Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-10-2008, 08:06 PM   #1
vtdave
Member#: 181001
2012 Impreza WRX 5DR
Rally Blue
Default Odd vibration...
The patient is a 2000 Impreza (wife's car). I can feel a heavy vibration at highway speeds through the steering wheel and the gas pedal. The vibration is most pronounced under heavy load (accelerating and engine braking). But, if I put the car in neutral and coast at 65 mph, it's there, too.
I've already:
1. Replaced rotors and pads (needed to get done anyway). Vibration is still there.
2. Swapped wheels and tires. Vibration is still there.
What's next - motor mounts, CV joints, driveshaft? The only confusing thing is that the vibration is still there when the gear selector (auto tranny) is in Neutral.
Your $.02 is much appreciated.
DAve
vtdave is offline   Reply With Quote
Old 12-10-2008, 08:25 PM   #2
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
I'd check the front end for any play in the tie rod ends or the ball joints/wheel bearings. This is most easily accomplished by lifting the front wheels off the ground and supporting the car with jack stands. Then, and you'll need a helper for this part, grab one of the front wheels at the top and bottom (12 and 6 o'clock) and shake it up and down, feeling for any movement. While you're shaking the wheel, your helper should be looking for anything moving. Slop in this direction typically indicates worn ball joints or wheel bearings.
After that, place your hands at the 3 and 9 o'clock positions and shake the wheel back and forth. Again, have your helper looking for anything moving isn't just the normal movement of the tie rods back and forth. The easiest way to tell if it's normal movement or not, depending upon how hard you're shaking the wheel, is to look at the wheel on the side you're not shaking. If it's moving in time with you shaking the wheel, you're just steering the car.
I know it's probably kind of hard to understand what I just wrote without pictures, but there was a decent article on popular mechanics' website that dealt with this. Admittedly, PM keeps things fairly generic, but the same principles apply. Hope this helps.
http://www.popularmechanics.com/how_...e/1272531.html
silver2004impreza is offline   Reply With Quote
Old 12-10-2008, 08:35 PM   #3
vtdave
Member#: 181001
Rally Blue
Thanks very much. I'll try that procedure.
Old 12-10-2008, 08:56 PM   #4
danmezz
Member#: 126339
2003 WRX Wagon
my guess would be worn tires from a bad alignment... if you rotate the tires and the vibration moves to a different place or changes sound then you know that's it
a bad universal joint can make vibrations too, but it usually changes with acceleration/deceleration
danmezz is offline   Reply With Quote
Old 12-10-2008, 09:16 PM   #5
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Hmm.... sounds EERILY like the problem I had with my 98RS. I changed the transmission, rear diff, engine mounts, suspension, tires..... and it wound up being a FL axle. .
My symptoms were:
- Only was really noticeable during acceleration
- Got worse as speed increased.
- Had a speed harmonic it was worse at.
Replaced the axle, and it was perfect. Took a year to figure it out
Good luck!
- dow
dowroa is offline   Reply With Quote
odd feedback vibration through pedals ronnyek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-13-2006 11:43 PM
weird knocking noise/odd vibration? maddhatteroo7 Normally Aspirated Powertrain 0 03-13-2006 04:32 PM
odd noise/vibration from rear of car Butterz Texas Impreza Club Forum -- TXIC 11 03-08-2006 07:59 PM
Odd vibration when turning... volkl23 Tire & Wheel 0 04-08-2005 12:23 AM
Odd engine stumble/vibration from 1900-2500rpms in neutral MaddMax Legacy Forum 13 10-12-2004 07:23 PM
