Old 12-08-2008, 11:25 PM   #1
slayers_x
Member#: 101220
MY05 imprezaRS
riding on open diff
Default Engine Hoses
I have about 118,xxx miles on my MY05 Impreza 2.5RS. I know that my 120,000 mile maintenance is coming up. I don't know if this is necessary true but do the engine hoses do they need to be replace?
I heard someone saying that age through mileage rather than years like 10+. I drive alot enough to accumulate 118,xxx miles within three years. I bought the car brand new in March 2005 and it's December 2008. Not even four year with this much mileage.
So is there a time when I should replace and do you guys suggest any places to replace such as Autozone, Pepboys, or should I go to the dealer and get OEM hoses?
I'm willing to spend the extra money and go to dealer if need be.
I tried searching around a bit but I'm guessing I'm not using the correct keyword or such.
http://forums.nasioc.com/forums/sear...archid=3467856
slayers_x is offline   Reply With Quote
Old 12-09-2008, 04:48 AM   #2
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Just replace if you find any cracks and leaks. For an 05, you should still be good. If the technician at the dealer recommends something then consider it.
EdHilario is offline   Reply With Quote
Old 12-09-2008, 01:09 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
heat cycles also play a part in wear and tear. I don't think there's anything wrong with other brands of hoses. I have napa upper and lower radiator hoses on mine for a while and have not had any problems.
Old 12-09-2008, 08:54 PM   #4
slayers_x
Member#: 101220
MY05 imprezaRS
riding on open diff
Well all the hoses look fine to me even with that much mileage and all the heat cycles it goes through. I keep my engine bay clean too. So should I just REPLACE the hoses if only IF there is any leaks or cracks rather than the mileage and continuous heat cycles it goes through?
I do a lot of spirited driving in the canyons too. At the moment there is nothing wrong with my hoses and just want to take a precaution if need be and extend the lifespan of my motor since I do alot of driving in California.
Old 12-10-2008, 03:42 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
it doesn't hurt to replace them. they're only 10...20 dollars? seems pretty good insurance to me, especially since you don't want them bursting at inopportune times.
oh, and you can also squeeze them. I forget if you should do it hot or cold, or if it matters. search on it.
Old 12-10-2008, 04:09 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
cheap insurance
Old 12-11-2008, 09:56 PM   #7
Ekeenan86
Member#: 155493
1999 Legacy Outback
I agree, take the opportunity to change your hoses, thermostat, and flush the radiator. You do it now and you won't have to worry about it for a very long time. And its the insurance of knowing you're safe. The japanese use preventive maintenance on their machinary; helps reduce breakdowns and ensures continuous operation. Unfortuantely the american car manufactures haven't figured that one out.
Ekeenan86 is offline   Reply With Quote
Old 12-12-2008, 12:40 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by Uncle Scotty View Post
cheap insurance
Agreed. If you have almost 120K miles, & you have never changed any hoses, you should do it now before something goes wrong @ the wrong time.
There is damage you see and damage you don't see. Just becuase it doesn't looked cracked does not mean you won;t have a failure sooner than you think
Samurai Jack is offline   Reply With Quote
FS: NoVA: Samco Radiator Hoses in Black and 4 No Tear Clamps for 02-07 WRX / STi. adjasont Engine/Power/Exhaust 5 11-27-2011 03:06 PM
FS: TXS FMIC, BOV, WL sways, camber plates, stock parts, brake hoses, more benton0311 MAIC Private Classifieds 21 06-12-2010 07:54 PM
Blue engine hoses and belts? BBQdDude Interior & Exterior Modification 16 04-10-2009 02:25 PM
Braided hoses for engines Bonsaimaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-13-2002 08:17 PM
engine bay hose diameters? efoo Technical Forum Archive 1 07-18-2000 09:55 AM
