Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-11-2008, 02:42 AM   #26
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
from what i can see by the pictures posted up. the '05 2.5rs intake from injen looks like it'll even work on the 08-09 2.5i's!!!! (since it's been proven to work on the 06-07's, i have one installed.)
Vizzionz is offline   Reply With Quote
Old 12-11-2008, 08:09 AM   #27
WRXbrother
Member#: 141182
96 Impreza Coupe
Good write up. After the holiday season passes and I get closer to auto X season and summer, I'm going to get mine set up.
Thanks for the info.
WRXbrother is offline   Reply With Quote
Old 12-11-2008, 08:13 AM   #28
jordan s
Member#: 122233
1997 Legacy GT
Aspen White 5MT
yea and runs like ****. hence why he made a hybrid.....
jordan s is offline   Reply With Quote
Old 12-11-2008, 02:33 PM   #29
AWD Ninja
Member#: 181980
2006 STi
Originally Posted by Battlesnake99 View Post
actually just found out theyre making a 2005+ 2.5i Cobb Accessport! comign out in February. im stoked.
WAAAA ????? no way ! gimmie the source of this info !
AWD Ninja is offline   Reply With Quote
Old 12-11-2008, 04:03 PM   #30
Battlesnake99
Member#: 163066
08 2.5i sedan
ya I asked Sean S. personally on facebook and he said rallitek and surgeline tuning are working on it and it's due to come out in february.
Battlesnake99 is offline   Reply With Quote
Old 12-11-2008, 04:17 PM   #31
iommichild
Member#: 194990
2008 OBS
Steel Silver/Spark Silver
Hmm...Accessport out in February...tax return shortly thereafter... Timing sounds good to me!
iommichild is offline   Reply With Quote
Old 12-11-2008, 05:17 PM   #32
apexanimal
Member#: 170186
08 Fit
apexanimal is offline   Reply With Quote
Old 12-13-2008, 02:46 PM   #33
cthomasset
Member#: 189435
2008 2.5i
Default 2008 2.5i snorkus/intake silencer
Here are a couple shots of the 2008 snorkus/intake silencer...whatever you want to call it.
Looks like it has changed shape from other photos I have seen.
Yes, I run a K&N. And no, I don't want to talk about it.
cthomasset is offline   Reply With Quote
Old 12-13-2008, 04:50 PM   #34
GrundleJuice
Member#: 165749
is that snorkus a simple shape or does it have channels and ducts inside the outer shell? its hard to tell from the pic... almost looks like a milk jug. just curious what changes were made between 07 and 08. do you have any pics of the rest of the stock intake?
Old 12-13-2008, 05:21 PM   #35
cthomasset
Member#: 189435
2008 2.5i
I actually didn't take it off to inspect it. However, it appears to be be a fancy milk jug.
Old 12-13-2008, 08:53 PM   #36
KingHardcor
Member#: 186952
'08 2.5i
What a rediculously complicated stock intake sytem we have on these things. It's like a maze.
Anyway, in all my reading about intakes, I thought that the hybrid was only supposed to change everything before the filter and leave everythng after alone. Did I get that backwords?
I'm still trying to figure this out but great thread.
KingHardcor is offline   Reply With Quote
Old 12-13-2008, 09:22 PM   #37
KingHardcor
Member#: 186952
'08 2.5i
It looks like I had it backwords and you did it as advised in another thread.
There's a lot of info out on this stuff.
Old 12-13-2008, 09:26 PM   #38
KingHardcor
Member#: 186952
'08 2.5i
I also notice you left off one hose. The one just to the left of the throttle body(as looking at it from the front), with the white plastic thing inline with a grey electrical connection on it. It looks to be a case vent or something?
Any further plans for that?
Old 12-14-2008, 10:01 PM   #39
GrundleJuice
Member#: 165749
That only plugs into the hose on one end. the other end that clips to the "airbox" is just a mount. I looked extensively at mine when doing my intake modifications.
Old 12-14-2008, 11:29 PM   #40
KingHardcor
Member#: 186952
'08 2.5i
Gottcha. Thanks for the info.
