Old 12-14-2008, 05:24 PM   #1
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
Default bad bearing or something else??
so I took my car in to get an alignment the other day and they told me i had a bad bearing and needed to replace it before they can do the alignment. The technician showed me that there is some play (a very slight amount) in the left rear wheel. It looks like the lug nuts are a little bit loose, but theyre not so the play is coming from elsewhere. Does this sound like a bad wheel bearing? The only reason I question the diagnosis is because there is absolutely no noise coming from the area, and with past bad wheel bearings ive always heard it. Any input would be greatly appreciated.
thanks,
Nate
rolzrex is offline   Reply With Quote
Old 12-14-2008, 07:07 PM   #2
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
anyone?
Old 12-15-2008, 09:41 AM   #3
SpankySuby
Member#: 122305
2002 wrx half breed
Yeah that sounds like a bad wheel bearing i dont know the exact tollerances for play but its not very much... with that being said that wheel really shouldnt move at all.
Did you check 12-6 position and 9-3 position?
what you could also do since he said only that one is bad is check the others to see how they feel and then recheck that one.
SpankySuby is offline   Reply With Quote
Old 12-15-2008, 03:43 PM   #4
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
12-6 and 9-3 position??
Old 12-16-2008, 02:15 PM   #5
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
does this sound like a bad bearing issue to anyone else? as I said, the only experience ive had with bad bearings in previous cars is increasingly loud noise coming from the wheel, not "play" in the wheel so im not sure...
Old 12-16-2008, 05:39 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
grab the tire at 12 and 6 o'clock and wiggle it. then at 9 and 3 and wiggle to see if there's any play.
Old 12-16-2008, 06:35 PM   #7
mikeythejew
Member#: 141672
thanks,
Nate
It looks like the lug nuts are a little bit loose = WTF!
So if your wheel doesn't fall off VIA a bad bearing which is possible, it might fall off due to loose lug nuts.
mikeythejew is offline   Reply With Quote
Old 12-16-2008, 08:12 PM   #8
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
you didnt read the whole post. I said it LOOKS like the lug nuts are loose, but theyre NOT. I was referring to the amount of play the wheel has due to a possible bearing problem. The lugs are all tight
Old 12-17-2008, 10:20 AM   #9
Kavik
Member#: 112278
2003 Sonic wrx wagon
2005 blue "wrx" Wagon
i gotta agree with you, sounds odd. I've had a few bearings go bad, and they all were easily recognized by the noise before i ever got the car off the ground to check for play.
did the guy doing the alignment take the wheel off at all before telling you that? I'd like to believe that they would know what they're talking about, but we all know that's not always the case
Kavik is offline   Reply With Quote
CEL P0171 - bad MAF or O2 sensor....or something else? Heider Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-22-2009 05:28 PM
Wheel bearing or something else? xcdhridr Brakes, Steering & Suspension 9 04-29-2009 12:59 PM
rough going into 2nd...bad synco or something else? balajc Transmission (AT/MT) & Driveline 0 08-19-2003 09:40 AM
Help! Wheel bearing or CV joint or something else? Strider Brakes, Steering & Suspension 0 03-26-2003 08:26 AM
