#1 |
Member#: 147940
BAIC
Vehicle:2002 WRX WRB |
Just got my 16g WRX tuned at GST today! very happy with the results! Thanks Mike and Greg.
271whp/245tq on a mustang dyno. not bad ![]() Just thought I'd like to share it with everyone. especially since theres not too much on standard 16g turbos. The tune is super smooth and runs great! Nothing jaw-dropping, just a dailydriver/autoX car. here's the engine mods: Cobb AP V.2 FP16g turbo DeatschWerks 650cc Injectors Walbro 255lph Fuel Pump Helix TMIC Cobb SF Intake GodSpeed Turbo Inlet Helix Catless DP Helix Catless Up SubieSport Lightweight Pulleys Gruppe-S BCS HKS SSQV BOV Dyno Sheet ![]() AFR Sheet ![]() Feel free to give feedback or ask questions. Brandon F.
#2 |
Member#: 192848
South East
Vehicle:1998 GC8 rsti BDP |
NICE numbers man. Big 16G or what kind of 16g..ebay? deadbolt...ect...
#3 |
Member#: 192848
South East
Dammit i just read FP, my bad bro. NICE NUMBERSSSS
#4 |
Member#: 147940
BAIC
yup. just a little ol' standard FP16g!
#5 |
Trust me, I'm a scientist
Moderator Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
Nice!! When do you see full boost? What is full boost on that setup, and what kind of fuel? Also, looks like you might be getting just a tiny bit of clutch slippage at 4k. Stock clutch?
#6 |
Member#: 152680
Vehicle:2002 ej22t 2.35 s363 surged aem ems 6spd wagon |
Nice clean pull out to 7k.. looks very good.
#7 |
SCIC
Every VF39 owner should see that beauty that is 5500-7k
#8 |
Member#: 167879
South East
Vehicle:2005 Impreza midnight blue |
nice number for the standard 16G
. how much boost are you running on it?![]() i had the Evo3 big 16g and made 325whp at 26 psi on a mustang dyno. ![]() |
#9 |
Member#: 165025
Any tranny work done?
#10 |
Member#: 170747
BAIC
Vehicle:2004 WRX Wagon PSM |
Curious to know how much boost you're running too.
I just did a standard 16g swap too (DB turbo though) with a Clark Turner map, but I was thinking about having it tuned @ GST since they're down the road from me. I've been pretty blown away with the top end power of the 16g. It's a nice compromise to have similar spool to the TD04 with a lot more top end. |
#11 |
Member#: 147940
BAIC
03wrx-wrb:wow.. 26psi is quite a bit. stock block? meth?
and sorry, 91oct. boost= 19psi tapered to 17psi. tranny is JDM STi RA gearset(cryo'd) with ACT street clutch. and i need a new clutch soon too. |
#12 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
catless in california?? ballsy!
nice, bet shes fun to drive w/ those jdm sti ra gears 2Liters rule! |
#13 |
Member#: 140575
Vehicle:2005 Legacy GT sedan |
Very nice... on a Mustang dyno too!
A lot of people write off the regular 16G, often missing the fact that not only is it affordable, if offers comparable spool and better cfm output than even the much vaunted VF34. The icing on the cake is that it's rebuildable and can be upgraded to a larger variant down the road if needed. Great choice on injectors, too. A lot of people run pinks with that turbo, but I've always thought they were running the risk of pushing it in terms of IDCs. I have the same injectors, and they've been great so far. It also gives you some headroom if you decide to upgrade the turbo later. Any idea what your injector duty cycles are? I'm on the lowish side with 650s and a DB 16G- right at 70%. If you don't mind me asking, what is your target boost? That's a solid curve you've got there... I'm interested to see if you are pushing over 20 psi. I'm running 19, but am thinking about having it upped once I get some proper gauges to let me closely monitor things once I start really pushing it. Sorry about all the questions; just curious. |
#14 |
Member#: 147940
BAIC
Thank you.
i agree! very overlooked turbo. and love the fact that FP's are rebuildable. chose the 650's for future plans of an 18g. plus its nice to have headroom. peak boost is 19psi tapered to 17psi. and believe injector duty is similar. Brandon F. |
#15 | |
Member#: 192628
Vehicle:2004 Subaru WRX Java Black Pearl |
Ive been considering the dp big 16g and those injectors. I know i will talk to my tuner closer to then, but do you think deatschwerks 650s would be large enough for the db big 16g? |
#16 |
Member#: 152680
Yes, the 650's will flow enough for any of the 16g's unless your on E85
#17 |
Member#: 56345
Vehicle:93 Swapped L Green |
Seems kinda rich to me.
