Old 12-07-2008, 05:32 PM   #1
Hokie-wrx wagon
Member#: 87194
2008 Impreza WRX STI
Spark Silver Metallic
Default 225/45/17s ok for winter tires on the '08 STI?
I just bought an '08 STI yesterday. I found a set of 225/45/17 Michelin Aplina winter tires locally that I'm going to mount on 17s that will clear the brakes. I just realized that the current tires on the sti are 245/40/18s. Are 225/45/17s going to cause problems for me? I know the speedo will be off by 2.6%. I should've researched before I bought them ... I should've gotten 225/50/17s.
Hokie-wrx wagon is offline   Reply With Quote
Old 12-07-2008, 09:05 PM   #2
krzyss
Member#: 8365
2005 Legacy GT Ltd
Atlantic Blue
I think the biggest issue will not be the fit as smaller tires do not present such problem.
Check load index but I think you should be fine.
Krzys
PS Verify that used tires are uniformly worn, check circumference of each tire (I assume that your winter tires are used).
krzyss is offline   Reply With Quote
Old 12-07-2008, 09:23 PM   #3
cpunlamd
Member#: 151360
2007 STI RIP
2013 EvoX/2010 GTR
The secret about "snow tires" is to go with a taller tire with a thinner width. For example: 225/45/17 is what I have on my STI from the factory. I purchased a set of Michelin snow tires in 215/50/17. Wide tires do not go well with snow or rain.
p.s. I bought my new Michelin snow tires from Tirerack CHEAP!!! ($104 each)
cpunlamd is offline   Reply With Quote
snow cables for 225/45/17 ok for a slightly smaller tire? SUBYDOODIE Tire & Wheel 2 12-02-2009 02:45 AM
FS: 17x7.5 +40 5x100/5x114 Voxx Monza rims with 225/45/17 hankook ipike winter tires flutyr525 Wheels/Tires 18 08-04-2009 11:37 AM
[FS] 225/45/17 Continental TS790V Winter Tires T1mmmy Wheels/Tires 12 09-22-2006 02:47 PM
Are 225/45/17s ok on a wagon dub2W..RX Tire & Wheel 6 02-05-2004 03:56 PM
225/45 17 ok for gc8? speed master Brakes, Steering & Suspension 8 08-08-2002 11:11 PM
Message Board Statistics All times are GMT -4. The time now is 08:39 AM.
