Old 12-13-2008, 02:08 PM   #1
Jrags87
Member#: 119324
2005 Impreza WRX STI
Crystal Grey Metallic
Default Can i run 235 sized tired on stock BBS Rims?
Tire rack only recommends 225 .. but was wondering if i could get away with a slightly wider tire?
Thanks
Jrags87 is offline   Reply With Quote
Old 12-13-2008, 02:11 PM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
u can easily put a 235 on your stock BBS rims.
the car should have come with 235s
vinceGC8 is offline   Reply With Quote
Old 12-13-2008, 02:13 PM   #3
Jrags87
Member#: 119324
hmm .. why would tire rack recommend 225?
basically .. i want to know if i can put the Dunlop Direzza Sport Z1 Star Spec 235s on the BBS wheels
Old 12-13-2008, 03:07 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You can't because TireRack said so.
however I do run 235/40/17 on 17x8 on my '99 Impreza L Wagon. Subaru SHOULD have went with 235's in the first place. Or maybe even 245's. There's not wrong with running 235's on your BBS wheel. You should run 245/40's on your wheel.
FuJi K is online now   Reply With Quote
Old 12-13-2008, 03:31 PM   #5
gtaccord
Member#: 180318
2005 STI
Tire rack recommends a tire based on the height considering what came on your car stock. Therefore it will always tell you that your stock size is best. If you look at the individual tire specs it will tell you the rim width range that will work with each size.
245/40s will work perfectly so 235s are certainly ok.
gtaccord is offline   Reply With Quote
Old 12-13-2008, 03:35 PM   #6
Blacksails192
Member#: 142686
back to european
04 sti had 17.75 rims which started the 225 tire standard but in 05 it went to a 17x8 rim but never went to a 235 for some reason
Blacksails192 is offline   Reply With Quote
Old 12-13-2008, 03:37 PM   #7
Ralliart4
Member#: 135927
2002 Impreza WRX RA
I used a 235 45 17 on my 17x8 wheels as well and they are not too big for a 17x7.5 you may even be able to get away with a 245 40 17 if you have coilovers.
There should not be a problem at all with running just a slightly wider tire compared to the 225
Ralliart4 is offline   Reply With Quote
Old 12-13-2008, 03:38 PM   #8
JBee
Member#: 105076
2002 Tuned by FORZA2
RMK #4
i has 04 and im running 245/45/17 toyo t1r
thats how i roll.
JBee is offline   Reply With Quote
Old 12-13-2008, 03:39 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000000000d....you have a 17x8 WHEEL
245/40 is just fine.....perfect, in fact.... better gearing....a 255/40 will fit too as will a 245/45
235/40 is too short and a 235/45 is just wimpy
Old 12-13-2008, 03:40 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Blacksails192 View Post
04 sti had 17x7.5 WHEELS which started the 225 tire standard but in 05 it went to a 17x8 rim but never went to a 235 for some reason
fixed that for ya
Old 12-13-2008, 04:03 PM   #11
TeamTHP
Member#: 151994
05 STI "Stage 2"
[email protected], 1.78 60's
will 245/40 and 255/40 clear the stock suspension with stock offset/wheels?
TeamTHP is offline   Reply With Quote
235/40/17 size tire on stock 17" wheels? gopsu Tire & Wheel 8 05-06-2008 10:56 PM
size for winter tires on stock wrx rims? CletusTheDwarf Tire & Wheel 5 01-29-2007 06:03 PM
How wide of tires on stock BBS rims with an STI pink drop? Andrew Newbies & FAQs 15 11-25-2006 04:41 AM
235/45 (or 235/40) tires on stock 17x7.5 BBS? root Tire & Wheel 17 01-26-2005 08:00 PM
can I run 235-45-17 on 17x8 w 48et on 2004 DickWRX Tire & Wheel 4 11-16-2004 11:43 AM
