Old 03-09-2009, 08:19 PM   #151
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Originally Posted by bcware View Post
I really think all of that is overkill, but I won't say it's impossible that something could go wrong. I've driven over 100,000 n/a untuned bolt-on miles in two different cars and never had an issue. I have also never heard of anyone damaging their engine with intake/header/exhaust. Is this a subaru thing?
I only say MAFv table rescaling is necessary because in a MAF based vehicle, anytime you change the intake in any way (especially increasing the diameter of the pipe) you will affect fueling. weather its enough to do damage all depends of the specific scenario. if you are running lean due to an intake and you lose a vac line or a gasket, you will be even more lean. and its easily possible to be lean enough to do damage. Not to mention all the power you leave on the table.
Old 03-09-2009, 08:25 PM   #152
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
That's a good point.
bcware is offline   Reply With Quote
Old 03-10-2009, 06:26 PM   #153
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
I noticed when I was installing this that the most it did to change the setup on my 08 was to replace the torque box and the rubber tubing with smooth piping. It really didn't change the diameter of the pipe, at least not the piece between the airbox and the torque box.
I tried another experiment before I did this mod. I replaced that rubber tube between the boxes with a pipe that had a smooth interior. Then I replaced the torque box with this hybrid setup, and it wasn't till then that I actually noticed some gains, mainly in low end...
Am I missing anything? I'm blond so if I'm being a nube that's why...
dzrt_hrd is offline   Reply With Quote
Old 03-13-2009, 05:05 PM   #154
tylere
Member#: 175548
2008 Impreza 2.5i
metalic grey
i have a question what will i get more perfromance from. this or a cai? thanks
tylere is offline   Reply With Quote
Old 03-15-2009, 10:32 PM   #155
element4859
Member#: 205738
2008 Impreza 2.5i 5d
Dark grey metallic
Originally Posted by TVu1987 View Post
man i got a 08 impreza, but i couldn't find any place that sell a cold air intake.
can u help please. =)
www.Cosmoracing.com
element4859 is offline   Reply With Quote
Old 03-15-2009, 11:47 PM   #156
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
i have an answer you should learn to use proper grammar and read the first post.
iyzmi is offline   Reply With Quote
Old 03-16-2009, 01:08 AM   #157
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Upon resetting the ecu I experienced some sluggishness at all rpms, exactly as I had after my exhaust was installed. After about 30 minutes of driving these symptoms disappeared and no detrimental effects were felt. I threw a p01707 (bank 1 too lean), but have experienced no knocking. I just reinforced some of the seals with silicone and tightened things up. I'll update with how this helps things.
You do realize your short ram is a bad idea, right? The codes are an example of that. They throw a code once they peg 20%. If your adjustments to the intake pulled that down to 19.9%, you won't get a CEL but you'll still have a problem.
Also, you have no way of knowing wither or not you're knocking. Unless your 08 is staggeringly different from the 06-07 (and it's not), you're knocking like a mofo.
Originally Posted by CAMG3 View Post
Not trying to hack the thread, but does anyone know what the NA Accessport will accomplish?
More power and fuel efficiency?
Don't threadjack
And the AP won't do anything the open source tools can't and the AP will cost hundreds more.
Originally Posted by lawnwrangler View Post
first of all i want to say how great this forum is. there is so much info on it and its awesome how helpful the posts can be. i have been researching for upgrades to my stock '09 impreza, i want to increase horsepower and fuel efficiency if possible. i have found exhaust systems, cold air intakes and ecu chips. nothing is specifically for 2009's. does anyone know if there are specific performance parts for 2009 impreza outback sports? any suggestions for performance parts? any focused direction is very much appreciated. thank you.
Don't threadjack.
Old 04-05-2009, 09:02 PM   #158
skiley22
Member#: 188750
2008 Impreza 2.5i
Lightning Red
The link to the original poster's intake seems to be broken..anywhere else to buy this from?
skiley22 is offline   Reply With Quote
Old 04-06-2009, 03:13 AM   #159
gshabanov
Member#: 201478
2008 Impreza 2.5i
I'll sell it you mine if you pay for shipping and stuff.
Or you can go to autoparts store that link points to and look for a 1997 i think subaru impreza intake.
But PM me if your interested I took mine off. Cause it made things worse.
Just FYI.
gshabanov is offline   Reply With Quote
Old 04-06-2009, 04:10 PM   #160
cthomasset
Member#: 189435
2008 2.5i
I received some communication about the intake no longer being available at that online store. Dang! It was perfect!
