Old 12-12-2008, 09:04 PM   #1
ezzzey
Member#: 141956
2002 Impreza WRX
Default Whats behind this cover?
what part is this?
I get this noise when i turn off the car... right when the motors about to a dead stop seems like a pulley isnt turning freely, like its a little seized or something? Seems like its coming from the arrow pointing in the picture.. what's behind there? Pulley i asume? for wat?
http://img212.imageshack.us/my.php?i...uenginetp8.jpg
thanks
ezzzey is offline   Reply With Quote
Old 12-12-2008, 09:31 PM   #2
Boosted Up
Member#: 154828
04 & 12 WRX 06 STI
How many miles on your car?
Replaced timing belt yet?
Boosted Up is offline   Reply With Quote
Old 12-12-2008, 09:41 PM   #3
ezzzey
Member#: 141956
2002 Impreza WRX
223,000km (not miles) and the timing belt was changed by the dealer when i bought the car at 165,000k (give or take).
Old 12-12-2008, 09:54 PM   #4
Newbuggy
Member#: 152042
so timing belt at 102000 miles and it has 138000 on it now. For us yankees
Newbuggy is offline   Reply With Quote
Old 12-12-2008, 10:45 PM   #5
Crawford Performance
Member#: 42075
There are four pullies for the timing belt behind the three covers. They are known to have the bearings go bad.
It's much cheaper to replace it before the timing belt breaks
Team Crawford
Crawford Performance is offline   Reply With Quote
Old 12-13-2008, 02:37 AM   #6
ezzzey
Member#: 141956
2002 Impreza WRX
Team Crawford
so from the picture i've posted above, the arrow pointing to the cover in the left hand side, thats ONE of the 4 pullies?
Have any pullies you'd recommend? or go with a stock one ? I dont mind spending a few more bucks.
Dave
Old 12-13-2008, 05:06 AM   #7
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Go with stock so you know it fits.
EdHilario is offline   Reply With Quote
Old 12-13-2008, 11:13 AM   #8
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
What you want to replace is the tensioners and idlers I believe. They are in between the belts. Here is a link to refer to with some pictures. New belts should be installed and check the seals also while in there.
http://endwrench.com/images/pdfs/2.2SingleOverWin01.pdf
Old 12-13-2008, 04:00 PM   #9
ezzzey
Member#: 141956
2002 Impreza WRX
Well, the sound appears to be coming from the left hand side "BIG Pulley" not from the main area where the 4 small idler pulley are.
Just called subaru, they want 220$ for 1x Timing belt pulley ;/ and install is 350$ woots. This really sucks... just spent 400$ on a damn o2sensor about 1-2 months ago, now this... ugh. Def not letting them do this... for 350$ i can get a nice front lip... or ero guards muaha(lol).
Do i have to remove all those sprockets/idler pulleys in order to loosen the belt and install a new Timing belt pulley? Or can i just Loosen ONE of the sprockets/idler pulleys in order to give me enough slack to remove the pulley?
Thanks in advance.
Old 12-19-2008, 01:05 AM   #10
ezzzey
Member#: 141956
2002 Impreza WRX
so i've done a little more reading...
now... http://www.salicos.com/images/PulleyGrip.JPG
[the biggest pulley on the left]
Isnt that pulley the one i have the arrow pointing to in the first top picture? And that would be a cam gear or am i wrong? Cause thats were the noise/sound appears to come from when i shut off the car.
Old 12-21-2008, 11:52 AM   #11
Cougar4
Member#: 53443
Winestone
The large sprocket is connected to the cam alright. I'm not sure why you are hearing noise from it unless the bearing or bushing for it isn't being getting lubrication or, it is worn out.
What is this spare connector behind the stereo? ('99 Impreza) Pic attached doufdouf Car Audio, Video & Security 6 09-05-2006 08:41 PM
Whats the story behind this D-I-Z-Z-L-E Off-Topic 45 08-17-2005 11:48 PM
What are the physics behind this ? Extraze Off-Topic 101 07-16-2005 01:55 PM
hella black magic behind STi covers rally alaska Electrical & Lighting 4 05-15-2005 01:20 AM
whats the story behind this carbon fiber thing? skimmilk68 Off-Topic 32 07-19-2004 11:35 AM