Old 12-15-2008, 12:08 AM   #41
TVu1987
Member#: 196698
12 STI
ICE SILVER
man i got a 08 impreza, but i couldn't find any place that sell a cold air intake.
can u help please. =)
TVu1987 is offline   Reply With Quote
Old 12-15-2008, 12:16 PM   #42
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
There really is no place to get them. If you're looking to mod your intake the prevailing opinion thus far is that the hybrid set-up is pretty much the best you can do on these cars. But there's nothing out specifically for the 08's yet, and that's what's being discussed in this thread.
dzrt_hrd is offline   Reply With Quote
Old 12-16-2008, 01:44 AM   #43
tylere
Member#: 175548
2008 Impreza 2.5i
metalic grey
lachute performance is making them i have contacted them and i am going to buy their next shipment . just message them on here and they will tell you about it
tylere is offline   Reply With Quote
Old 12-22-2008, 09:21 PM   #44
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
Mwahaha 08 2.5i with a short ram intake. I used the same intake as cthomasset.
Upon resetting the ecu I experienced some sluggishness at all rpms, exactly as I had after my exhaust was installed. After about 30 minutes of driving these symptoms disappeared and no detrimental effects were felt. I threw a p01707 (bank 1 too lean), but have experienced no knocking. I just reinforced some of the seals with silicone and tightened things up. I'll update with how this helps things.
bcware is offline   Reply With Quote
Old 12-28-2008, 09:47 PM   #45
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
i've done a little more work to the intake and this is the result:
my theory is that because i placed the maf so close to the filter i was getting incorrect readings due to turbulent air. i hacked off most of the final straight section found on the intake and placed it between the maf and filter. the section is a bit larger than it appears because of the presence of rubber couplings on both sides. i am hoping that the straight section of pipe will produce airflow more agreeable with the maf. so far i have reset the ecu and completed 3 power cycles with no check engine light, but it is still too soon to call it fixed.
Old 12-29-2008, 03:48 AM   #46
GrundleJuice
Member#: 165749
that piece of clear tubing that you ran to the homemade port you added is all for nothing. that white plastic thing you hooked the tubing to is not a sensor, its just the bracket that clips the sensor to the factory intake box. if you look in that side you will see that it goes nowhere and you should also notice that it was just clipped on. no seal or anything to make it air tight.
also, you do know that the title of this thread is "DIY hybrid intake" not DIY SRI", right?
Old 12-29-2008, 02:49 PM   #47
CAMG3
Member#: 184738
2008 Outback Sport
Not trying to hack the thread, but does anyone know what the NA Accessport will accomplish?
More power and fuel efficiency?
CAMG3 is offline   Reply With Quote
Old 12-29-2008, 04:45 PM   #48
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
i wasn't going to make my own thread and since it's related i think it's ok.
the white sensor was attached to a black plastic tube which was attached to a black rubber tube which enters the torque box. the stock setup looks as though it would be air-tight. i haven't followed the lines anywhere as i am scrambling for a few minutes just to get everything attached.
what exactly does the white sensor do?
Old 12-29-2008, 05:01 PM   #49
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
you're supposed to keep your stock airbox and snorkus, thats why you're getting bad readings.
Zac86 is offline   Reply With Quote
Old 12-29-2008, 11:16 PM   #50
lawnwrangler
Member#: 198659
2009 imp out sport
sage green metallic
Question '09 Impreza outback sport performance parts
first of all i want to say how great this forum is. there is so much info on it and its awesome how helpful the posts can be. i have been researching for upgrades to my stock '09 impreza, i want to increase horsepower and fuel efficiency if possible. i have found exhaust systems, cold air intakes and ecu chips. nothing is specifically for 2009's. does anyone know if there are specific performance parts for 2009 impreza outback sports? any suggestions for performance parts? any focused direction is very much appreciated. thank you.
lawnwrangler is offline   Reply With Quote
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 01:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 10:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 03:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 11:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 10:54 PM
