Notices
Old 04-05-2012, 11:44 PM   #301
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Originally Posted by JourdanWithaU
Which coupler? I changed them both.
The catch can isn't necessary. I noticed a considerable amount of oil in my stock intake so I figured it might be a good idea. However, I have yet to see any oil in the new tubes (why I opted for clear).
The bubbled one at ur air box
krzywhtboi82 is offline   Reply With Quote
Old 04-05-2012, 11:48 PM   #302
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
And what do u got ur catch can draining into.
Old 04-06-2012, 07:44 PM   #303
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
got mine on yesterday put like 30 miles and runs great just got kinda a rough idle but i also had them do the recall that reset the comp and they said it could idle rough for a bit till it relearns and after that i got home and put it on. sounds great when u get on it or rev it. no lights for me. notice a bit more torque and seems to take a bit longer now to warm up even when its like 60 out
Old 04-06-2012, 08:12 PM   #304
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Hooked a scanner and read my maf values. At idle I was at .4 and wot 6000 rpm I was at 4.7. Does.that sound right ill have to figure out house to save the graph and put a pic up
Old 04-06-2012, 08:26 PM   #305
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Interesting...
Those voltages seem to go lower and higher than what williaty referenced in the sticky.
Sounds like your experience is very similar to mine though. The catch can doesn't drain into anything it just collects the gross oil that gets puked out of the crankcase and that coupler is a standard hump coupler that I ordered from Amazon. I actually have an extra one because it came in a 2-pack.
JourdanWithaU is offline   Reply With Quote
Old 04-06-2012, 09:19 PM   #306
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Is that good or bad? Also remember I just had my comp reset dealer said could take a week or two to fully release and run right. Also I hate the 2 piece set up on crank hoses I'm gonna try to find a one long hose for each side. Hey where'd u get the bubble coupler at ur air box and the longer one at ur throttle body.
Old 04-06-2012, 10:05 PM   #307
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Ordered them both off Amazon. I have an extra hump connector, plugs and some hose. Would you be interested in any of that?
Old 04-06-2012, 10:40 PM   #308
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Just the hump connector bc I cant find one. I got the other stuff already
Old 04-07-2012, 10:11 AM   #309
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
PM'd.
Old 04-08-2012, 01:10 AM   #310
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Just ordered the same $15 intake. Kinda excited to see how it turns out
KartRacer3 is offline   Reply With Quote
Old 04-08-2012, 10:09 AM   #311
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Cleared 100 miles. It seems the ECU has got it all figured out and it's running great. No CEL. Can't tell if it is making any noise. My exhaust is all like, "I'm sorry you can't hear your intake over the sound of how awesome I am."
One of these days I might get around to putting the silencer in and see if I can hear anything from the intake.
Old 04-08-2012, 10:25 AM   #312
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
I got stock exhaust on mine so I can hear it and it sounds good. Sounds better when I took off that flat funnel piece on the front of the box
Old 04-08-2012, 11:03 AM   #313
DirknJirkn13
Member#: 249696
2010 Outback Sport
The piece that brings the air in? Probably a good idea to leave that on there.
DirknJirkn13 is offline   Reply With Quote
Old 04-08-2012, 11:46 AM   #314
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
I don't think it will make much of a difference performance wise. With the way the funnel is oriented I don't think it really brings much to the air box. I would be worried about other stuff going into the air box though.
Old 04-08-2012, 02:03 PM   #315
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Yea it does affect anything with out it.
Old 04-08-2012, 02:06 PM   #316
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
No more than with it on and sucking stuff in from out side the car. Actually prob less bc it won't suck in water or bugs or dirt. I've had it like that for 6 months and my air filter is staying cleaner. I still have the piece that's on the hood that helps direct in coming air
Old 04-09-2012, 12:10 PM   #317
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
So I've had mine on for a few days now. Everything runs great. Only thing I'm noticing is its taking longer to warm up. Or at least I think so these don't have a temp gauge just a idiot light that turns off when its warm. So question is has anyone else noticed this
Old 04-09-2012, 06:16 PM   #318
bradyarz
Member#: 272381
2008 Impreza OBS
Just FYI (if you already knew, disregard) the idiot light turns off at 120 degrees*. Normal operating temp is ~188 degrees*
*according to my scangauge.
bradyarz is offline   Reply With Quote
Old 04-09-2012, 07:06 PM   #319
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
It's a bit lower than 120 according to my Depo Gauge. I'd have to double check, but I am pretty sure that the bottom end of my gauge is 100 and when the light turns off, the needle still hasn't moved. Then after a few more minutes it starts to make it's way towards 180.
Old 04-09-2012, 09:47 PM   #320
bradyarz
Member#: 272381
2008 Impreza OBS
Where are you pulling data from? Did you have to add an aftermarket sensor? I'd be willing to bet that's the difference; the scangauge pulls all the values through the OBD port. I can see just about all the parameters the ECU sees.
Old 04-10-2012, 12:06 AM   #321
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Aftermarket sensor on the upper radiator hose.
Old 04-10-2012, 01:09 AM   #322
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Yea that's cool bit all that means to me is that its taking longer now to reach 120 than it dis before. So does that mean it has something to do with the intake.
Old 04-10-2012, 01:10 AM   #323
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Thinkin of doing this. What did u use. How'd u do it. I hate not having a gauge
Old 04-10-2012, 09:07 AM   #324
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
I'd suggest skipping on the gauges and sensors, and just get an OBDII reader. You get a symphony of gauges and data from it. Either go with the ScanGauge II, or the Torque app for Android with a OBD/bluetooth dongle.
Brayarz, I can corroborate. ~120F for idiot light off as well. One thing though which suprised me is that during highway cruising, my coolant temp sits at 177F, whereas on my previous 2003 OBS, it was hovering more around 190F. Bad thermostat, or excessive cooling?
Old 04-10-2012, 07:01 PM   #325
Filthy_Mchaggis
Member#: 275489
2011 2.5i Premium
Does anyone here run an obdII bluetooth and torque pro?
Filthy_Mchaggis is offline   Reply With Quote
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 12:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 02:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 10:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 09:54 PM
