#1 |
Member Sales Rating: (25)
Member#: 87629
BAIC
Vehicle:05 6spd LGT |
link to pics here:
http://forums.nasioc.com/forums/show....php?t=1643978 custom 627 lb. springs for kw v3s- front and rear with required helper springs for the rear and custom rear tops to run a linear spring. great upgrade if you are tracking/autoxing/just like a non-progressive rear spring. used for about 1000 miles. $150 + shipping thanks ben
#10 |
Member Sales Rating: (24)
Member#: 81659
NWIC
Vehicle:2010 Fozzy XT Ice Silver Metallic |
So you have two sets of the 600lb springs? I was a little confused by the pictures. Intrested in just one set of 600lb springs
#11 |
Member Sales Rating: (17)
Member#: 50319
NESIC
Vehicle:2006 STI |
Can you please confirm the spring diameter and length? Just curious if they'll work with my RCE T2's.
I'm in CT and could pick up. |
#12 |
Member#: 87629
BAIC
token, I have a full set (f+r) of the stiffer springs and the necessary helper springs/tops/top mounts to run them in the rear.
viking, I will pm myles at rce right now and see what he thinks, although I don;t think the springs are interchangeable between the v3s and the t2s. i'll take some measurements when I am home. |
#13 |
Member#: 87629
BAIC
viking, here is the response I got from andy@rce
The springs should fit, The spring rates as well as the free length of the springs may be very different, however. For instance a 70-100 and a 70-140 may have the same spring rate, but will behave differently and give different ride heights. Obviously these spring rates would not be matched to their T2 shock valving either, but yes, they are standard race springs, they should fit. Andy RCE |
#14 |
Member#: 50319
NESIC
Vehicle:2006 STI |
^Thanks for following up. Unfortunately I need to pass - I talked to Myles and 600# is the ceiling I can realistically go with the T2's. Good luck with the sale.
| Thread Tools | |
| Display Modes | |
| GTWorx KW V3 or GTworx Damper and springs for WRX 2008 | imstuner | Newbies & FAQs | 11 | 04-09-2010 06:18 PM |
| 03 wrx tein s-tech springs w/oem stuts and top hats. | 03silverblt | SCIC Private Classifieds | 3 | 12-24-2008 06:56 PM |
| FS LI: D-specs/camber plates/group n tops/ custom KW V3 springs/lots of oem | Blown95ImpalaSS | Tri-State Area Private Classifieds | 16 | 12-10-2008 02:19 PM |
| Kw V3 And Cusco Top Hat | SuperSmog | Brakes, Steering & Suspension | 5 | 06-18-2007 03:31 PM |
| JIC replacement springs, and helper springs ?? | ScreaminFast | Brakes, Steering & Suspension | 6 | 10-12-2003 07:47 AM |
