Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-14-2008, 11:47 AM   #1
cthomasset
Member#: 189435
2008 2.5i
Default MY 08 2.5i Issue - Bucking/ Hesitation
Car: 2008 2.5i 4eat, 5200 miles
Mods: SPT catback (installed 2 days ago), have run K&N panel filter for last 2k
Situation: 65 mph, 1/2 tank of gas, 55 deg F, windy as hell, 9:30 pm central time.
Issue: At highway speed last night, car bucked and hesitated while under load for about 5 seconds, any throttle input produced it. It gave me the impression that the engine would die. It didn't. Problem reoccurred 4 miles down the road, only bucked twice. Car was acting fine before and after each episode. I get into town 20 miles later (no issues that whole time) and everything is cool until I get half way through town. Then the same issues pop up. Bucking/hesitation under load, any throttle input.
I start thinking that it might be bad gas, so I fill up the rest of the tank with gas. Problem continues to occur, but only a couple more times. I stop at a light, and the car rough idles like a motor mount is bad. Then its fine. I find some open road and floor it....no issue. I let it idle when I get home for 10 mins....no issue. It idles fine.
I wake up this morning, reset the ECU, put in a paper air filter, add some injector cleaner and let it idle for 15 mins. No issue, good idle. I drive to the parts store and pick up some Heet. No issue. Put the Heet in and drive around for awhile. No issue. Get home and let it idle for 30 mins. No issue, good idle.
My thoughts.
  1. Bad gas
  2. MAF?
  3. Ignition
Anybody?
cthomasset is offline   Reply With Quote
Old 12-14-2008, 01:42 PM   #2
jordan s
Member#: 122233
1996 Outback Wagon
Navy Blue 5MT
did you check your oil? air filter?
jordan s is offline   Reply With Quote
Old 12-14-2008, 02:30 PM   #3
cthomasset
Member#: 189435
2008 2.5i
Oil level is good. Air filter is clean.
Old 12-14-2008, 02:34 PM   #4
Battlesnake99
Member#: 163066
08 2.5i sedan
shouldnt you mention the hybrid intake?
Battlesnake99 is offline   Reply With Quote
Old 12-14-2008, 02:40 PM   #5
cthomasset
Member#: 189435
2008 2.5i
Not currently running it (the lady didn't appreciate the noise).
Old 12-14-2008, 07:53 PM   #6
bnaccs
Member#: 197473
Maybe it is a bad tank of gas.
bnaccs is offline   Reply With Quote
Old 12-14-2008, 08:40 PM   #7
GrundleJuice
Member#: 165749
did you clean your MAF after you replaced the K/N filter w/ paper?
Old 12-14-2008, 09:13 PM   #8
cthomasset
Member#: 189435
2008 2.5i
I didn't clean the MAF. I have some MAF cleaner, so I may end up doing that if the problem crops up again.
video of my catback on my 08 2.5i tylere Normally Aspirated Powertrain 8 09-23-2008 10:53 PM
video of my catback on my 08 2.5i tylere Normally Aspirated Powertrain 0 09-22-2008 11:08 PM
Problems with 08 2.5i. ticking and hesitation.. Redneck Ricer Normally Aspirated Powertrain 5 09-19-2008 12:31 PM
New exhaust for my 08 2.5i? Vitus Newbies & FAQs 15 04-23-2008 03:25 AM
Help make my 08 2.5i into a sleeper jeeppsu85@ Tri-State Area Forum 23 04-18-2008 12:21 AM
