Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-13-2008, 08:45 PM   #1
sam11
Member#: 165311
2005 2.5RS
Exclamation Engine Clunking Noise?
Not sure if this is the right place, wan a mod move this to the right section, please.
Have a 2005 2.5RS with 54,000 Km's
My brother was driving home last night @ 3 AM and was joined by an Acura club & a few BMW's.
Began to drive more aggressively and the check engine light came on, followed by the engine making some clunking noise.
Makes this loud clunking noise at low revs and the noise dissipates into the higher revs, but not as much.
Anyone know the problem?
sam11 is offline   Reply With Quote
Old 12-14-2008, 02:13 AM   #2
jrobe
Member#: 172156
1995 Legacy LS Wagon
blue
What code does the CEL give you? That's the first place to look.
jrobe is offline   Reply With Quote
Old 12-14-2008, 03:02 AM   #3
raheezy69
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
mobile 1 5w30?
raheezy69 is offline   Reply With Quote
Old 12-14-2008, 04:22 AM   #4
sam11
Member#: 165311
2005 2.5RS
The car was last serviced at 46,000 km.
How do I get the CEL code? The CEL light flashed a few times, in which we slowed down, and later heard the noise.
Originally Posted by raheezy69 View Post
mobile 1 5w30?
No, Castrol 5w30, I added 2 bottles of Castrol 5w30 this morning just in case, didn't make a difference.
Old 12-14-2008, 10:59 AM   #5
jrobe
Member#: 172156
blue
An OBD2 scanner that plugs into car on the drivers side by your knee's.
You can buy cheap scanners or go to Autozone and they will scan it for you.
If you bought it from a dealer they might scan it for free, if not they will charge you more than it would cost to buy your own scanner.
Good luck.
Old 12-14-2008, 02:02 PM   #6
piperpilot26
Member#: 197453
knock sensor mabye? it could be pre ignition or detonation.
piperpilot26 is offline   Reply With Quote
Old 12-14-2008, 04:51 PM   #7
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Most likely you spun a rod bearing. Engine rebuild will be in order if so.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 12-14-2008, 05:35 PM   #8
sam11
Member#: 165311
2005 2.5RS
Josh
Are you kidding me? I'm the second owner, and the previous owner didn't drive the car hard, and only put 32km's on the car. It hasn't even been driven hard, until that night.
How much would that cost?
Waiting for a few members to respond to their PM's to get a scan, will know soon.
Old 12-14-2008, 06:31 PM   #9
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Doesn't need to be driven hard if it was 2qts low on oil.
People don't typically add oil "just in case", they add it because it is low.
flstffxe is offline   Reply With Quote
Old 12-14-2008, 08:48 PM   #10
GrundleJuice
Member#: 165749
were you 2 quarts low or not? if you were, that + some aggressive driving can cavitate the oil pickup/pump. If you were not 2 quarts low, grossly over servicing the oil can have its own problems.
This may all be in vain now, though. especially if you are in need or rebuild. would like to know what you find out for future NASIOCer's sake.. (CEL, what the problem turns out to be)
Old 12-14-2008, 10:23 PM   #11
sam11
Member#: 165311
2005 2.5RS
I'm not sure if it was low or not, my brother said that he checked the oil in the morning and it was low, for some reason I think the engine was cold when he checked it, even though he said he ran the engine. Either way the car hasn't been moved since.
A fellow member thought it may be a cracked gasket, but he's not sure. I will be flat bedding it to the dealership tomorrow and will update this thread once I know.
Old 12-15-2008, 11:41 AM   #12
ScottyB
Member#: 155883
2005 Impreza 2.5RS
bacon rage
sounds like a spun bearing. running an engine hard on a low oil level will do that. 2 quarts low is pretty negligent, btw.
if it is a spun bearing and you got lucky you may only need to replace the rod bearings if the crank isn't torn up. if you drove on it much at all after the noise you'll likely have to rebuild the bottom end at the very least.
does the noise sound like a metal hammer hitting a solid metal part? search youtube and you'll get an idea of what a confirmed spun bearing sounds like.
ScottyB is offline   Reply With Quote
Old 12-15-2008, 12:03 PM   #13
BE6STI
Member#: 192815
2003 Outback
Regatta Red Pearl
Checking the oil on a cold engine would show a slightly higher oil reading on the stick as opposed to an at op temp one because the engine had not been run in a while so all the oil would be in the pan, not small deposites through out the motor so if it was low on cold... then it was low...period...
Last edited by BE6STI; 12-15-2008 at 12:04 PM. Reason: I have horrible typing skills :(
BE6STI is offline   Reply With Quote
Old 12-15-2008, 02:08 PM   #14
jrobe
Member#: 172156
blue
There is a reason check engine lights come on.
CHECK THE CODES
Then go from there.
Old 12-15-2008, 02:29 PM   #15
raheezy69
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
sounds to me like you're fucxed
Old 12-15-2008, 11:34 PM   #16
t3t4meat
Member#: 196972
low on oil + engine knocking noise = spun rod bearing.
get a new short block or engine which ever you find cheaper.
t3t4meat is offline   Reply With Quote
Old 12-15-2008, 11:35 PM   #17
t3t4meat
Member#: 196972
these cars will run for a long time, but will break quickly with low oil
Old 12-15-2008, 11:44 PM   #18
sam11
Member#: 165311
2005 2.5RS
I agree its a spun rod bearing. But. the odd thing is my oil light never came on.
Old 12-16-2008, 12:59 AM   #19
dlong27
Member#: 191010
2011 Lego Premium
Damn, thats a hard lesson to learn, always check your oil at every fill-up, good luck with the repairs.
dlong27 is offline   Reply With Quote
Old 12-16-2008, 01:54 AM   #20
09Impreza
Member#: 197291
2009 Impreza
It sounds like a spun bearing for sure. My BMW M3 began to make a similar noise like that so I took it to the dealer. They did not go too deep into it and replaced the VANOS unit in the car and didn't notice anything funny after replacing it. After I got it back, it made the same clunking noise at low RPMs, so I drove it normally for the next few hundred miles, thinking the sound was ok. At one point the bearing finally blew out and ruined the crankshaft and the engine sounded like an old Mercedes diesel. It turned out that the bearing had blew and the engine needed to be replaced. I would get it checked out for sure. Good luck. Hopefully the same thing that happened for me isn't happening to you even though they are two separate cars.
09Impreza is offline   Reply With Quote
Clunking Noise and Knocking Noise from rear. AWD_Drift Brakes, Steering & Suspension 16 02-14-2011 02:56 AM
Clunking noise when engine is cold.. JAhman Newbies & FAQs 5 11-29-2007 09:18 PM
Horrible clunking noise coming from engine & transmission... Remnex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 11-06-2005 03:04 AM
check engine light / funky clunking noise from center diff? JessesTalon North West Impreza Club Forum -- NWIC 3 12-28-2004 12:19 AM
04 WRX makes clunking noise when in gear & engine cold at 2000-2500 rpms ImportVenom Transmission (AT/MT) & Driveline 16 08-03-2003 09:24 PM
