Vancouver Impreza Club
Old 12-22-2008, 08:40 PM   #26
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Rad fan hooked up, tach hooked up, fixed a leak in the power steering, coolant system mostly complete (no heater core in right now. brrr.), all lights hooked back up.
I've got an appointment at a shop on Monday to get the new intercooler piping made, then it's time to tune!
Splinter is offline   Reply With Quote
Old 12-23-2008, 12:55 AM   #27
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Looks like it's gonna be a fun car to drive. What turbo are you running at the moment? Think it can handle anti-lag?
alcoolaid is offline   Reply With Quote
Old 12-23-2008, 01:03 AM   #28
Brisky
Member#: 148078
2001 Legacy GT
Birch White
That's one hell of a shop you have there friend....
But I like with where this seems to be going...
I will keep stopping by to check on your progress...
Brisky is offline   Reply With Quote
Old 12-23-2008, 03:34 AM   #29
Scott_2.5TS
Member#: 163806
where's the widebody?
Scott_2.5TS is offline   Reply With Quote
Old 12-23-2008, 03:50 AM   #30
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
In imagination land until it gets into the shop in february
Old 12-23-2008, 03:53 AM   #31
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
TD06H-20G... Probably could handle antilag for a while, but I dont really think it has that much benefit to be worth the cost.
Yea, and to make it worse it's not even mine. Getting booted out. Hopefully I'll be able to use it from time to time still.
Old 01-18-2009, 10:32 PM   #32
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Updates on first post!
Old 01-19-2009, 01:14 AM   #33
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
rediculous. i thought i had some wide wheels. its kinda funny because i test fit my 18x9.5 +38 On Jockey_girls GC and it didnt stick out nearly that much.
Loomin is offline   Reply With Quote
Old 01-19-2009, 01:35 AM   #34
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Keep in mind I've also got GD suspension under there, so that increases my track by almost an inch on each side. The wheels are also +25, so that's another half an inch. 1 inch + .5 in + .5 in wider wheels = 2 inches total extra.
Old 01-19-2009, 01:55 AM   #35
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Wow, the 6 speed looks ridiculously huge next to the 5 speed
Old 01-19-2009, 02:30 AM   #36
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
yessir. i have a pic like that in my swap thread
Old 01-19-2009, 11:50 PM   #37
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
More updates
Old 01-20-2009, 08:45 PM   #38
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Ordered some ARP extended lugs today, damn those things aren't cheap.
Necessary tho :/
Old 01-21-2009, 10:22 PM   #39
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
No new pics but the suspension swap is done, still have to set everything to spec but I'm not going to do that until I've got the tires on the wheels so I can align it.
Almost entirely a bolt-on affair, pretty stoked about that. Surprised more people don't do this... My wheelbase just increased from 57.4 inches to 58.9. An inch and a half is a pretty considerable gain! Not to mention the added stiffness of the aluminum control arms and lateral links over the cheesy RS steel pieces.
Tomorrow I'm going to finish stripping out the diff and hook up the e-brake cables, then start tearing into the motor to get the shiny new rods in there. I want everything ready to drop in when the car gets back from the body shop.
Old 01-22-2009, 02:47 AM   #40
Scott_2.5TS
Member#: 163806
When will this be on the road?
Old 01-22-2009, 09:17 AM   #41
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Mid march is the plan
Old 01-24-2009, 07:09 PM   #42
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Tires get here monday or tuesday, so I can get those mounted and do a quick alignment.
First page updated.
Old 01-25-2009, 01:13 AM   #43
alcoolaid
Member#: 134949
'07 SWP STi
Originally Posted by Splinter View Post
Yeck, I need to learn how to weld better.
I'm running the 05 STI crossmember and steering rack, which has different splines than the stock RS, so I had to chop both knuckles in half and swap ends. Using two extremely long steel bars I couldn't break the welds, so hopefully they'll hold. I'm going to pull it off after a few weeks and inspect it for any cracks.
Yikes, I'd be scared driving
Old 01-25-2009, 01:29 AM   #44
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
haha well I ground a fairly large V-grove between the two halves >< like that, then ran my welder at high amperage with a low wire speed and filled in the gap. It's ugly, but I think it'll hold.
Old 01-25-2009, 12:12 PM   #45
onur
Member#: 99005
that's one piece you don't want to be messing around with Steve..
onur is offline   Reply With Quote
Old 01-25-2009, 06:11 PM   #46
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Think I should grind it out and run another bead through it just to be sure?
Old 01-25-2009, 08:01 PM   #47
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
I'd say so...
007WRX is offline   Reply With Quote
Old 01-26-2009, 01:37 AM   #48
andys
Member#: 53455
2004 Forester XTI-RR
dark
You 'hope'?! Oh man. DON'T learn to weld on your steering shaft. Get this PROFESSIONALLY done!!
It's your steering....... and i could be coming the other way....
andys is offline   Reply With Quote
Old 01-26-2009, 01:38 AM   #49
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
****ing LOAD it with weld. make sure you dont spray water on it either.... let it cool down on its own. you really dont want to harden that piece of metal. haha imagine if it broke..... youd be ****ed.
Old 01-26-2009, 01:44 AM   #50
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
lol ok you guys have convinced me.
I'll grind it back down and take it to a shop.
22B for sale sleepysubie Rocky Mountains Impreza Club Forum -- RMIC 8 06-08-2010 08:06 PM
This kid will grow up to be either a serial killer or a serial killer. Cole Off-Topic 37 10-03-2008 05:33 PM
22b front bumper with grill, 22b side skirts, 22b rear bumper, and Cwest front bumper D Spec Dc2 Private 'For Sale' Classifieds 51 05-17-2005 06:20 PM
Looking for killer bass at a killer price? wrxplaya11 Car Audio, Video & Security 1 01-07-2004 10:10 AM
('93-'01) ANOTHER 22b spotted!!! How many 22b is ther world wide!?!?! limited ? gerardchau Impreza Forum 23 08-07-2001 02:27 AM
