Old 12-11-2008, 05:43 PM   #1
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
Default Flashing CEL
I'm working on a friends 2000 Legacy, and have come across an interesting problem. When it's started for the first start of the day in frezzing weather, it has a definate miss, and flashing CEL to go along with it. I've been told it's either a coil pack dying, or bad plug wires. Plugs are new NGK's, and wires are a couple years old. Again, this problem is only for the first start of the day in freezing weather. Suggestions anyone before I just throw parts at it?
carrman is offline   Reply With Quote
Old 12-11-2008, 05:46 PM   #2
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Get the code(s) pulled before you do anything. It's the best way to diagnose, and we can't do a lot without them.
If you find out you're getting a misfire, you can swap the wires left-to-right, and if the misfire follows, it's a safe bet that your problem is with the wire.
If it turns out to be the coilpack, and if you can wait, I can unload one to ya for cheap!
LetItSnow is offline   Reply With Quote
Old 12-11-2008, 05:47 PM   #3
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
Did that, but it isn't logging any.
Old 12-11-2008, 08:11 PM   #4
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
strange....
My guess would be an 02 sensor going bad.
sc00ter is offline   Reply With Quote
Old 12-11-2008, 08:14 PM   #5
GrundleJuice
Member#: 165749
reset the ecu and wait for the CEL to come on again. then try pulling them again.
Old 12-12-2008, 10:06 AM   #6
carrman
Member#: 69137
2007 2.5i Outback
1966 Chrysler 300
Found a corroded terminal on the coil pack. Cleaned it up, and fired it this morning, only to haveit misfire again, but for a shorter period of time. Beginning to think it's a bad coil pack, or I need new wires. Wires are 3 years old.
Old 12-12-2008, 02:15 PM   #7
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
have you pulled the spark plugs? if not, pull them and check them out!! also recheck the plug wire connections to make sure they are all tight and secured in place.
Vizzionz is offline   Reply With Quote
Old 12-21-2008, 01:00 PM   #8
fornetti14
Member#: 103771
'00 Impreza 2.5RS
I hope you don't have what I had with my flashing CEL - burnt exhaust valves on the #4 cylinder. I had a Cylinder #4 misfire CEL code plus the car was obviously misfiring.
A simple compression check found that I had only 80 psi of compression on #4 and 180 - 185 psi on the rest.
fornetti14 is offline   Reply With Quote
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
HELP!! flashing cel tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-04-2010 01:38 PM
2 CELs, GAS Smell, Flashing CEL, HELP! Zerolapse Service & Maintenance 1 09-15-2006 10:50 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
Flashing CEL vs. Solid CEL Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-15-2003 11:01 PM
