Old 12-11-2008, 12:12 PM   #1
Manutd06
Member#: 193616
06 WRB
WRX
Default How to clear my headlight lenses
hey guys, ive been noticing for sometime now that my headlite lenses got yellow shades. its not dirty or anything, it has to be something else. i just got it handwashed few days ago from this private shop and its still there. i mean super white HIDs and when its really dark and im looking at my lights, i see this yellow shade sort of mixed in with the xenons.
can anyone tell me what i can do to make the lenses crystal clear.
Manutd06 is offline   Reply With Quote
Old 12-11-2008, 12:48 PM   #2
quadtard
Member#: 104206
headlight polishing compound
quadtard is online now   Reply With Quote
Old 12-11-2008, 01:27 PM   #3
Manutd06
Member#: 193616
06 WRB
WRX
thanks buddy
Old 12-11-2008, 04:19 PM   #4
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
meguirs PlastX
audio1der is offline   Reply With Quote
Old 12-11-2008, 07:07 PM   #5
civic_82
Member#: 189668
2007 2.5i sp ed
Originally Posted by audio1der View Post
meguirs PlastX
depending on how bad the lense is it wont work, had to buy new ones on my civic
civic_82 is offline   Reply With Quote
Old 12-11-2008, 07:10 PM   #6
Un0RiGiNaL
Member#: 189748
advanced auto has this cleaning kit, comes with sandpaper and a bunch of other crap
Un0RiGiNaL is offline   Reply With Quote
Old 12-11-2008, 11:11 PM   #7
Matt4545
Member#: 193752
1999 Legacy 2.5gt
i just did this today, i took 800 grit automotive sand paper and scuffed it up, then wet sanded with the same 800 grit. then i took plastic polishing compound and my dremel with the plastic buffer ad don on it and buffed that compound in at increasing speed. Then wet sanded again and buffed with the polish compound again, then wiped all the compound off and buffed with a fresh buff pad. then fixed any imperfections by wet sanded that area and buffing it lightly again. then wiped the whole lens down and cleaned it, and sprayed it with 3 coats of DuPont spray clear. comes in a can and is like 4 dollars at auto zone. now after you have done all the buffing you may think it doesn't look all that much better, but when you spray on this clear it make them look great. it also protects them from turning on you again. they look great, my only complain is i can still see swirl marks in the lens if my headlights are on and i look at them on an angle. this was my first time doing it and it came out a lot better than i expected. now i just gotta get the fog lights done....
oh yeah, and i found its alot easier to just pull the whole headlight assembly off the car and take it in the basement or something.
Matt4545 is offline   Reply With Quote
Old 12-11-2008, 11:25 PM   #8
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
did the same thing. i just did 800 the 1000 and then 1600 grit paper and less buffing. turned out great, gets rid of a the pits and make them look brand new
bugeyesubie is offline   Reply With Quote
Old 12-17-2008, 02:00 AM   #9
Mr. Bungle
Member#: 44091
'07 STi
Obshidian Burakku
I probably sound like a broken record, but Simix surface restorer worked for me on this, too.
Mr. Bungle is offline   Reply With Quote
Old 12-17-2008, 11:10 AM   #10
ttocsnodrog
Member#: 193576
I imagine that any type of clear finish sprayed onto headlights (or especially foglights as they're so near the road) is going to start flaking off pretty quickly. A method I've used on a good number of vehicles is to start with patience (and keep it through the remainder of the steps!) and lightly wetsand with 800 grit, then spend twice as much time with 1200 grit, then twice as much time as that with 2000 grit, then spend a whole BUNCH of time with 2500 grit. It'll still look pretty cloudy at this point, so polish it out with a good polishing compound. Have fun -- you'll get like-new results if you spend enough time at it!
ttocsnodrog is offline   Reply With Quote
Old 12-17-2008, 12:31 PM   #11
KB21
Member#: 186441
2004 Impreza WRX
Try CCP 5-Minute Headlamp Lens Restorer kit. You can buy it on Summit Racing website. Comes with everything you need. You just need to have a regular household drill. I used it on my headlights and it worked very well. I also used it on my neighbor's Chrysler. His headlights were very hazy/yellow and CCP stuff made them look like new. Polishing compound I picked up at the local auto store did not work very well at all.
However, if you have some deep scratches or pitting (from rocks or other road debris), CCP will not help by itself. You'll probably have to wetsand the headlights first and then use a polishing compound of some sort.
KB21 is offline   Reply With Quote
How to clear 06 headlights & paint. Silver_04_WRX_SC Electrical & Lighting 1553 05-11-2016 12:15 AM
How to clear MY04 headlights - photo instructions skivvie Car Care & Detailing 1374 03-14-2015 02:07 PM
How to clear corner headlights... m0okie06 Electrical & Lighting 1 09-01-2006 10:48 PM
where is a good spot to clear my headlights? topgrinder Vancouver Impreza Club Forum -- VIC 8 08-21-2005 02:33 AM
Finally decided to clear my headlights out tonight... Subie2 Texas Impreza Club Forum -- TXIC 14 06-25-2005 11:15 AM
