Old 12-08-2008, 01:32 PM   #1
Don Nguyen
Member#: 188383
Default Flipping Azenis RT-615s - Inside to Outside
Has anyone done this, and tracked their car on it? My azenis have somewhat decent wear on it, but it still shows sign of quicker/more inner wear than outer wear.
I just need to have these last one more track event and driving from norcal to socal. Basically to the end of this month, before they are replaced.
I am just wondering if swapping them will cause any noticeable differences. I've read that the outside compound is not as soft/sticky as the inside compound, however, I may be able to live with that as long as everything else is ok.
Any feedback would be great.
thanks.
-Don
Don Nguyen is offline   Reply With Quote
Old 12-08-2008, 04:51 PM   #2
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
It work, but it likely won't have quite as much grip. Then again, I hate azenis anyway.
But I wouldn't rely on one set of tires for a track day AND a long drive. I'd pick one or the other.
xcdhridr is offline   Reply With Quote
Old 12-08-2008, 04:55 PM   #3
Don Nguyen
Member#: 188383
They are my daily driver tires, and I am fairly sure they will make both the track event and trip.
Old 12-09-2008, 12:23 AM   #4
Evan
Member#: 11218
2005 Legacy GT Wagon
99 Miata, 91 Miata turbo
I've never tried this, but have always wondered if it was safe. The harder you turn, the more load you place on the outside of the tire, so is it really better to put the more worn edge out there? I guess the answer depends on your alignment settings.
Evan is offline   Reply With Quote
Old 12-09-2008, 12:30 AM   #5
Davidss
Member#: 27446
Z06
Yes it works fine and is perfectly safe. I've had to do it tons of times and never noticed any difference.
Davidss is offline   Reply With Quote
Old 12-09-2008, 12:30 AM   #6
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
ummm i would not recommend this, just my .02 worked in a tirecenter for a few years and have gone to a few michelin training seminars where we got to test out having better tires in the front and rear in wet weather situations, asymmeticals inside out and directionals going the wrong way, here's a quick def and you have the rt615 which are an asymmetrical design.... Another variation in tread design you’ll see is "asymmetrical" tires. Tires with an asymmetrical design mix tread patterns or put more rubber on one side of the tread than the other in an effort to make one tire out of two different tread patterns. Some combine a slick-like smooth tread on half the tire (to improve traction) with a block pattern on the other half (for directional stability).
mpsti05 is offline   Reply With Quote
Old 12-09-2008, 01:20 AM   #7
Tarmac Junkie
Member#: 188792
1993 Integra
I've had the same experience.
Tarmac Junkie is offline   Reply With Quote
Old 12-09-2008, 01:45 PM   #8
Don Nguyen
Member#: 188383
Technically yes, I have heard that. However, my insides still wear out a lot faster than my outsides. It wears out somewhat evenly, but still wear more on the inside than outside.
I agree, in wet weather conditions, it can't be good or better to run them in the wrong driection. However, how "bad" could it be in dry weather? Thanks for the input/info.
I just swapped mine the other day, since my insides were almost completely worn down, so I doubt they would have provided any wet traction at all anyways. So far, the swapped tires seem to be able to provide me with more feedback, less tramlining, and better feel.
We'll see how it holds up for now. If anyone else has any feedback or info, that'd be great.
thanks.
-Don
Old 12-09-2008, 02:06 PM   #9
Evan
Member#: 11218
My guess is that you've changed when you're most likely to see a tire failure. With the worn edge on the outside, I would expect it to fail during cornering. With the worn edge on the inside, I would expect it to fail while the steering wheel is straight and under hard acceleration or hard braking.
Try to use a pyrometer at the track to check tire temps across the tread.
Obviously, you should take out some camber if you can.
Old 12-09-2008, 03:47 PM   #10
Don Nguyen
Member#: 188383
Tire temps are even across the tires, using a tire pyrometer.
-Don
About to purchase a aet of Azenis RT-615s......but what will be the perfect size?! spooledwrx Tire & Wheel 5 04-28-2006 04:03 PM
new Azenis RT-615 is in stock now at vulcan nhluhr Tire & Wheel 116 06-21-2005 01:27 PM
New summer tires are on. Falken Azenis rt-615. No more snow please. 56k take a nap rex n effect Mid Atlantic Impreza Club -- MAIC 27 03-15-2005 02:52 PM
New Azenis RT-615 Mark B. Tire & Wheel 62 02-02-2005 10:36 PM
AZENIS RT-615 up on Vulcantire.com wrx2.0 555 Motorsports 36 12-03-2004 11:26 AM
Message Board Statistics All times are GMT -4. The time now is 02:46 PM.
