the trade when he does a brake job. I do my own brake work, and save his work for the more difficult stuff.
Old 07-20-2009, 01:30 PM   #20
macio04
Member#: 180198
2004 WRX wagon
Default What solved the problem for me
Take the rear wheel off.
Take the caliper and rotor off.
Now take a good look at the most bottom part of the park break plate. There is a spot on this plate right between the lower ends of park break shoes where it got bent outwards. You should be able to see shinny metal on that spot resulting from grinding.
What I did to fix it was punching the spot a few times with a chisel and a hammer.
No more grind while taking a sharp turn.
Hope it helps
macio04 is offline   Reply With Quote
Old 07-21-2009, 09:35 PM   #21
gando327
Member#: 101942
03 Impreza WRX
Silver *wingless*
on my car, my friend who did my brakes had to grind down the metal plate behind the rear rotor because it was rusted. It started grinding right after i got new brakes and rotors. Started right after he did the job.
gando327 is offline   Reply With Quote
Old 09-20-2009, 09:18 PM   #22
aiklimov
Member#: 224367
Default Same problem, and a solution.
I had the same problem which developed gradually, without installing new pads, rotors, or any other changes that I'm aware of. So I used Dremel to remove some of the backing plate around the scraping mark (bottom of backing plate). The backing plate is fairly thick (~4mm - double layer) and I removed less than 1mm. I also filed away a little bit of the rotor extrusion that was scraping the backing plate. Scraping sound is gone now. Thanks to the other posts and my brother-in-law who pointed me to this thread.
aiklimov is offline   Reply With Quote
Old 09-24-2009, 03:01 PM   #23
bjteel
Member#: 14442
2002 WRB WRX
I posted something about this a couple years back and no one mentioned it being a common issue with Subarus.
Good to know.
bjteel is offline   Reply With Quote
Old 09-28-2009, 02:28 AM   #24
hai8616
Member#: 224495
Thanks a lot : All of you. I started to have the same problem : When I make a sharp left turn , it sounds like brake pads are gone , I took both rear brake pads off and clean them, at 83k they are about 50% left and still OK , but the sound is still there , I know it should not be bearings or cv because if I drive straight nothing happens , only when I make a turn . I never thought about that . This weekend I am going to take the rotors off and see what happen
This is a great forum I learn a lot .
hai8616 is offline   Reply With Quote
Old 09-29-2009, 02:51 PM   #25
Sperm
Member#: 25038
2002 PSM WRX sedan
I'm having the same issue currently. Now I'm hoping that it's just that backing plate rubbing.
If it is a bad bearing, how hard would that be to fix in my driveway? Possible? Easy, even? I've done swaybars, lateral links, etc. in my driveway. I'm good with a wrench. Anyone that's replaced a bearing, please chime in!
Thanks.
And, yeah, this place is a great resource. Been here awhile now and I still love it.
Sperm is offline   Reply With Quote
Grinding noise from right front on left turns after accident Turbovan Brakes, Steering & Suspension 2 02-25-2009 05:01 AM
Grinding noise from passenger rear when turning slowly crofrog Brakes, Steering & Suspension 6 05-28-2008 03:54 PM
Sound when making sharp right turn sasquatch95 Brakes, Steering & Suspension 20 10-18-2006 12:26 AM
Fixed the popping noise in right rear today. 2003 sedan Brakes, Steering & Suspension 18 08-13-2004 02:17 AM
Grinding Noise From Right Rear arbabp Brakes, Steering & Suspension 2 03-06-2004 10:47 PM
