Old 12-14-2008, 06:38 PM   #1
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
Default E-brake light staying on while driving?
OK so when i put the ebrake down the light in the cluster stays on. This started happening when it started to get cold however it has never happened to me in the previous winters. Sometimes the light will come off right after i put the ebrake down however it lights back up once i start to drive sometimes. Just wondering if this happens to anyone else.
jcbluescooby is offline   Reply With Quote
Old 12-14-2008, 06:57 PM   #2
crf-sti
Member#: 189457
2005 WRX STI
CGM
it could be that there is too much slack in the e-brake cable, we had a '04 Sti in the shop the other day with the same problem, we just adjusted the e-brake cable from the center console and it made the light go off.
crf-sti is offline   Reply With Quote
Old 12-14-2008, 06:59 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Moved this to the Maintenance forum as it's a service issue. The brake light is also connected to the level sensor in the brake fluid reservoir, so when it comes on with the e-brake down it means the fluid level is low. When it's intermittent and goes on and off the level is marginal.
You should check your brake pads before adding any fluid, because the usual reason for the level dropping is worn pads. This of course assumes there are no leaks in the system.
Replace any worn pads first, then top off the fluid if necessary after driving on the new pads for a while. If fluid is added first, before changing the pads, it may overflow later.
Old 12-14-2008, 11:53 PM   #4
fastwrx25
Member#: 126441
03 bugeye
add some brake fluid. this happened to me cpl weeks ago
fastwrx25 is offline   Reply With Quote
Old 12-15-2008, 12:46 AM   #5
MightyWRX02
Member#: 16518
1584 Pirate Ship
Type ARRRRRRR!
i needed new rear brakes anyway so when I got them done the light went off. It was on for a month or two until i got them taken care of
MightyWRX02 is offline   Reply With Quote
Old 12-15-2008, 09:46 PM   #6
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
brake fluid
shift0246 is offline   Reply With Quote
Old 12-19-2008, 10:57 AM   #7
jcbluescooby
Member#: 113012
'04 XT red LIFTED
must be the break pads..dont think ive changed them since 30k maintenance..will do that and get rotors resurfaced sometime this weekend or next
Old 12-19-2008, 01:47 PM   #8
gathermewool
Member#: 143624
14 FXT Touring
VRP
Originally Posted by shift0246 View Post
brake fluid
Please read the posts before jumping in and answering an already answered question Mulder was spot on with his response, and no others were necessary until after a response from the OP...
gathermewool is offline   Reply With Quote
installed new mc, bled brakes brake light stays on???? vien Brakes, Steering & Suspension 6 04-27-2010 02:18 AM
e-brake light comes on while driving NJ2.5RS Brakes, Steering & Suspension 2 11-26-2008 08:27 AM
Parking Brake light staying on??? NYWRXTASY Brakes, Steering & Suspension 8 04-09-2003 08:57 PM
Brake Light Comes on While Driving BLCK DVL Service & Maintenance 3 10-02-2002 01:58 PM
E-Brake light stays on? sumo Brakes, Steering & Suspension 5 05-05-2002 09:51 PM
