Closed Thread
Old 12-10-2008, 07:55 PM   #1
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Default grimms 44 ewg questions
Ok so i just bought the Grimmspeed 44mm ewg and I have a question. I have an 06 WRX tr with a vf39 and supporting mods with the cobb vf39 map on it. should i leave this map on the car as i drive to COBB and just run wastegate spring pressure after i install it or should i try and get a map from like clark turner so i can safely drive the car to COBB? I imagine as long as i bypass the ebcs and run it directly to the wastegate and do not get into boost i should be ok but i just wanted to confirm. Any help would be awesome! P.s. i tried to search but maybe didnt type in the correct keywords?
06HAWKMAN is offline
Old 12-10-2008, 08:00 PM   #2
TurboWRX32
Member#: 107557
2006 WRX
Steel Gray
I had the same setup. Depending on what spring is in the wastegate. I just ran direct vacuum to the wastegate and ran the spring. I did that as a temp. fix so I could drive the car. I wouldn't do it for a permanent thing.
TurboWRX32 is offline
Old 12-10-2008, 08:06 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Just stay out of boost. Keep your foot out of it and you'll be fine.
Turn in Concepts is offline
Old 12-10-2008, 08:06 PM   #4
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
the spring will be a .9 bar. i would only want to set it up this way to drive to the tuner
Old 12-10-2008, 08:47 PM   #5
Clark Turner
Member#: 178047
02 WRX STI Spec C
Run a line from the bottom port on the gate to the compressor direct. This will limit boost to around 10 psi and you will be fine. Dont run a line on the top of the gate. THen, When you get to your tuner, you can hook it up correctly.
Clark
Clark Turner is offline
Old 12-10-2008, 09:18 PM   #6
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
thanks man much appreciated! do you have a map for this kind of setup?
Old 12-11-2008, 07:34 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You live 6 inches from your tuner and you come here to ask tuning questions? Seriously? Think that line of logic through next time.
Unabomber is offline
Closed Thread
grimm speed ewg up pipe and tial 38mm Richmond WRX Engine/Power/Exhaust 3 03-12-2009 03:30 PM
Grimm speed ewg and turboxs downpipe Zspectrum Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 82 06-13-2008 03:31 PM
Grimm speed ewg/ upipe Zspectrum TXIC Private Classifieds 4 03-11-2008 11:38 AM
Question!! Tial 44 Ewg Overkill?? don kovy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-30-2007 12:41 AM
FS in CT : Cobb AP, Cobb TBE, UR UP / Tial 44 EWG sodo NESIC Private Classifieds 15 01-18-2007 02:41 PM
