Old 12-10-2008, 01:52 AM   #1
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Default 95 OBS Gas and no go?
I am looking to buy a 95 impreza wagon but the owner of it says it starts up fine and idles fine but when the gas is applied the car does not move. Anyone know for sure what would be causing this?
It sounds to me that it could be the throttle cable, or a fuel problem. I would like to know what I am up against before I descide to buy it so your help ASAP! would be much appreciated. Thanks, Dan
Suby<3777 is offline   Reply With Quote
Old 12-10-2008, 02:02 AM   #2
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
check the fuel filter it might be clogged, check the throttle cable if its loose.
HighRevimpreza is offline   Reply With Quote
Old 12-10-2008, 02:19 AM   #3
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Yah, that could be it. The car is about an 8 hour drive away so I would like to bring as many parts it could be as possible to make sure I cover all angles. Anything else it could be?
Old 12-10-2008, 02:33 AM   #4
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
does it have the intake box?
Old 12-10-2008, 03:02 AM   #5
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Not sure, have not seen the car yet. Why?
Old 12-10-2008, 01:52 PM   #6
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
to much air will choke the motor and it will run very lean and it will die out
Old 12-10-2008, 02:26 PM   #7
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
Doesnt move as wont move in gear?? or wont rev up when open up? id bring a can of starter fluid, to check for intake vaccum leaks. if its in gear and wont move, if its an auto, maybe a good band tightening job, or stick maybe throw out bearing, or clutch? isit throwing any codes do you know?
rivman05 is offline   Reply With Quote
Old 12-10-2008, 03:34 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
it's hard enough to diagnose a car thru the internet when you have it, it's even harder when you yourself haven't even seen the car. according to your first sentence, i would take off the parking brake.
Old 12-11-2008, 03:15 AM   #9
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
I am sure the owner is no that stupid. Like I said just wanted to get a few ideas of what it could be before I make an 8hour drive to look at it. Want to try and fix it if I do by it. Sounds like it could be a simple fix and the owner just does not know jack about cars. So we will see.
Old 11-16-2009, 12:04 AM   #10
dgsblb2
Member#: 197278
1999 Lifted OBS
Just curious as to what happened. To me, it sounds like the transmission's forward drives are shot.
dgsblb2 is offline   Reply With Quote
Old 11-16-2009, 01:32 AM   #11
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
I never bought the car so never found out. Bought a 99 impreza L instead
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
FREE: 95 OBS 1.8L Motor and Gearbox gongeuzler NWIC Private Classifieds 4 10-16-2007 01:25 PM
Spiders, gas and no clothes don't mix. HoRo1 Off-Topic 9 04-02-2006 09:40 PM
Some Show and No Go.. Nightstar Member's Car Gallery 55 10-19-2005 06:29 PM
HELP!! Give it gas but car has no go! Sobelizard109 Service & Maintenance 3 05-10-2003 01:49 AM
