Old 12-12-2008, 02:53 AM   #1
09Impreza
Member#: 197291
2009 Impreza
Default A couple of quick questions regarding my '09 Impreza
I just purchased my 2009 Impreza not too long ago and as of now it has about 5K miles on it. I have a couple of questions to ask and want to know if these things are normal. First, after the car has been sitting for maybe a day or two, after I reverse out of my parking space and put my car into first gear and start going, there is a loud klunk-like noise coming from underside of the car. It only happens once (only one, semi-loud klunk) and only after start-up in the described situation above. Is it part of the AWD system or something different?
Also, given the circumstance that I am downshifting while coming down a hill at around 50 MPH and I downshift from 5th to 3rd gear, there is a suddle vibrating noise coming from the engine compartment. When this happens, the car is only downshifting with no other input and is at about ~4000 RPM. Is this normal?
TIA
Matt
09Impreza is offline   Reply With Quote
Old 12-12-2008, 11:25 AM   #2
natejohnson81
Member#: 191050
2008 Impreza 2.5i 5d
Dark Gray
No clue as to the downshift issue... Have you tried downshifting from 5-4 instead of 5-3? Depending on speed and gear the syncros may be the cause of the sound...
As for the clunk when you start... I have the same issue. I notice it mostly as have the wheel turned rather sharply... If you ever find out anything on it let me know... I have an 08 with 6k and i cant really say it has been bad enough to talk to the dealer about...
natejohnson81 is offline   Reply With Quote
Old 12-12-2008, 01:07 PM   #3
VIsubi
Member#: 187834
06 2.5i impreza
Red
well I know lockers will make a noise once its locks but does an LSD do the same....try downshifting from 5th 4th to 3rd even if you don't use 4th..use the motion in other words go directly into 4th but don't release the clutch then into 3rd jumping.
VIsubi is offline   Reply With Quote
Old 12-12-2008, 08:04 PM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That clunk is an ABS self-test. Perfectly normal.
Counterfit is offline   Reply With Quote
Old 12-12-2008, 09:39 PM   #5
Old_Lady_Driver
Member#: 190056
2013 2.0i 5 dr CVT
Pearl white
I have a 2008 Impreza automatic transmission -- I was told by the dealer that the clunk is the ABS self-testing. Yes, I have it too, right after the car starts moving forward.
Old_Lady_Driver is offline   Reply With Quote
Old 12-13-2008, 01:33 PM   #6
VIsubi
Member#: 187834
06 2.5i impreza
Red
well mine doesn't do that and its a 06 never heard a clunk when starting it and if that was true everytime you started the car it would make that noise mine doesn't who knows I guess.
Old 12-15-2008, 04:36 AM   #7
09Impreza
Member#: 197291
2009 Impreza
Thanks a lot for the responses. I will try the 4th to 3rd shift instead. More specifically, the vibrating noise comes when the car is in a downshift and above 3K RPM.
Old 12-15-2008, 10:17 AM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
dunno what the self test would be. Could the clunk just be the pads or calipers shifting? Pretty common thing for disc brakes to do when reversing the direction of the car.
sniper1rfa is offline   Reply With Quote
Old 10-22-2010, 12:18 PM   #9
Ziggy114
Member#: 261735
2008 Impreza 2.5i
Dark Grey Metallic
I've been noticing the same problem with my '08 impreza, the noise usually seemed to be coming from the front passenger wheel - was hoping it wasn't a u-joint or something. Most of the stuff I've turned up seems to point to it being the ABS self-test, as previously mentioned. I mentioned it to the dealer last time I had it in for servicing, but the mechanic reported back that he either couldn't reproduce the noise, or that he didn't find anything wrong, I can't remember which.
You wouldn't think they would design it to make a noise that would be unsettling to those of us who pay attention to those sorts of things... is it possible that some misadjustment with the break caliper is the reason it makes the noise instead of performing its test silently?
Ziggy114 is offline   Reply With Quote
Old 10-22-2010, 12:58 PM   #10
gurana
Member#: 255131
2011 Impreza OBS
OBP/Dark Gray
I too have noticed it. It's always when I'm just starting to drive. Glad to hear it's not a problem...
gurana is offline   Reply With Quote
Old 10-22-2010, 01:04 PM   #11
royalnewjersey
Member#: 250954
2013 WRX Hatch
Yep, I have the "clunk" sound too. Only happens when starting to drive for the first time, or after reversing.
Sounds like it's a common (normal) behavior.
royalnewjersey is offline   Reply With Quote
Old 10-22-2010, 09:16 PM   #12
nickd711
Member#: 240349
2009 impreza
black
both my 09 impreza and my wifes 10 forester both do it. pefectly normal. but it does freak u out when u hear it the first couple of times.
nickd711 is offline   Reply With Quote
Old 10-23-2010, 08:30 AM   #13
marlo
Member#: 261728
I have a 2008 impresa, at first i though it was a problem but the owners manual talks about it also (ABS self Test)
marlo is offline   Reply With Quote
quick question regarding my fmic scooby1320 Newbies & FAQs 7 01-28-2009 02:37 PM
got vf22 installed, got couple of quick questions. schwarzenegger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-19-2003 08:41 PM
Couple of quick questions. kcarton Impreza Forum 2 11-11-2003 12:46 PM
Broke 1st gear have a couple of quick questions fastlane Transmission (AT/MT) & Driveline 13 05-08-2003 01:32 AM
a couple of quick questions. steppin16 Normally Aspirated Powertrain 1 06-28-2001 09:33 AM
