Old 12-10-2008, 11:27 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question Sign in if you have ej257 long block with ej205 intake parts
ok I am seriously considering a ej257 swap with a ej205 intake parts. Yet I don't hear much about people running this setup.
So if you have one or know plenty about this setup and fill me in on thoughts of running this setup. Yes I know there will be no avcs, good / bad?
Going to run vf30 for now and maybe something larger later. Also considering a few mods to avoid oil starvation. Any suggestions on the best setup for that with this engine. There seems to be a lot of thoughts about what's best.
Oh will I need to change injectors? I currently have a cobb shelf map vf30 setup.
I understand there will be some vacuum line changes. Can you guys fill me in?
If I am missing anything let me know.
thanx
Old 12-10-2008, 11:55 PM   #2
White out
Member#: 46277
** LP640
Viper GTS
uhh... as long as you run the ej205 intake mani & tgv's it will work.
the intake is exactly the same otherwise.
Nick
White out is offline   Reply With Quote
Old 12-11-2008, 12:49 AM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yes but how well?
Old 12-11-2008, 09:24 AM   #4
MasterKwan
Member#: 98961
2003 WRX
It's funny, I'm contemplating something like this too. I have new 545 top feed injectors and TGV deletes and a 2.5 liter STI motor. I was hoping I can bolt the pretty manifold right on top of my existing 2.0 TGV's. I've noticed the STI's moved the FPR under the manifold. I wonder if using the 2.0 fuel setup would be a step backwards from a fuel distribution standpoint.
Old 12-11-2008, 09:27 AM   #5
wrxej205
Member#: 188454
02 ej207+6speed
psm
im gonna be running a ej25 shortblock ej20 heads with 280 cams stock valves and stock ej20 manifold with a vf34 ewg setup with pinks and utec. ha im hoping it will all go together smoothly. get my heads back this week. and well find out if its a plausible setup or not.
wrxej205 is offline   Reply With Quote
Old 12-11-2008, 09:42 AM   #6
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
What kind of camshafts are you using that are able to utilize the stock valves? I would seriously think about upgrading those springs.
tux121 is offline   Reply With Quote
Old 12-11-2008, 09:50 AM   #7
wrxej205
Member#: 188454
02 ej207+6speed
psm
crower stage 3 cams with the crower springs they come with
Old 12-11-2008, 10:10 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It's a proven setup that works well and has been done many times before. If you are going to do it, get STI cams for the stock heads, 2.5L head gaskets and use your intake manifold.
Tony
Old 12-12-2008, 01:43 AM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Been wondering simular things. Let me know what you find out.
thanx
Old 12-12-2008, 10:04 AM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
What is the name for this swap. trying to search for others who have done this.
Old 12-12-2008, 11:32 AM   #11
MasterKwan
Member#: 98961
2003 WRX
I never heard it to have a name.
Old 12-12-2008, 03:49 PM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
What search parameters did you use?
Old 12-12-2008, 04:08 PM   #13
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
I have always called it a hybrid swap.
FYI, other than the throttle body mount area being different, the 2.5L intake manifold and 2.0L intake manifold are identical. As are the TGVs (well, other than the injector style, therefor the injector mouting holes)
Defiant Autospeed is offline   Reply With Quote
Old 12-12-2008, 05:18 PM   #14
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
i ran a ej257 with sotck intake mani,tb, engine harness, and tgv from a 02 wrx...it ran great. I used bc 272 cams. I only ran it for a few weeks due to the fact that my rings werent seating correctly so i pulled it out and i am going to install 100mm pistons. Just make sure if you have 05 and up you get the cosworth cam sensor adapter bracket. The 257 runs 2 sensors in the back where as the the wrx has one in the front that you need the bracket to mount to the heads.
blkwagon is offline   Reply With Quote
Old 12-12-2008, 05:32 PM   #15
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Well I was corrected on another thread. Yet there is no name for this swap.
If I had to choose a name I would say hybrid long block swap.
Old 12-12-2008, 05:33 PM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Cool thanx for that. I remeber reading that some where once. Yet can't remember where. What mfg makes the conversion parts?
Old 12-14-2008, 08:15 PM   #17
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
From my searching I found the link from Element Tuning
http://elementtuning.com/technical/ej25_install.htm
Also found that some of the info about the cam possition sensor is wrong. The 04 have that spot they list on the website. Yet 05+ don't. Yet Gruppe-S might have made one. Yet so see any thing about them making this part.
So this is my update at this point. Also looking into the Element Tuning did this conversion and ran a vf30 on hydra = 311 whp. Yet not sure I want to run hydra.
Old 12-15-2008, 10:17 PM   #18
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
In the process right now of installing a 06 sti lb with my 02 pnp intake manifold tb, and tgv deletes from Grimmspeed, also his(Grimm's) pnp exhaust manifold with x-over pipe. I will be using the Cosworth cam sensor bracket(this is what Gruppe-s sells and is on back order, unless you buy directly from Cosworth). Right now I will be running a pnp vf22 until funds come available for a Green or preferably a sz49. The avcs will not work of course right now...but if you by a jdm v7 ecu it can be open source tuned with the avcs. Unless you want to spend your money on a used Hydra. The guy that will be tuning my car said he could tune around the AVCS, of course spool up will be faster with AVCS but he said I wouldn't be missing it right now.
breathinez is offline   Reply With Quote
Old 12-15-2008, 11:37 PM   #19
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
cool thanx for the info
Old 12-16-2008, 12:22 AM   #20
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Old 12-22-2008, 01:01 PM   #21
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
WOW mis-information in this thread. Use the search term 257 hybrid. what this means is using the sti 2.5 shortblock with 2.0 heads and other head components for the 2.0. The combination works well when built right.
You dont need any stupid cam position sensor if you are using the US wrx 2.0 heads.
NITROS is offline   Reply With Quote
Old 12-22-2008, 01:21 PM   #22
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yea but thats not what this thread is about.
This thread is about the long block hybrid. Using the 2.5L sti heads and block. Just with no avcs and 2.0L intake and tgv's. So the info is not incorrect.
Old 12-22-2008, 01:32 PM   #23
MasterKwan
Member#: 98961
2003 WRX
Well, I thought it was about using the 2.5L long block WITH AVCS and 2.0 intake parts. That's what I'm doing anyway. Basically a setup like the 07 STI's with their top feed injectors.
Old 12-22-2008, 09:08 PM   #24
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
i just did a long block swap on to my wrx and kept the wrx manifold. i had a write up
http://forums.nasioc.com/forums/show....php?t=1626076
wrxsubiemod is offline   Reply With Quote
Old 12-22-2008, 11:55 PM   #25
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Alright! Now that's what I'm talking about.
ej257 short block with ej205 heads - Hybrid Setup 007WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-27-2009 02:53 PM
Read This If You Have Had Warranty Problems With Soa! ScoobieSnacks Warranty Issues & SOA Problems 10 06-25-2004 10:23 PM
If you have sold a 2001RS with mods on it please read this!!!!!!!! triXXXter Normally Aspirated Powertrain 15 08-09-2001 01:47 PM
