Old 12-08-2008, 10:15 AM   #1
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Default which car will be faster?
we have 2 cars they are identical, they have the same power mods, same suspension mods, same everything but wheels and tires.
Car A: has some 18x9.5 wheels that weight 22 lbs and some 245/40/18 tires that weight 27 lbs
Car B: has some 17x8 wheels that weight 14 lbs and some 215/40/17 tires that weight 18 lbs.
**tires are the same brand and compound**
Which will win on Auto cross, how about road racing, and drag?
Idk I know one will more surface contact but the other will have less rotational mass.
Old 12-08-2008, 10:26 AM   #2
soulbazz
Member#: 95916
2004 Impreza WRX
1998 Legacy GT Wagon
grassroots did a pretty good article on this (using a miata) a few months back ... maybe you can find it on their website. it has test data and I found it pretty useful
soulbazz is offline   Reply With Quote
Old 12-08-2008, 10:29 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Assuming the tires perform the same with sidewall/width ratio, slip angle etc...same driver, you really can't call it. Best guess is:
B would win in all counts of forward acceleration so long as traction isn't an issue.
B would loose in braking and cornering grip. Although A does have more work for the brakes to handle.
Homemade WRX is online now   Reply With Quote
Old 12-08-2008, 10:30 AM   #4
leecea
Member#: 37359
2003 WRX
There is also a significant gearing change due to tire diameters.
IMHO, there are too many unknowns.
leecea is offline   Reply With Quote
Old 12-08-2008, 10:35 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
well that's why I said tire B would win acceleration, although I guess pending power levels/traps that could be requiring another gear shift...
Old 12-08-2008, 10:54 AM   #6
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Code:
Stock Tire - 215/40R17
Tire 1 - 245/40R18
Section Width: 8.46 in 215 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 7 - 8.5 in
Rim Width Range: 8 - 9.5 in
Overall Diameter: 23.77 in 603.75 mm
Overall Diameter: 25.71 in 653.03 mm
Sidewall Height: 3.38 in 85.852 mm
Sidewall Height: 3.85 in 97.79 mm
Radius: 11.88 in 301.75 mm
Radius: 12.85 in 326.39 mm
Circumference: 74.67 in 1896.6 mm
Circumference: 80.77 in 2051.5 mm
Revs per Mile: 875.0
Revs per Mile: 809.0
Actual Speed: 60 mph 100 km/h
Speedometer1: 55.4 mph 92.4 km/h
Speedometer Difference: - Speedometer Difference: 8.158% too slow
Diameter Difference: - Diameter Difference: 7.55%
Better driver wins, handsdown.
cucamelsmd15 is offline   Reply With Quote
Old 12-08-2008, 11:31 AM   #7
KC
Member#: 442
16 SS
00 S2000
All being equal, and same driver, I'd call it too close to tell. Too many other variables to say which will win based on just tires/wheels.
--KC
KC is offline   Reply With Quote
Old 12-08-2008, 12:08 PM   #8
juanmedina
Member#: 133146
so it seems that car should be about equal. Car A been faster on the acceleration department while Car B is faster on the corners and braking.
Old 12-08-2008, 12:20 PM   #9
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I've covertly put a "rallydecals.com" sticker on car A......now who wins?
jack
Old 12-08-2008, 12:25 PM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Add a jackstand sticker to car A next to the rallydecals.com and its a no brainer.
-Tom
who won on thinner but shorter tires before because of gearing
trhoppe is offline   Reply With Quote
Old 12-08-2008, 12:40 PM   #11
STi-MAN
Member#: 70252
05 STI
blue
Yea, i think theres alot of other factors as well.. the track being a huge one.. but i'd go for more meat on the tires winning.
STi-MAN is offline   Reply With Quote
Old 12-08-2008, 01:12 PM   #12
KC
Member#: 442
16 SS
00 S2000
I wouldn't.
--kC
Old 12-08-2008, 02:02 PM   #13
leecea
Member#: 37359
2003 WRX
As I said, there are two many unknowns. The OP doesn't even say what car or what mods. Just that they are equal.
