Old 12-11-2008, 08:43 AM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default unbalanced wheels or bad wheel bearings
on my 02 wrx w/ sti bbs rims i notice there is a loud humming noise when driving @ 40-60 mph, its even pretty noticeable when rolling to a stop @ lower speeds.
i havent had them balanced yet and im not sure if the previous owner did, however my old 96 obs impreza wagon used to do the same thing and the wheels were balanced..
is it possible the rear wheel bearings are bad? the car has 110K on it
mxpunk is offline   Reply With Quote
Old 12-11-2008, 09:20 AM   #2
En Sabah Nur
Member#: 179525
How can you tell if your bearings are bad, what noises would be heard?
En Sabah Nur is offline   Reply With Quote
Old 12-11-2008, 09:25 AM   #3
1stockwrx
Member#: 162365
06 RSX Type S
did you try to rebalance them?
1stockwrx is offline   Reply With Quote
Old 12-11-2008, 12:10 PM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
i dont know, thats why i posted here..
not yet, i think im going to get them powder coated and when i put the tires back on ill have them rebalanced
Old 12-11-2008, 12:46 PM   #5
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
wheel bearing noise will be speed dependent. But it also should be at occurring at most speeds.
Are you sure its not just the tires hitting some body harmonic or possibly just tire noise (especially if your car may be out of alignment.)
Wheel imbalance will be felt before its heard.
DiscoGsus is offline   Reply With Quote
Old 12-11-2008, 01:13 PM   #6
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
It could be your wheel berings, but does the sound go away when you turn right or left? or get more intense when you turn one direction?
Quadsbc is offline   Reply With Quote
Old 12-11-2008, 02:29 PM   #7
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
body harmonic..as in rubbing? i dont think they rub, they are BBS STi rims off an 04 sti. it has cooper zeon? tires i think..are they known to be noisey?
naa, i just mostly notice it while on the highway crusing, it sounds like its coming from the rear.
Old 12-11-2008, 02:41 PM   #8
EdHilario
Member#: 137398
2004 Impreza 2.5RS
I would say check the balance on the rear tires first.
EdHilario is offline   Reply With Quote
Old 12-11-2008, 06:40 PM   #9
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
Is the noise coming from a specific corner or side of the car? You could try and rotate the tires and see if the noise follows the tires. Otherwise could be the bearing.
ritky is offline   Reply With Quote
Old 12-11-2008, 10:36 PM   #10
MT_Pockets
Member#: 180118
08 obs
Whats your tire tread like? I've mistaken wheel bearings for worn tread before.
In my experience, wheel bearing noise will slightly go away when taking a curvy exit ramp from the freeway. Either loading or unloading that bearing lessens the howl.
MT_Pockets is offline   Reply With Quote
Old 12-11-2008, 10:50 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
the back side of the car........
the tread is in good condition, not too worn..
Old 12-12-2008, 11:01 AM   #12
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
Rotate them to the front and see if the noise follows.
Old 12-12-2008, 04:08 PM   #13
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
With the car unloaded in the air on jack stands, try rocking the wheel from the 12 and 6 o'clock position. If you notice play at the wheel bearing point, I'd start looking for a replacement.
jdmimpreza is offline   Reply With Quote
Old 12-12-2008, 08:46 PM   #14
HALFSTI
Member#: 152639
2006 STI
aspen white
Unbalanced tires usually dont make noise. If they do they will shake you out of the car. Cooper zeons are a lil noisey because of the tread design. Sounds like a wheel bearing or possible uneven tread wear. try running you hand along the tread and feel for and high and low spots or waves. This is called cupping or feathering.
This is what cupping can look like.
http://images.google.com/imgres?imgu...3Doff%26sa%3DG
HALFSTI is offline   Reply With Quote
Old 12-16-2008, 12:10 PM   #15
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thx ill give it a look for sure
Old 12-16-2008, 01:36 PM   #16
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
body harmonic like the vibration/noise from the tires is causing some part of the car to vibrate at the same frequency (or one of its harmonics.)
I would guess too much Toe in or out on the back wheels. It will make sort-of noisy tires.... REALLY noisy.
Old 12-16-2008, 02:04 PM   #17
Roamrex
Member#: 171487
06 WRX Wagon
SGM
probably the tires itself. as tires wear they get real noisy.
Roamrex is offline   Reply With Quote
how to tell it is bent wheel or bad tire? dawhim Newbies & FAQs 13 12-15-2005 02:49 PM
ACE wheels, good deal or bad wheels? WRXED1 Tire & Wheel 18 04-18-2004 02:55 AM
WTB Stock wheels or 17" wheels blueribbon North West Impreza Club Forum -- NWIC 2 01-06-2004 09:26 PM
FT: either 1 wheel for 1 wheel or 4 wheels for 4 wheels(read post) YaZahX Tri-State Area Forum 19 10-28-2002 05:47 PM
Looking for stock WRX wheels or RS Wheels ChrisV-FL South East Region Forum 4 09-20-2002 07:05 AM
