Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 12-07-2008, 11:47 PM   #1
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Default Please Help: Looking for an STU car to run @ El Toro ProSolo and San Diego Nat. Tour
ProSolo El Toro (3/28 - 3/29) and San Diego National Tour (3/21 - 3/22).
Any west coast STU'ers out there want to offer me a co-drive at either or both of these events. Your car needs to not fully prepped either. Just looking for something with 245 width tires, stiff springs/coilovers, and lots of negative camber. If you're not sure your car qualifies as STU class PM me and I can help you determine its class. I can offer the following compensation:
-Beer
-Use of my STU WRX STi at some east coast '09 ProSolo or National Tour events
-Monetary compensation
Please post or PM me if you can help. Thanks!
Regards,
Jake
My Car Set Up
1. Intake: OE Airbox with the Home-Depot-Special Ram Air Ducting
2. Exhaust: Grimmspeed Uppipe, COBB Downpipe, Custom Magnaflow High-flow Catalytic Converter
3. Suspension: H&R/Bilstein/Perrin Coilovers Spring Rates - 457F/336R, Group-N Rear Top Mounts, Cusco Front Camber Plates, Whiteline 29mm FSB, Cusco 24mm RSB, Whiteline Steering Rack Bushings, Hotchkis Endlinks F&R, Front Strut Tower Brace
4. Alignment: -2.75 F Camber, -1.2 R Camber, 0 Toe
5. Tires: TBD
6. Wheels: Rota DPT 17x9 +42et
6. Brakes: Technifit SS Lines, ATE Blue Fluid, Hawk HP+ F&R
7. ECU: Stock
8. Other: Group-N Transmission Mount, Group-N Motor Mounts, TIC Race Differential Mount Bushings, CG Lock Seatbelt Tensioner, Hawker Odyssey PC680MJT Lightweight Battery 15 lbs
My Autox Resume (not comprehensive, but you get the idea)
-Trophied at '08 DC ProSolo
-Trophied at '08 Devens National Tour
-'08 STU Champion NNJR SCCA
-'07 A Class champion NASA/MotorsportsNE
-5th Place Overall '08 PAX Season Championship NNJR SCCA
References available upon request.
S1MPSONS is offline   Reply With Quote
Old 12-08-2008, 08:05 PM   #2
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
You might try posting to the SCIC chapter...
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 12-08-2008, 08:30 PM   #3
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I'll give it a try, but I have a feeling STU people check here more than local boards.
Old 12-10-2008, 04:31 PM   #4
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Note: Other compensation = $$$
Old 12-10-2008, 06:38 PM   #5
aufaber
Member#: 47448
1999 FP BMW
Elitetint.com/ChaseCam
STU competitors in So-Cal have dwindled significantly for '09.
aufaber is offline   Reply With Quote
Old 12-10-2008, 06:51 PM   #6
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Bummer. Too bad. STU is one class that never ceases to have a large turnout of fun, cool, down to earth competitors.
In another post of mine, a member said I should post some of my "qualifications" and some references. Here is what I wrote.
I am only really looking to drive and STU prepped STi or Evo since they are the only two proven STU competitive cars. I am sure many people would vouch for me. PM any of the following members for references:
"LightWerkz" - '08 A Class champion NASA/MotorsportsNE and NASIOC vendor
"Evil STI" - '07 STU champion NNJR SCCA, '08 HS champion NNJR SCCA
"Corey" - '07 ProSolo STU champion
"espEVO" - 3rd Place Overall PAX '08 DC ProSolo
"bdi" - Northeast Competitor (STU)
"Buttdyno" - Northeast Competitor (STX) and NASIOC moderator
"KAIBUTSU" - 2nd Place AS '07 ProSolo Finale
Old 12-10-2008, 07:22 PM   #7
aufaber
Member#: 47448
1999 FP BMW
Well, you can try:
Cal Club
http://Forums.solo2.com
Sand Diego
http://www.sdsolo.com/forum/index.php
Old 12-10-2008, 11:34 PM   #8
BlkWRXWag
Member#: 31821
2015 DS WRX
Good luck - I hope you get a ride. Unfortunately my old car is is now commuting with a baby seat in the back
BlkWRXWag is offline   Reply With Quote
Old 12-11-2008, 02:58 AM   #9
littlewhitewagon
Member#: 103068
11 STI sedan
I am open to you running my wagon, but I'm not sure if it falls within STU.
