Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-08-2008, 10:39 PM   #1
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default calculating horsepower
173 hp is what my motor put at the crank stock .when I look at my stock map the highest g/rev value is like 1.3 I think. Can I equate those?
Like can I say now I'm putting out x g/rev figure out what percent that is higher than the stock max value and then add that percentage to the stock. Hp number
If that makes sence?
watchunglava is offline   Reply With Quote
Old 12-08-2008, 11:03 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
You could worth back through the math. Mainly what you need is the correlation between force and time. Any method will need additional information like car weight, gearing, etc. In the end, you have to work your way back down to the physical torque that the tire applies to the road and at what rpm.
One of the easier routes, kinda, is to simply do a series of pulls in the car and record sensor information. RomRaider is a good tool for reading and storing this info. All you really need is rpm. Time comes along with it, and the change in time and change in rpm will give you all that you need. There's another program called Data Log Lab (not free but a trial version that you can play with). You simply open the rpm recorded log file from RomRaider in it, and input the specs for your car (mass, gearing, aerodynamics), and it will generate your torque and horse power numbers with the press of a button. Well there's a couple more setup steps like grabbing the romraider definitions from romraider's sight for DLL. There's also pre made up car data available for a number of Impreza models too.
Old 12-08-2008, 11:07 PM   #3
watchunglava
Member#: 168862
nice i just downloaded the trial version yesterday i havent had the time to check it out sick to hear its got sweet tools on it though.
ill definatly check the hp on their, but if your right and i can equate the g/ rev like i said in the o.p. then im at 198 hp at the crank right now . before ecu tuning
Old 12-09-2008, 02:02 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
g/rev is more for torque than HP.
Old 12-09-2008, 02:05 PM   #5
watchunglava
Member#: 168862
right on, well what it came down to was like 18% more g/ rev so whatever that equates to. im souped about 18% just from bolt ons .
Old 12-09-2008, 07:48 PM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
HP = (torque x RPM)/5252
Torque is in ft-lbs.
Counterfit is online now   Reply With Quote
Old 12-09-2008, 09:20 PM   #7
ProDarwin
Member#: 134943
94 SW2, 95 SW2
9(?) Lemons Car
accel = (overall eff*engine power - road load power)/(effective mass * velocity)
Ignore torque. It has nothing to do with acceleration. If so desired, you can calculate it from rpm.
ProDarwin is offline   Reply With Quote
Old 12-10-2008, 01:17 AM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You're only up 18% if your MAF scaling was perfect before and after the changes. Trust me, I've been down this path before. Hell, the stock tune, stock engine claims to hit a 1.29g/rev peak load. Scale the MAF properly and that drops to 1.13-1.14g/rev for a real number. I know you haven't scaled your MAF in the upper ranges yet because you don't have a wideband. So your engine load numbers are meaningless, sadly.
Old 12-10-2008, 01:20 AM   #9
watchunglava
Member#: 168862
true that i was like damn 168 !!!
Old 12-10-2008, 01:21 AM   #10
watchunglava
Member#: 168862
wide band is coming as soon as i can get the exhaust squared away .
Old 12-10-2008, 01:23 AM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Dude, you have got to start learning to put more than one sentence in a post. This whole string-of-1-line-posts-every-minute is going to end up with a mod penalizing you for being a post whore
Old 12-10-2008, 01:28 AM   #12
watchunglava
Member#: 168862
wow really? how fascist . and incorect, it should be post slut, im not recieving any money out of the deal.
Old 12-10-2008, 12:29 PM   #13
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
no but you def went from a newb to a specialist super fast because of the 1 sentence per post
zavier is offline   Reply With Quote
Old 12-10-2008, 01:27 PM   #14
watchunglava
Member#: 168862
i dont see what the difference is 1 sentence or 1 paragraph as long as it has substance ,i dont even know how rankings are set up like newbie specialist or whatever . i thought i got promoted becuase i was the man . or because im sleeping with the boss. or because im about to be an ase certified tech ? or because my wang is as big as a babies arm. whatever the case is im definatly no newbie .
not my fault its allmost 2009 and i ussually post on my blackberry, instantly ,. ill just have to post longer post? i dont know whatever dont hate !
this is so off topic anyway. but i guess the op was answered so im going to unsubscribe anway . good discussion everyone.
Old 12-10-2008, 02:22 PM   #15
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
What is g/rev?
from some searching, it appears to be air mass ingested per revolution?
sniper1rfa is offline   Reply With Quote
Old 12-10-2008, 02:26 PM   #16
watchunglava
Member#: 168862
the axis value “Load” for ign and fueling tables, given in unit of g/rev, can be obtained from a MAF reading in g/s and the RPM of the engine. example: My engine logged 202 g/s at 5666rpms. so, in order to convert 202 g/s to g/rev, we do this: divide rpms by 60 to turn it into rev (which is actually revolution per second, not revolution per minute, which is pretty much uniformly referred to in the ECU as RPM. I denote this because in conversation “revs” usually refers to RPMs. NOT FOR ECUS IT DOESN’T!) so, 5666/60=94.434 then, we divide g/s by rev so, 202/94.434=2.139 g/rev, which is what the axis is in.
Old 12-10-2008, 03:03 PM   #17
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Still haven't told me what g/rev is.
I know what it's *for*, i just don't know what the unit means. g could be a unit of acceleration, for example, or perhaps a unit of mass (grams), or if your forget the caps key it could be the gravitation constant or the shear modulus of a material.
Old 12-10-2008, 03:09 PM   #18
watchunglava
Member#: 168862
it says it right there , its gallons per rev. take rmos divide by 60, youll get rps ( revs per second.) thats your revs. then take your gallons per second and divide by the rev # .
youll get gallons per rev. its measuring how many gallons of air your sucking in per revolution.
Old 12-10-2008, 03:12 PM   #19
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
gallons?
Weird.
Old 12-10-2008, 03:14 PM   #20
watchunglava
Member#: 168862
im pretty sure its gallons. why would it be wierd?
Old 12-10-2008, 03:16 PM   #21
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
because gallons of a gas is dependent on pressure.
I was thinking grams, but that's a pretty small number. Although at atmospheric, maybe it's not.
EDIT: no, that makes sense. One liter at STP is about 1.3 grams
Also, gallons isn't metric.
Old 12-10-2008, 03:16 PM   #22
watchunglava
Member#: 168862
accually it might be grams! my bad lol . im not ase certified yet!!!! lol
Old 12-10-2008, 03:18 PM   #23
watchunglava
Member#: 168862
in fact its definatly grams im so sorry i have no idea why my brain made me write gallons but whatever im here correcting myself sorry
Old 12-10-2008, 03:47 PM   #24
Un0RiGiNaL
Member#: 189748
this is too confusing just take your car to the damn dyno
Un0RiGiNaL is offline   Reply With Quote
Old 12-10-2008, 07:09 PM   #25
GrundleJuice
Member#: 165749
its grams. gallons is a unit of volume not mass. Its also an imperial measurement, so it has more than one correct value (U.S. Gallon is not = to Imperial gallon).
APv2 Horsepower Performance Calculator Stames_wiltz Proven Power Bragging 2 10-11-2008 06:26 PM
Accessport Horsepower calculations Shakes AccessPort 0 02-18-2008 10:04 AM
Fun with drives ... Power and Horsepower calculations Brady Off-Topic 6 11-30-2005 04:05 PM
calculated horsepower??? geronimo66 Proven Power Bragging 11 10-01-2003 09:37 PM
Formula for calculating horsepower needed for AutoLogger LiquidForce Engine Management & Tuning 6 06-10-2003 07:58 PM
