Old 12-11-2008, 12:18 AM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Horrible Grinding Noise!
Alright a little background first, 02 wrx stg 3 ish, tmic, tbe, 120k on the odometer.
It just started tonight, was coming home from a meeting at work and I started hearing a really loud grinding gear, just trying to figure out what it is. Called up my dad and he thinks it may be either throwout bearing or pilot bearing. Personally I don't think it's either because it doesn't do it specifically when you put the clutch in or out nor does it do it when I'm changing gears at all. Just completely random. I have been having problems with belt slippage which led me to believe that maybe my timing belt tensioner may be in need of replacement because it also seems like the crank pulley is a bit wobbly, not much just a tiny bit. It seems like its coming from the timing belt area on the driver side, almost right under the dipstick.
IE: odd grinding noise, dad thinks its throwout or pilot bearing; I think it's timing tensioner; noise coming from driver side timing belt area underneath the dipstick
More money down the drain probably
sorrowfulkiller is offline   Reply With Quote
Old 12-11-2008, 01:07 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
could be a timing belt idler pulley going bad.
Old 12-11-2008, 02:14 PM   #3
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
under the dip stick? waterpump. don't drive it,best to just pull the covers and check it out.
crampfan is offline   Reply With Quote
Old 12-12-2008, 09:30 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
dont drive the car or you may cost yourself a LOT of $$$
get it checked out sooner rather than later
Old 12-12-2008, 04:06 PM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
yeah, it's in the shop now... don't have time to mess with it myself because of work and whatnot.
Should hear back from them within today by the time I get to work
Horrible grinding/rattling on startup after 6mt swap Cyclops Transmission (AT/MT) & Driveline 8 06-03-2008 01:56 PM
Horrible grinding after H6 upgrade, Hawk HPS pads, and DBA slotted rotors garface Brakes, Steering & Suspension 6 10-29-2006 08:15 PM
horrible cracking noise! mprezuhguy Brakes, Steering & Suspension 4 07-16-2003 02:33 PM
Horrible grinding banging noise after working on car, HELP! dexterous Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-28-2003 10:24 PM
Got a really horrible leaking noise...Any ideas? Shifty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2002 02:42 PM
