Old 12-08-2008, 08:09 PM   #1
jrobe
Member#: 172156
1995 Legacy LS Wagon
blue
Default 2.2 lifters collapsed, now rough idle
My 95 2.2 got the tick the other day after I put some high mileage oil in. I figured the detergents in the oil broke free some crud. Went I pulled the valve cover all 4 on top were collapsed. I filled them with oil and fired it up and it idled so rough it shook the whole car for a couple of minutes then it idled smooth and 15 minutes later the tick was back.
I pulled them again all 4 were collapsed again, pumped them up and it idled rough again for a few minutes till it would smooth out.
What could make it do that? and there is no CEL
thanks Jeff
jrobe is offline   Reply With Quote
Old 12-11-2008, 09:54 PM   #2
jrobe
Member#: 172156
blue
anyone?
Old 12-11-2008, 10:03 PM   #3
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
just curious, wat weight is the oil ur running? synthethic or conventional? i did that ot my 72 buick 455, and the same thing happened, swap to a lil thicker oil. the lighter stuff gets around better, but doesnt hold up for lifters too well it seems. also remember that synthetic is much lighter, the 20/50 weight moves like 5/30 conventional. just things to think about.
rivman05 is offline   Reply With Quote
Old 12-12-2008, 10:14 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Low oil pressure maybe?
You may just need to replace the hla's. You could try adding 1/2-1 qt. of atf in your oil for a short time to loosen all the gunk. Obviously then do an oil change.
Tim Sanderson is offline   Reply With Quote
Old 12-12-2008, 11:17 AM   #5
jrobe
Member#: 172156
blue
I put Mobil 1 high mileage, I think it was 10w 40. The motor only has 80K and runs great besides the lifter. Right now I do have 3qt of atf in it. I'm not driving it, just starting it up and letting it run every now and then. When I put it on the road I am going to run Rotella syn 5w 40.
It's the running rough(missing) when I get it back together that makes me wonder. Then after 5min it runs normal.
Jeff
Old 12-12-2008, 08:05 PM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
What weight is recommended in the manual? 10w40 seems kind of high, especially for December in Wisconsin...
Counterfit is offline   Reply With Quote
Old 12-13-2008, 08:26 AM   #7
John*G
Member#: 19562
95 coupe
red
You have to pull out the HLA's and pump them up manually in a oil bath. If they won't pump up they are shot. Which I guess you have done. Having four go at once is odd though. I worked on a car a while back that had a plugged up rocker arm assembly. Several of the tiny oil feed holes to the HLA's in the rocker arms where plugged with tiny metal splinters , one in each. I don't think it even blocked the feed hole entirely. Unfortunately the HLA's where ruined from running dry.
John
John*G is offline   Reply With Quote
Old 12-13-2008, 10:17 PM   #8
jrobe
Member#: 172156
blue
The 10w 40 I was running was syn oil.
I am taking them out and pumping them back up. It will run like crap at idle for a few minutes and then smooth out and run tick free for as long as I let it run. When I come back the next day it ticks again.
I figure the only way 4 can collapse at a time is some blockage, which I can't find.
The thing that baffles me is why would it run rough after I pump them up.
Old 12-14-2008, 02:07 PM   #9
piperpilot26
Member#: 197453
try 10w 30, its more or less something blocking the oil passages. or mabye its an oil pump issue? the rough idle thing I'm not getting either.
piperpilot26 is offline   Reply With Quote
Missed a shift and now rough idle?? mcganz121 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 06-01-2008 05:13 PM
New Spark Plugs... now rough idle??? bmw50021 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 12-02-2006 01:04 PM
rough idle, and now no start quadtard Service & Maintenance 19 06-27-2006 01:12 AM
Sudden change in quality of idle, now rough -=Ice-T=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-29-2005 10:13 PM
Mobil-One oil change, now rough idle blackdog Newbies & FAQs 22 10-29-2003 01:06 PM