Good showing for a much more durable turbo than anything in the VF series. I'm not sure why the TDO516G is compared to the VF3X turbos when it's much similar in size to the VF22. Studies show that for some apparent reason 57% of all NASIOC users with upgraded turbos want to suck any "VF" turbo's dick. |
#18 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
nice numbers..
but afr are abit rich..they are close to what a stock setup would do as far as afr's. if they leaned the afr's 11.5 to 11 you could have gotten some more power & still stayed on the safe side. |
#19 |
Member#: 195511
Seems pretty good, nice run!
#20 |
Member#: 78074
Vehicle:2005 STi Aspen White |
are you running the stock catback? it just says up pipe and dp
#21 |
Member#: 147940
BAIC
not stock catback, some no-name 3" catback
#22 | |
Member#: 172027
Vehicle:2006 cgm wagon 290whp 343wtq |
![]() nice power curves, I've gotta say that the 16G is a much better match with the 2l than the 2.5. My boost falls OFF at 5500-6000, but the initial torque just smacks me in the face |
#23 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
Looks great!! I have the same gears, and turbo on my 2.0l and its a GREAT combination. Only thing that you may run into is the short RA 4th gear at the drag strip if you start trapping over 110mph.. (hey its possible).
Nice tune though, enjoy it! |
#24 | |
Member#: 140575
The above being said, within the next year I am considering sending the turbo back in for upgrade to a "Super 16G," as acceleration over 65 or 70 does take a dive. I wouldn't mind trading a little low end for a bit more top end pull. Since I'm running a stock gear box I haven't bothered to take my car to a strip, but I'd like to do it just once before I go larger so I would have a concrete basis for comparison. Rambling aside, as was mentioned, those injectors should be great for ANY size 16G, and based on what I've seen, will even do well in a basic 18G setup. If you know what your power goals are, you can always refer to this calculator to determine how much injector you need. http://www.deatschwerks.com/catalog/...alculators.php For a WRX, I *think* it is generally recommended to use a BSFC of .59. Once you have your injectors figured out, you can choose your turbo from there. You may already know this, but I'm throwing the info out there just in case. For comparison sake, here was my thread from a while back using a standard 16G: http://forums.nasioc.com/forums/show...t=J.+Steinbeck On the dyno my car spooled hard and early, but some people pointed out that I may be dropping a little more torque toward redline than I should, and I had a little dip at 5,000 rpm that might be the result of some pulled timing. Not sure what the case was, but the car still feels great, and after getting a fairly knowledgeable person to log since then, it appeared that the car is happy. I do wish my curve was as linear as the OPs, though. My numbers are higher, but I was on a Dynojet. I bet we would pull similar peak numbers on the same dyno... he might even push a little higher than me. I don't mean to get off topic; I thought it would be nice to throw some of these results together since it does seems like it is hard to find info on this board from other "regular" 16G users. Last edited by J. Steinbeck; 12-11-2008 at 10:01 AM. |
#25 | ||
Member#: 101880
SCIC
Vehicle:2012 Mustang GT |
These two posts have really got me leaning towards a Evo3 16g now once again. 26 psi making 326whp on a mustang? That's golden numbers right there. Any kind of special fuel that goes with that? |
| Thread Tools | |
| Display Modes | |
| Well I got my 06 WRX STi today... | maximo | Newbies & FAQs | 3 | 07-22-2007 11:59 PM |
| Got my 05 WRX Wagon today!! | kriald | General Community | 9 | 08-28-2004 06:24 PM |
| Got my '02 WRX today... Got a question about what the dealer said... | WRX-ZJ | Newbies & FAQs | 13 | 08-04-2002 02:16 PM |
| Got my JDM conversion dyno'd yesterday | annointed | Factory 2.0L Turbo Powertrain | 8 | 05-16-2002 12:28 AM |
| Got my new WRX today!!! | dandbest | Tri-State Area Forum | 8 | 10-09-2001 05:27 PM |
