Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 12-07-2008, 02:52 PM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default metal grinding noise- help
My wifes car just started making a metal grinding noise this afternoon. there's nothing that seems to be dragging onthe ground so Im thinking its in the brakes or wheels. It only does it going forwards, there is no sound in reverse. Other than the sound, the car drives normally. does anyone know what it could be?
hendo2.5 is offline   Reply With Quote
Old 12-07-2008, 03:12 PM   #2
fatgroundhog
Member#: 44942
Did you just change the brake rotors? If so, that happens...do a search and you'll see that the fix is pretty easy.
fatgroundhog is offline   Reply With Quote
Old 12-07-2008, 05:02 PM   #3
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
We did change them a few months ago- thanks
Old 01-12-2009, 06:05 PM   #4
amdyagifighter
Member#: 199487
2009 2.5i Impreza
Dark Grey
I experienced exactly the same problem in my impreza last night. I was at a stopsign, put the car into gear and began moving forward and instantly heard a high pitched grinding noise. My car only has 1100 miles, so the breaks and rotors and new. What else could be causing the problem?
amdyagifighter is offline   Reply With Quote
Old 01-12-2009, 06:41 PM   #5
Emperor WuRM
Member#: 169737
2006 Wrx Tr
tranny? if its only when its in gear then it would have to be the transmission. what about when you engage the clutch?
Emperor WuRM is offline   Reply With Quote
Old 01-13-2009, 07:40 PM   #6
amdyagifighter
Member#: 199487
2009 2.5i Impreza
Dark Grey
...the grinding sound only occured that one time. If i remember correctly, i started to hear the grinding right around when the clutch began to engage first gear and my car started moving forward. It was a terrible sound.
Sheer metal/metal grinding noise from tranny area digitaljigga Transmission (AT/MT) & Driveline 1 03-19-2007 11:58 AM
metal on metal grind noise? pads or ball joint? j-speedracer Brakes, Steering & Suspension 7 07-12-2005 03:57 PM
Help! metal on metal grinding noise andyC Legacy Forum 19 04-29-2004 09:47 AM
