Old 12-11-2008, 01:57 AM   #1
BlackC4rb0n
Member#: 197197
2007 WRX
cum
Default taking off on ramps v.boost lag? etc
hey guys,
have a question about when i take off on ramps.
when i shift 1->2 the car would stop or not gain speed until i am in second and from 2-3-4, [by stop i mean it waits until i am in gear, i guess my gear changes are rough] my boost gauge reads +5-10 psi yet the car does NOT pull. This is usually when i am going on a ramp that is either a little upslope or flat. not the case when im going downhill. I dont think i have a boost leak or anything like that. my set up is stock with just a cbe. but i have noticed this twice. Its just annoying when im boosting 10psi and not moving. anyone know whats going on. thanks
BlackC4rb0n is offline   Reply With Quote
Old 12-11-2008, 02:09 AM   #2
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Get a tune, then report results. I don't know how good/bad the stock maps are but give it a try, or stage 2 and see if you are satisfied with the results.
Jubert69 is offline   Reply With Quote
Old 12-11-2008, 02:22 AM   #3
BlackC4rb0n
Member#: 197197
2007 WRX
cum
do you think stage 2 off the shelf map will make a difference in pulls?
Old 12-11-2008, 06:45 AM   #4
knockknockknock
Member#: 150915
2007 wrx tr
smurf blue
I am going to assume inexperience, if I am wrong you can ignore this post.
If you are accelerating hard, when you shift from 1->2, it is normal to feel the car no longer accelerating. The harder you are accelerating and the longer you take to shift, increases this feeling. This is because our cars accelerate really fast in 1st, then when you push in the clutch, the acceleration rate almost instantly drops to 0 (no longer any power to the wheels). If you are on an incline, you may even start decelerating.
You can lessen the duration and feel by shifting faster. But be warned, the fastest shifting techniques (eg. flatfoot/power shifting) will put stress on your drivetrain. There are instructions/links somewheres in the sticky topics above someplace, on how to do a speed shift properly, which puts less strain on your drivetrain. My definition of a speed shift, is where you lift off the throttle just enough to drop your rpms to match the next gear you are shifting into, and then rolling back into the throttle as the clutch engages.
One final warning, if you are going to try to learn how to shift faster. When you are shifting in the higher rpms, and you mess up or force a shift, you can strain your drivetrain (because of the high hp/tq at those rpms). If you goof on a shift or things arent' right, leave the clutch in, drop your rpms, shift to the appropriate gear for your speed, and do a normal shift. Then try again next time.
PS. I don't race my 07 wrx, but my guess would be that the best shift points are probably somewhere around 5500rpm.
knockknockknock is offline   Reply With Quote
I just put 04 Sti take offs on my 03 wrx...now theres a vibration at highway speeds? japspecjohn Brakes, Steering & Suspension 7 03-20-2010 06:35 AM
WTB, take offs from an XB, Yaris, toyota, etc mattjk SCIC Private Classifieds 6 03-24-2008 01:24 PM
Video of Failed Sea Launch Take-off on Jan. 31 avk Off-Topic 9 01-31-2007 01:38 PM
PONDER THIS: On-ramp vs. Off-ramp Hypernoodle Off-Topic 25 07-03-2006 02:10 PM
Who has STI sedan take-offs on a wagon? savka Brakes, Steering & Suspension 2 02-20-2003 10:55 AM
