Old 12-12-2008, 11:42 AM   #1
abaton6
Member#: 149373
Angry 97 2.2 Auto, 24 MPG!!??
Any suggestions? It has 142K on the clock.
abaton6 is offline   Reply With Quote
Old 12-12-2008, 12:01 PM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
1) TUNE UP!!!!
2) Use a light foot.....ALWAYS,
3) Inflate your tires to between 37-39psi.
4) Lose weight or if weight has been lost, keep really heavy people out of your car.
Kevin Thomas is offline   Reply With Quote
Old 12-12-2008, 01:30 PM   #3
2.5GTLegacy
Member#: 111219
This right here might be too much, as head increase pressure will go up as well.
I keep mine at around 32psi.
And i get around 23-24 mpgs, so don't expect wonders.
2.5GTLegacy is offline   Reply With Quote
Old 12-12-2008, 02:08 PM   #4
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
open you drivers door and read what the manufacturer says to fill your tires up with the correct PSI.
the 37-39 PSI is for Auto-X, etc.
Vizzionz is offline   Reply With Quote
Old 12-12-2008, 02:26 PM   #5
Kevin Thomas
Member#: 110
1989 1989 XT6
I was just letting him know what worked best for me as far as gas mileage. Been doing this for almost 11 years now with no ill effects or extra wear on tires. The manufacturers recommendation should be followed but it never got me the best gas mileage. I just happen to have a 2.2 '97. .2 cents...
Old 12-12-2008, 09:51 PM   #6
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
"Keep RPMs below 4000 RPM unless in a case of emergency."
Yep, that said.
Smoke is offline   Reply With Quote
Old 12-12-2008, 11:30 PM   #7
mycarsux
Member#: 32049
2010 sti
what wait...r we supposed to get more than 24?! i mean..mine is 2.5 but yeah..
mycarsux is offline   Reply With Quote
Old 12-12-2008, 11:39 PM   #8
ZeppelinPie792
Member#: 160287
2007 Impreza 2.5i SE
Newport Pearl Blue
Actually, it is just recommended pressure for the inside of your doors. You can inflate them up to the max listed on the sidewall of the tire and be fine. You can do the research to find out how this isn't harmful if you want.
This site may help you out a bit too: http://www.cleanmpg.com/cmps_index.php
I tend to get 28-31mp city in my car incorporating a few techniques from this website.
ZeppelinPie792 is offline   Reply With Quote
Old 12-13-2008, 12:04 AM   #9
mofugga
Member#: 19540
2000 old skool RS
BRP
seafoam
mofugga is online now   Reply With Quote
Old 12-13-2008, 12:25 AM   #10
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
u r doin better than me in my 94 Leg 2.2l I get about 20 on average
dangerousatom is offline   Reply With Quote
Old 12-13-2008, 12:36 AM   #11
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
24 MPG isn't too bad (don't forget the colder weather means less MPG). I get anywhere between 26-30 MPG depending on where I go. I have a very light foot.
As stated before check your tires, get a tune up if you are due, and drive like a grandmother.
jetfan2207 is offline   Reply With Quote
Old 12-13-2008, 02:21 AM   #12
mycarsux
Member#: 32049
2010 sti
i just read some articles on that site. the mpgs they're getting is amazing
i gotta try some techniques. of course there's some stuff i can't avoid (like driving w/o awd or avoiding hills), but it was interesting reading how inflating your tires up the the max psi on the tire sidewall is perfectly fine. i want my car to get 30mpg
Old 12-13-2008, 08:28 AM   #13
GrundleJuice
Member#: 165749
the information stated on that website about inflating your tires to max pressure is incorrect. while it is still safe for the tire's integrity it will cause poor treadwear on most tires (not improve treadwear! and only very low profile tires can get away without any noticeable change in treadwear) and it will absolutely decrease grip levels. your tire will no longer be able to conform to the small contours/imperfections in the road surface like it could with a lower pressure. It wont be a night and day difference in terms of feel, but in an emergency braking, maneuvering and even acceleration may suffer. This has all been proven.
If inflating your tires to max pressure was an easy, no loss way to gain MPG then the auto manufacturers would design their suspension to ride comfortably on 65 psi.
Their is no doubt that running at a higher tire inflation pressure will decrease rolling resistance (friction) and increase efficiency, however.
GrundleJuice is online now   Reply With Quote
Old 12-13-2008, 10:25 AM   #14
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
tire friction is also a VERY small part in what your engine has to overcome to accelerate, or even stay at the same speed. Wind resistance is the big one. stay under 60-65 if you can help it.
oh, and with 148K on the car, tune up. when was the last time air filter was checked? how about O2 sensor?
Old 12-13-2008, 03:02 PM   #15
ZeppelinPie792
Member#: 160287
Newport Pearl Blue
It isn't THAT hard, but you will have to work for it, somewhat.
Keep in mind I was getting about 24-26 city when I first got my car. I tend to have a very light foot.
I also didn't exactly inflate my tires all the way up to the max, but about 5 psi below max.
Old 12-13-2008, 03:47 PM   #16
GrundleJuice
Member#: 165749
im getting 26+ city with a moderate foot, running 36psi front 34psi rear w/ a tune to go along with bolt ons. which is about 1.5mpg better than I was experiencing with the stock setup/stock tune. I dont do much freeway driving, and when i do, i usually have two bikes on a yakima roof rack, so my mileage is pretty dismal.
97 Legacy 2.2 auto - what trans can swap in? yo vanilla Transmission (AT/MT) & Driveline 3 12-19-2012 08:51 PM
Calling All 97-99 LGT 2.5 N/A mpg thread illegal2.2 Legacy Forum 20 10-08-2008 10:27 AM
does 2002 auto transmission fit on 1996/97 legacy 2.5 zrl Transmission (AT/MT) & Driveline 0 09-19-2007 04:28 PM
Storyland 2 Day auto-x April 24/25 KC New England Impreza Club Forum -- NESIC 13 04-21-2004 12:32 PM
Causes of 18 mpg/24 mpg fuel economy? purefx STi Forum Archive 35 05-12-2003 03:32 AM
