Old 12-10-2008, 09:50 PM   #1
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
Default what comes off the bottom of the wastegate solenoid?
hey guy,s wonder if you can answer these QUestions; were doe's the vacc line off the bottom of the wastegate solenoid go to, manifold vacc?
turbo vacc? bov control? there's 3 one in the middle goe's to the compressor!? one on the top goe's to the waste gate actuator!? the one on the bottom is disconected right now cause I was out of ports to use!! so I left it cause I did'nt know what it came off???? I can splice it in with another vacc line right????? I don't know what to splice it into though??
it runs okay but when I press the accelerator to fast it will stall!!! but the intake pipe from the turbo to the intake is getto homemade just untill the Intercooler come's that will make it run better I'm sure. I think the IAC is a little sticky but it was quite clean inside!~! I could have some vacc lines mixed up though but I rembered were most of them went on the EJ22T but the manifold ports for vacc are quite different on the EJ20G so it's not running too bad till it starts to boost cause the intake starts to leak!!
any help would be greatly appreaciated
thanx Jesse
94 GT is offline   Reply With Quote
Old 12-10-2008, 10:36 PM   #2
DumbUglyDragon
Member#: 61077
1993 WRX
It bleeds into the intake box. Rob has a diagram floating around... let me try to find it.
DumbUglyDragon is offline   Reply With Quote
Old 12-10-2008, 11:01 PM   #3
94 GT
Member#: 193676
94 legacy GT
the pipe has the plastid still stuck in it!! maybe it broke off the bottom! crap!! but I don't rember seeing a hole in the intakebox?? which box? the air filter or the damper one with the idle control and evap in it ??
thanx that could be it (I HOPE NOT) but I can fix it if that indeed is were it goe's!
Old 12-11-2008, 02:56 AM   #4
DumbUglyDragon
Member#: 61077
1993 WRX
The one I'm talking about is a port that is found on the stock resonator box, after the air filter and maf.
Old 12-11-2008, 04:11 AM   #5
94 GT
Member#: 193676
94 legacy GT
okay going to check that one out towmorrow thaanx!!
Old 12-13-2008, 08:01 PM   #6
94 GT
Member#: 193676
94 legacy GT
yeah I broke it off when pulling out the old engine ( damm) so I have to figure out how to make it work!@!! I also cracked the one going to the actuator so probly no waste gate but I gotta take it easy untill I get the Intercooler then I will fix the probs when I pull it apart again.
thanx for the input cause tha port is in a hidden spot so I probly would'nt have found tha untill later
Jesse
Under Posting Rules at the bottom of the page...HTML off? Grap Off-Topic 19 04-12-2010 04:17 PM
What's the foam at the bottom of the windshield for? nosajwp Interior & Exterior Modification 9 08-04-2006 06:56 PM
Blew the I/C piping off the bottom of the stock intercooler while street racing yo BoostdScubaru Off-Topic 45 08-30-2004 04:57 PM
What is the "knob" on the bottom of the clutch master cylinder? rallynutdon Motorsports 0 08-25-2004 08:27 AM
Why did the PM thing get moved to the bottom of the page? Impreza Rider General Community 2 03-26-2003 02:27 PM
