Old 12-10-2008, 01:06 PM   #1
Mike_Subaru
Member#: 189378
Default Split Gas Tank Issue
Hi,
I have an 1998 AWD Imprezza with a split gas tank. If I understand correctly, the pump side of the tank pumps fuel to the motor, and the return line, feeds into a Venturi Jet module in the tank. The pick-up tube from the second 1/2 of the gas tank is also fed to this Jet Module.
Issue is, I can only use 10 gallons of fuel before the 16 gallon tank is on empty. Cruise range is about 280 miles before the needle is on empty. I assume the secondary "Venturie Jet" system is not working, returning the fuel to the pump side of the tank.
What are the common issues with this set up? Cracked Rubber lines? Pluged up screen Filter? I had this issue before on a 95 wagon, and the dealership fixed it under warrenty.
Any ideas?
Thanks In advance for your help.
Mike_Subaru is offline   Reply With Quote
Old 12-11-2008, 01:05 PM   #2
ZOMG.STi
Member#: 191857
RIP Matthew Denice
'05 2.5RS / '03 S2K
I honestly have no idea, and low mpgs suck, so free bump.
Hope you get it figured out
ZOMG.STi is offline   Reply With Quote
FS: 2.5RS Gas tank with filler neck! perfect for smaller L tanks! scobaru MWSOC Private Classifieds 3 01-21-2007 07:56 PM
FS: 2.5RS Gas tank with filler neck! perfect for smaller L tanks! scobaru Drivetrain 0 01-18-2007 03:25 PM
2006 Impreza gas tank fill - fuel tank filler neck problems. Psybin Warranty Issues & SOA Problems 11 01-08-2007 09:48 PM
Anyone wanna help out with my gas tank issues tomorrow? oct 11th at phils shop scobaru Mid West Subaru Owners Club Forum -- MWSOC 6 10-11-2005 01:06 AM
RS gas tank issues in a 94L scobaru Subaru Conversions 1 10-09-2005 04:27 PM
