Tire & Wheel Forum sponsored by The Tire Rack |
12-13-2008, 04:23 PM | #1 |
Member#: 126042
SWIC
Vehicle:2004 W Ŕ X PSM |
Quick tire size question for stock wrx wheels.
There is a good deal on some winter tires that I want to get and the size is 225/60/16. I know that's a little wider and taller than the factory wrx tire size and IMO I think it should work fine for winter. What are your thoughts?
Thanks
12-13-2008, 04:32 PM | #2 |
Member#: 183480
South East
hmm...
I think the 60 is what is going to get you. I have 225/55R16 on my stock wheels, I am lowered 1.25", and I don't really have any rub anywhere, but it is VERY VERY close to the strut in the rear. You can probably do it for sure if you aren't lowered at all, or if you don't mind a little tire rub every now and then in the rear. Then again...you are a sedan and not a wagon; that gives you a hair more clearance in the rear...not much, but...Like I said, probably no problems unless you are lowered and have a full car and full tank of gas. Even then, it probably would only rub around sharp corners, and you may be able to get rid of that with some negative camber.
12-13-2008, 05:19 PM | #3 |
Member#: 126042
SWIC
Sorry, I didn't even think about suspension making a difference. The car has stock suspension. Thanks for the reply.
WTT: 17" Rota Subzero's GOLD w/tires for stock wrx wheels w/good tires | veselik3 | NWIC Private Classifieds | 7 | 06-15-2007 02:26 AM |
tires size question for stock sti BBS rims | scooter29 | Tire & Wheel | 24 | 06-01-2007 11:34 PM |
quick socket size question for alk install | psyber_0ptix | Brakes, Steering & Suspension | 11 | 12-17-2004 01:33 AM |
best tires for stock wrx wheels? | nturino | Brakes, Steering & Suspension | 12 | 04-25-2002 10:54 AM |
TRADE:17X7 Dronnells with Khumos for stock wrx wheels and tires | MYWRXROKS | Southern California Impreza Club Forum -- SCIC | 14 | 03-06-2002 02:39 PM |