Imagine two versions of this test being run, one with stock Miatas and another with modified Z06s.
Will a Z06 accelerate faster on 215s?
Even if you assume it's a Suby, the differences between a stock NA Impreza and a 500whp STi will change the equation. Given enough power, the 215s can't get the power down to take advantage of the gearing and weight reduction.
Old 12-08-2008, 02:52 PM   #14
juanmedina
Member#: 133146
I am talking about my car.
Power mods: vf39, sti TMIC, gimmick turbo inlet, APS CAI, Perrin EL and Uppipe, TGV deletes, Phenolic spacer, Buschur Racing catless TBE, 860cc injectors, and a E85 tune that is not finallized .
Suspension mods: megan racing street coilovers, cobb adjustable swaybars and kartboy endlinks.
The car should weight about 2890-2910 with the heavy wheels and tires without me, I weight 150 lbs. Also, it has a stock 07 WRX tranny.
Old 12-08-2008, 02:58 PM   #15
cucamelsmd15
Member#: 122980
Oh, well, in that case, the larger tires/wheels will only emphasize your asstastic gearing and final drive.
Old 12-08-2008, 03:48 PM   #16
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
also, how good of a driver are you? That would make a big difference between the two. Are you good enough to be able to fully utilize the extra tire? I'm really only asking in terms of road racing.
However, based on what you've given me, and assuming you are an average, but not great, driver. I would guess the thinner tires would win in autocross and drag, while the wide tires would win at road racing.
Hopefully, Im right. Because that was pretty much the basis I used to make my decision on wheels/tires for my soon-to-be-road racing RS.
KAX is offline   Reply With Quote
Old 12-08-2008, 08:05 PM   #17
Jaberwocky
Member#: 87190
Small differences in alignment, shock valving, and tire age could make a difference. The devil is the details.
With that said, it should be close, but one car will be better than the other depending on venue. One has less rotational mass and shorter gearing while the other has wider rubber - Course dependent.
Jaberwocky is offline   Reply With Quote
Old 12-08-2008, 08:27 PM   #18
STi-MAN
Member#: 70252
05 STI
blue
Yeah,
also short gearing doesnt nec.. equal faster track time.. depending on different sections of a track, the car with the taller gearing could be faster then that with the short since no time will be lost for a shift.
Old 12-08-2008, 10:06 PM   #19
waktasz
Member#: 86356
2015 s1000r
wheelie monster
For that year WRX on most SCCA courses I'd want a short tire, but 215 is too skinny. Why are you limiting yourself to those two choices?
waktasz is offline   Reply With Quote
Old 12-08-2008, 10:16 PM   #20
davis10
Member#: 70011
17 pounds per wheel of unsprung weight is a lot..
I'd say the longer one is better for autocross
I lot depends on how much power the car has.
davis10 is offline   Reply With Quote
Old 12-08-2008, 10:45 PM   #21
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Car C: Has 17x8 wheels that weigh 14 lbs and 245/40R17 tires that weigh 20lbs?
Car C wins hands down.
speedyHAM is offline   Reply With Quote
Old 12-08-2008, 10:47 PM   #22
Tarmac Junkie
Member#: 188792
1994 Civic
Red
I would say for road racing, car A would be faster despite being heavier. Thats why in, say time attack, I would want the widest tire that would suit my needs. 215 or 245, it seems like a no brainer.
For drag, I would say if the car doesnt spin the tires, car B would be faster, just because of the lighter weight and less rotating mass.
Autocross???
Tarmac Junkie is offline   Reply With Quote
Fordís global mid-size car will be built on the Mondeo platform, will replace Fusion AVANTI R5 Non-Subaru News & Rumors 8 03-23-2009 09:08 PM
so which Ot'er will be the first to kill me for posting this pjhe Off-Topic 6 05-16-2008 10:17 AM
Which Japanese Cars Will Be 'Classics'? Tragedy Off-Topic 100 04-12-2008 02:15 AM
Seems like my car should be faster? jersey1320guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 09-07-2007 04:36 PM
My car will be in a car show! HRE | giulio Tri-State Area Forum 5 05-23-2001 01:26 PM