Here is the info for the intake.
1998-2001 Subaru Impreza - Kool Vue Cold Air Intake
P/N KV4801073
If anybody finds a source for this intake, PM me so I can update the instructions.
cthomasset is offline   Reply With Quote
Old 04-14-2009, 03:55 AM   #161
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
P/N KV4801073
Check this one out: http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
not too bad for 15$ (shipping cost more than the part itself haha)
NorthBayResident is offline   Reply With Quote
Old 04-14-2009, 09:27 AM   #162
cthomasset
Member#: 189435
2008 2.5i
Thats close. Looks just like the ebay intake I first tried. It will work, it just takes another hack to get there.
Old 04-15-2009, 12:34 AM   #163
gshabanov
Member#: 201478
2008 Impreza 2.5i
that pipe looks so beat up why is it covered in dings ?
Old 04-15-2009, 01:10 AM   #164
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
Probably a mixture of fantastic marketing and superior welding skills.
Old 04-15-2009, 01:32 AM   #165
skiley22
Member#: 188750
2008 Impreza 2.5i
Lightning Red
$15..with $20 shipping, that must be a heavy intake :/
Old 04-15-2009, 04:12 AM   #166
jabdalla
Member#: 208644
2010 WRX Wagon
So, have we decided this is no longer a good upgrade? Unless you remap the MAF? I'm sorry if I missed it, but could someone post some very clean cut instructions on how to accomplish this (programs, cables, directions, etc.). I'm just lost with the argument over what program to use.
jabdalla is offline   Reply With Quote
Old 04-20-2009, 12:42 AM   #167
aurtini
Member#: 205655
2006 Impreza 2.5i
I successfully installed this hybrid intake in my '06 2.5i. The install was pretty smooth, considering this was my first attempt at doing any kind of modification of my car; I figured it was a good way to cut my teeth and learn the ropes, both mechanical and ECU-ical
After rescaling my MAFv everything seemed to be running pretty smoothly; I noticed a little knock in first gear at low engine speed when starting to move from a stop from the knock sum and it sounded great. My only complaint was that I would hit some resonant frequency of intake and it would rattle against a bracket on my firewall since the install on an '06 was pretty tight. After more forum prowling and tons of reading I made a couple of road dyno power/torque graphs that show (providing my data is correct) that I was losing torque and horsepower with the hybrid intake compared to the stock setup. I have a post for that, with data, in the works (got to get to my 3 legit reply limit first, since I'm a newbie).
aurtini is offline   Reply With Quote
Old 04-20-2009, 12:51 AM   #168
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'll be interested to see your data as you're the first person out of probably 75 now that has seen any losses at all.
Old 04-20-2009, 01:25 PM   #169
obs2008
Member#: 163068
08 outback sport
i did this on my 08 and took it off after a few weeks. just lacked low end power and wasnt as nice to drive over all. my only other engine mods are kartboy crank pulley and avo panel filter. nice black painted hybrid intake for sale
obs2008 is offline   Reply With Quote
Old 04-20-2009, 01:41 PM   #170
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Interesting... that may suck for you 08 guys. If a CAI/SRI won't work because of resonance, and a hybrid won't work for some other reason, you guys just may be plain old screwed.
Old 04-20-2009, 07:12 PM   #171
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Since when does kartboy make crank pulleys?
Old 04-20-2009, 09:51 PM   #172
littlec
Member#: 208934
09 2.5i
That makes me a sad panda. I've been doing a good bit of research on this and was thinking of making it also my first mod. I guess I'll wait a bit until someone posts up some data. I'll let the data do the talking
littlec is offline   Reply With Quote
Old 04-21-2009, 10:44 AM   #173
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Would it be because of their stupid lean conditions?
formula91 is offline   Reply With Quote
Old 06-07-2009, 02:52 PM   #174
iorndorff
Member#: 209908
2009 2.5i
Has anyone actually made this one work? I'm trying to find the best option for a hybrid intake.
iorndorff is offline   Reply With Quote
Old 06-08-2009, 06:13 AM   #175
imprezachiang
Member#: 180311
2008 2.5i Sedan
Obsidian Black Pearl
cosmoracing model does not come with carb legal sticker :-\
imprezachiang is offline   Reply With Quote
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 12:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 02:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 10:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 09:54 PM
