Old 12-14-2008, 03:22 PM   #1
piperpilot26
Member#: 197453
Default 93 subaru legacy clutch/transmission problem.
I have a 93 subaru legacy L with 201,500 miles. I cold started my subaru last night after sitting for 9 hours and while running in neutral the car suddenly stalled very hard as if I had put it in first and let off the clutch at 1,500rpm, which was what it was running at. when I restarted the car, it would then only run with my foot on the clutch. It will go in gear but when I try to pull away it doesnt do anything but stall, as if I tried to pull away with the brake on. and it will move slowly in nuetral. I replaced the clutch 2 years ago, but I dont think the shop that did it ever resurfaced the flywheel, because I've had clutch chatter for the last two years. it's not a hydrolic assist clutch. and I've made few adjustments to the clutch since it has always grabbed about half way up the pedal. any ideas or suggestions?
P.S. sorry if I posted in the wrong forum, I know this group if primarily impreza's and wrx's. I just need some friendly advice.
piperpilot26 is offline   Reply With Quote
Old 12-15-2008, 01:36 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Sounds like your transmission took a dump. Short of taking it apart, I'm not sure there's anything you can do. I'd suggest checking out www.bbs.legacycentral.org as they are a forum primarily for the 90-94 US Legacies.
Legacy777 is offline   Reply With Quote
Old 12-15-2008, 08:14 PM   #3
piperpilot26
Member#: 197453
Thanks! I'll check out those forums. Thanks again.
Possible clutch/transmission problem fulie Transmission (AT/MT) & Driveline 9 02-17-2009 11:20 PM
Clutch / Transmission..Problem..? Norrberrt Transmission (AT/MT) & Driveline 4 03-30-2006 09:19 PM
Clutch/Transmission problem maybe? Brupp Transmission (AT/MT) & Driveline 2 07-08-2004 12:51 AM
93 Subaru Legacy Turbo AWD Tranny Probs MugenNeuspeed Transmission (AT/MT) & Driveline 3 11-07-2002 02:51 PM
93 Subaru Legacy Turbo AWD MugenNeuspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-01-2002 09:38 AM
