Old 12-08-2008, 11:17 PM   #1
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question using an 04 STi alternator on an EJ20G?
Since I'm an electrical newb can anyone assist me in using the new alternator I purchased on my EJ20g?
As with most Subies the dimensions are identical but the MY04 alt. has a 3 wire plug whereas my car has a 2 wire plug.
TIA,
-Mike.
EDIT:I know I can buy a used one that fits but got a deal on a brand new one so I want to make it work (even if it means sourcing the correct connector used) Just need to know how the wiring can be adapted to work.
mpaone is offline   Reply With Quote
Old 12-09-2008, 02:48 AM   #2
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
Iran into the sme problem when swapping a early 90's ej20g into my 94 ej22t legacy. so I used the legacy's one (evin though the jap one was better) cause that harness has an extra wire in it! maybe it's not nessary but I did'nt want to mess around!! maybe the american comps need an extra hot to let know it is operating?????/ so find out were the extra one goe's!!
going to see my alternator, starter guy tomorrow! so maybe he can answer that one!
94 GT is offline   Reply With Quote
Old 12-09-2008, 09:11 AM   #3
mpaone
Member#: 3
2012 Geeteeeye
Lightbulb
Cool thanks.
The label on my old one shows what looks like the plug and the letters S L (left to right with the clip on top), where the new one show S L C. I assume that means L is ground, S is power but gotta figure out what C is.
-Mike.
Old 12-09-2008, 12:48 PM   #4
kingsubi
Member#: 19239
2011 WRX
04 sti alternator:
1.Blue goes to ECU
2.Blue/red goes to main fuses
3.Black/white goes to cluster
2-wire alternator:
1.Black/red goes to cluster
2.White goes to main fuse box
edit: I am guessing you don't have the pigtail..
Sti 3-wire is 1 2 3 with tab at top, 2-wire is 1 2 with tab on top
kingsubi is offline   Reply With Quote
Old 12-09-2008, 01:18 PM   #5
mpaone
Member#: 3
2012 Geeteeeye
Originally Posted by kingsubi View Post
04 sti alternator:
1.Blue goes to ECU
2-wire alternator:
Thanks! Actually trying to buy the pigtail used as we speak so it will look cleaner. I assume since the stock one does not need an ECU out I can just wire it into the fuse box? So with the pigtail, blue and blue/red to fuses and black white to cluster.
-Mike.
Old 12-09-2008, 03:58 PM   #6
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Don't put the blue wire to the fuse box, leave it open.
Arctic Assassian is offline   Reply With Quote
Old 12-09-2008, 04:37 PM   #7
mpaone
Member#: 3
2012 Geeteeeye
Thumbs up
Ah, OK thanks. Prob a switch.
-Mike.
Old 12-10-2008, 09:22 AM   #8
mpaone
Member#: 3
2012 Geeteeeye
04 sti alternator:
1.Blue goes to ECU
2-wire alternator:
Just a small change to what what provided above...
The 2 pin connector on mine is:
1.White goes to main fuse box
2.Black/red goes to cluster
This is if you are looking at the back of the connector while it's plugged in, tab on top.
-Mike.
Old 12-11-2008, 08:56 AM   #9
mpaone
Member#: 3
2012 Geeteeeye
For anyone looking for the 3 plug connector, here you go.
http://www.cpgenerator.com/repairplugs.html
The one at the top of the page looks to be identical to the Subaru plug so I ordered one today.
-Mike.
Used V1 from an 04 STi work on my 05 STi? ConcentualInduction AccessPort 4 05-08-2011 10:10 PM
Newb Q: Blox Lugs fit okay onto 04 STI wheels on an 04 wrx? Strider327 Tire & Wheel 6 02-16-2010 10:08 PM
04 sti bumper on an 04 wagon mbscooby129 Interior & Exterior Modification 16 04-30-2009 10:24 AM
How hard to get an 04 STI Exhausto on a 04 RS... GREGS2point5 Normally Aspirated Powertrain 10 02-02-2006 06:26 AM
Who's installed an 04 STi wing on a non-STi? Jabzilla Interior & Exterior Modification 17 10-28-2003 04:30 PM