17x8 RPF-1
245/35R17 R1R
JIC FLT-A2
Cusco rear adjustable sway bar
KB rear end links
Cusco rear stiffening bar
STI diffuser
Cobb AP stage 2 91 oct CA map
Titek catless DP
Greddy SP2 exhaust
DBA 5000 XS front rotors
Project Mu HC+ front pads
Rotora lines (all 4 corners)
littlewhitewagon is offline   Reply With Quote
Old 12-11-2008, 03:14 AM   #10
DumbUglyDragon
Member#: 61077
1993 WRX
17x8 RPF-1
245/35R17 R1R
JIC FLT-A2
KB rear end links
STI diffuser
Titek catless DP
Greddy SP2 exhaust
No, it doesn't.
DumbUglyDragon is offline   Reply With Quote
Old 12-11-2008, 10:48 AM   #11
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Thanks! but I need an stu legal car. You ecu map is illegal too. But that's a quick fix.
Old 12-11-2008, 12:20 PM   #12
BlkWRXWag
Member#: 31821
2015 DS WRX
Jake - I don't think the local STU people, other than Rick Jung, really know if they will be signing up yet. STU has been dominated by two cars here which has lead to some apathy on the part of the other drivers. You should also post on the solo2 forums, since that is the LA region.
Closer to the time, I'll do all I can to get you a ride - the more in STU the better!
Old 12-11-2008, 12:37 PM   #13
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Much appreciated! Hopefully compensation will outweigh apathy. Who is the other dominating SoCal STU driver? I assume, Rick is one.
http://forums.solo2.com Doesn't have a registration link nor a contact information for the admin. How do I get on this forum?
Old 12-11-2008, 12:50 PM   #14
Banannie
Member#: 101199
2013 BRZ
BlackWRXWag = reighning ProSolo champ, and his accent is quite intimidating!!! Ha ha
Banannie is offline   Reply With Quote
Old 12-11-2008, 12:57 PM   #15
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
So does this ^^ mean no more STU for you?
I just check the ProSolo '08 season STU results. Does anybody know Aaron? Is he a NASIOC member? He ran really well this year and also ran El Toro. Maybe he would be interested.
Old 12-11-2008, 01:09 PM   #16
Banannie
Member#: 101199
2013 BRZ
If you look closer, Aaron was Max's pit boy
Old 12-11-2008, 01:13 PM   #17
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Haha. Right then, that makes sense. So is this STU car still around? What does all that baby-seat commuter-car talk mean? Street driven autox cars is what STU is all about.
Old 12-11-2008, 01:45 PM   #18
BlkWRXWag
Member#: 31821
2015 DS WRX
Aaron is aufaber and has posted in this thread. He is also the admin for forums/solo2
Old 12-11-2008, 01:55 PM   #19
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Thanks! PMed Aaron to set me up on solo2forums. So Max, are you running STU next year?
Old 12-11-2008, 03:58 PM   #20
BlkWRXWag
Member#: 31821
2015 DS WRX
For National events I will be, although I will be co-driving someone else's car
This car is a super secret car, just purchased the other day... it's going to be awesome. Rick Jung may as well retire right now
Old 12-11-2008, 05:13 PM   #21
Banannie
Member#: 101199
2013 BRZ
People who are observant will figure out who's car it is pretty quick
Old 12-11-2008, 11:44 PM   #22
kursplat
Member#: 89528
2005 sti
crystal grey
if they don't sell it and get something else by then
kursplat is offline   Reply With Quote
Old 12-12-2008, 12:53 PM   #23
aufaber
Member#: 47448
1999 FP BMW
If they haven't sold it and gotten somethign else ALREADY.
Old 12-12-2008, 12:57 PM   #24
Banannie
Member#: 101199
2013 BRZ
I don't think the 29 day record from the Z06 will be broken on this one!
Old 12-12-2008, 01:17 PM   #25
Chiketkd
Member#: 71634
In hibernation...
^Wait?! Do you still have the '09 WRX Annie???
Chiketkd is offline   Reply With Quote
