Old 01-10-2009, 11:06 AM   #76
Battlesnake99
Member#: 163066
08 2.5i sedan
yeah if it works for 06 it should work for 08, and he says the 06 one should be coming soon-ish...
VIsubi i dont really think you should spend money on an accessport if their kit is supplying a piggyback ecu... just tune it with that. but yes i too am awaiting the arrival of this kit.
Battlesnake99 is offline   Reply With Quote
Old 01-10-2009, 11:37 AM   #77
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
I've been eye-ing it myself for about six months now, so I'm pretty interested in what you find out. I'd pretty much accepted the idea that the piggyback wouldn't work with my 08 and I'd have to figure something else out. I feel like a dog who's ears just perked up...
dzrt_hrd is offline   Reply With Quote
Old 01-10-2009, 11:39 AM   #78
Battlesnake99
Member#: 163066
08 2.5i sedan
well Raptor says they've received significant inquiry for the 08 model. Maybe they'll make a plug-n-play harness thing to connect their ProSequential piggyback to our ECU... lets just wait and see.
Old 01-10-2009, 12:30 PM   #79
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
Honestly I bet their problem with the 08+ is the lack of map data. Once RomRaider adds support for 08/09 5spd to their list I wouldn't doubt it if someone gets the kit and just has their setup installed by a shop to get pro-tuned. Personally I would love to get a super charger kit for my car.
ronoverdrive is offline   Reply With Quote
Old 01-10-2009, 04:15 PM   #80
Battlesnake99
Member#: 163066
08 2.5i sedan
yeah might be cheaper to order the kit without the piggyback and tune via tactrix. personally i bet they can get that piggyback working fine on our cars, and then itll be very simple.
Old 01-10-2009, 05:01 PM   #81
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Originally Posted by tdhardy View Post
Does anyone know if this intake should fit on the 2.2L ej22 N/A engine? I have a 97 Impreza Sport and it's hard to find anything in the way of performance parts for it.
Any of those cheap ebay ones will fit.
Zac86 is offline   Reply With Quote
Old 01-10-2009, 05:11 PM   #82
GrundleJuice
Member#: 165749
I dont think the Factory ECU can compensate for manifold pressures above atmosphere. I think the piggyback ECU is used particularly for that reason.
Old 01-10-2009, 06:17 PM   #83
Battlesnake99
Member#: 163066
08 2.5i sedan
well significantly above atmosphere anyway but yes you might be right. good point. piggyback or bust it is then.
Old 01-10-2009, 11:29 PM   #84
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
Yeah, but how significant are we talking? 3psi? 5psi? 12psi? Last I checked the Raptor Super Charger kit puts out "normal boost" 6psi psi and a "high boost" 9psi model. On earlier bolt-on turbo applications they needed a piggy-back because they couldn't re-tune the stock ECU like the 06+ models can.
Old 01-10-2009, 11:53 PM   #85
jordan s
Member#: 122233
1996 Outback Wagon
Navy Blue 5MT
those supercharger kits cost about the same as a full motor swap.
jordan s is offline   Reply With Quote
Old 01-11-2009, 12:26 AM   #86
bnr34rb26dett
Member#: 188424
2012 640WHP STI
so what size hose barbs/ T connections/ hoses/ clamps do i need to buy?
i want to make sure i have all the parts before the mod
bnr34rb26dett is offline   Reply With Quote
Old 01-11-2009, 01:49 AM   #87
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
Except not everyone is interested in doing an engine swap. Personally I would like to do a supercharger to have something a little different then the norm. Besides, I'm pretty sure just the engine from a 2008 WRX alone would equal the cost of this kit.
Old 01-11-2009, 01:59 AM   #88
GrundleJuice
Member#: 165749
aweee... double post ftl.
Old 01-11-2009, 02:01 AM   #89
GrundleJuice
Member#: 165749
I think were talking 1-2psi depending on barometer readings that day. If local conditions are high press (30.10in Hg for example) then you may exceed the ECU parameters before reaching 1 psi.
Also, keep in mind that the fueling tables are capped @ a load of 1.3g/rev so once you pass that you're ****ed royally without some other way to compute fueling and the other necessary parameters.
Old 01-11-2009, 02:06 AM   #90
jordan s
Member#: 122233
1996 Outback Wagon
Navy Blue 5MT
full motor swap is way more worth the price and will be more reliable than that kit. i wouldn't doubt it if that thing blew your motor. turbocharger>supercharger hence why most cars come with factory turbos and the ones that did come with superchargers now come with turbos instead; cobalt ss, mini cooper s, etc.
Old 01-11-2009, 09:04 AM   #91
Battlesnake99
Member#: 163066
08 2.5i sedan
you sound like you know what youre talking about.
Old 01-11-2009, 01:27 PM   #92
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
I'm pretty sure most people are aware that a turbo will produce more gains, be a similar financial cost, etc. On the other hand, not everybody wants to follow the trend...
And turbo's can be just as risky as what everyone here is discussing. Just yesterday I spoke with an STI owner who's turbo spiked and blew a hole in his engine.
Old 01-11-2009, 01:35 PM   #93
Battlesnake99
Member#: 163066
08 2.5i sedan
youre giving him too much credit dzrt.
turbo > supercharger?
try to explain that one as a ZR1 rips you to shreds.
Old 01-11-2009, 02:08 PM   #94
GrundleJuice
Member#: 165749
guys, turbos and supercharges are not equals s far as comparison. its not apples to apples. both have advantages and disadvantages. Someone should do both... that would be an engine management masterpiece if it were done successfully.
Old 01-11-2009, 02:19 PM   #95
Battlesnake99
Member#: 163066
08 2.5i sedan
obviously im not saying superchargers are always better, but you cant just make a claim like turbochargers > superchargers. its stupid.
About using both, Volkswagon has used both. IIRC, they got a 1.3 litre engine to make 170hp without losing all of its low end torque. pretty impressive stuff.
Old 01-11-2009, 06:47 PM   #96
jordan s
Member#: 122233
1996 Outback Wagon
Navy Blue 5MT
ok so you spend $5 grand on this raptor supercharger kit for your stock motor and it puts out as much power as a stock wrx motor, then you can't tune it to put out anymore power safely. you spend $5 grand on a wrx motor swap and you can tune it to put out way more power reliably. way more practical to do a motor swap.
Old 01-11-2009, 07:31 PM   #97
Battlesnake99
Member#: 163066
08 2.5i sedan
whered you get $5 grand tardo? its $4400 AU, about $2200 US (we dont have to pay this one tax which helps)
so its $2200 for a really easy to install kit which gives you similar hp to a stock wrx and more torque. so whats really more practical?
Old 01-12-2009, 12:16 AM   #98
jordan s
Member#: 122233
1996 Outback Wagon
Navy Blue 5MT
my bad i thought it was $4400US plus shipping and tax so about $5 grand.
also, $4400AU~$3,000US
Old 01-12-2009, 07:58 AM   #99
obs2008
Member#: 163068
08 outback sport
thats such a good price, i want one. you guys ever see the supercharger kit that subaru developed a while back? now that thing is nice!
obs2008 is offline   Reply With Quote
Old 01-12-2009, 03:18 PM   #100
Battlesnake99
Member#: 163066
08 2.5i sedan
Jordan, I can direct you to the Raptor Superchargers guy (Tradewind over at RS25) if you dont believe me. He said $2200 or $2500 i cant remember. Either way much less than $3k.
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 12:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 02:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 10:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 09:54 PM
