Old 12-15-2008, 10:02 AM   #1
bnaccs
Member#: 197473
Default Tire pressure warning light
My 08 Outback Sport's low tire pressure warning came on for the first time today. The outside temp is -8. I assume this is the reason and that I don't have to add any air. I touched the tires and they all look and feel fine. Any thoughts are appreciated.
bnaccs is offline   Reply With Quote
Old 12-15-2008, 11:21 AM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
If your low pressure light is on, your tires are probably low.
If your pressure is low, you need to add air. That's the point of the light.
sniper1rfa is offline   Reply With Quote
Old 12-15-2008, 11:25 AM   #3
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
second!! ^^^^ what he said
salisburyv is offline   Reply With Quote
Old 12-15-2008, 12:09 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
well.....this is the first one of these I've seen
#1 and counting
Old 12-15-2008, 01:19 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....no offense but "touching" and "looking" is not an accurate way to tell whether your tires are inflated properly. Use a tire pressure gauge. Looks can be deceiving.
Kean is offline   Reply With Quote
Old 12-15-2008, 03:32 PM   #6
bnaccs
Member#: 197473
I was worried if I try to fill the tires at -8 degrees that they will be overinflated when the temperature rises. I didn't know that the warning was a result of the cold weather, and I should wait until it is not so cold out to add air.
Old 12-15-2008, 04:28 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
....then I would adjust as needed. According to some sources, for every 10F degree change, you may expect roughly a 1 PSI change in pressure (lower temps = lower press and vice versa). If you adjust your pressure to meet the recommendations listed on the placard on the door jamb, I would think you should be fine. If the temperature swings wildly, I would simply check to make sure your pressure is still within reasonable levels.
The tires will have a maximum cold pressure stamped on the tire that you should not exceed. The recommended pressures are likely a few PSI below this so you have some wiggle room. ....on top of that, the max press is for "cold", so there is some leeway there as well. Also, if you are adjusting pressure in a garage that is warmer than the temperature outside, you need to take this into account and adjust as needed. .....the 10 degree/1 PSI general rule should help. I guess my point is that as long as you don't go overboard filling up the tires (and keep monitoring them as needed), I really don't think you should worry about overinflation issues.
Old 12-15-2008, 07:50 PM   #8
bnaccs
Member#: 197473
I went to Discount Tire and they added 2 pounds of air to each tire. Thy said it was just the cold. The light did not go off. Do I have to do something to reset it, or will it go off on it's own? I drove about 2 miles after they added the air and the light stayed on. Thanks again!
Old 12-15-2008, 07:59 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
....how much air was there or is in there now? IIRC the TPMS requires a minimum of 29 PSI otherwise the light will illuminate.
Old 12-15-2008, 08:04 PM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
fyi.... Have a look at the following article from Subaru Drive magazine:
http://www.drive.subaru.com/Spr05_WhatsInside.htm
Take special note of the table at the bottom of the page explaining adjustments you may need to make when consdiering temperature changes.
Old 12-15-2008, 08:13 PM   #11
bnaccs
Member#: 197473
Kean,
Thanks so much for the great article. There is 35 now in each tire.
Old 12-15-2008, 08:16 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
Kean,
....no prob. I don't know why the light won't go off though. I would think it would reset itself after a few miles (with press above 29). ....maybe a failure in one of the transmitters (if that even would cause the light to trip)?
Old 12-15-2008, 10:24 PM   #13
salisburyv
Member#: 41863
2015 STI
drive faster than 40 miles an hour, if pressures are above 30 it will go out. If it doesnt, you have a bad sensor. Less than 36 k and its under warranty!!!
Old 12-16-2008, 05:30 AM   #14
Ghostrider319
Member#: 25130
2008 2.5i
'53 Chevy 210
if i remember correctly, if a sensor is bad or there is system fault, the TPMS light will flash. I've had the light come on and after tire servicing, it took about 10 minutes of driving for the light to extinguish.
Ghostrider319 is offline   Reply With Quote
Old 12-18-2008, 03:36 PM   #15
joker75
Member#: 168516
2008 Imprexa 2.5i
Spark silver
FWIW my light came on the other day when we got a nice cold spell. I figured that it was just the pressure loss due to the colder temps. I checked the tires and the pressure ranged from 29 to 31 which didn't seem too bad seing as the placard calls for 32. I raised them all to 34. The next time I drove it the light was still on. However after driving for a few miles the light turned off and has not been on since.
joker75 is offline   Reply With Quote
Old 12-18-2008, 03:40 PM   #16
640k
Member#: 160315
2008 STI
the tpms requires rotation in order to become activated. if they do not detect rotation, they will not reset the sensor. i'm not sure on the timing of the amount of rotation vs. when a signal is sent back to the receiver, but iirc, the wheels have to be moving at least 10mph in order to activate them.
640k is offline   Reply With Quote
Old 12-18-2008, 04:47 PM   #17
Kean
Member#: 25187
'08 Foz Prem TGM
....the sensors require that you be moving between 7-20 mph and will take readings every 30 seconds (transmitting every 60). ....it's all in the link I provided.
Old 02-16-2009, 12:54 AM   #18
jndimaria
Member#: 203076
05 STi CGM
re-bringing up the issue i guess...
i'm having a problem with the tpms - i bought a car, drove off the lot and 5 minutes later the light came on. turns out one tire had two nails and a razor blade in it! went and got a new tire, made sure the others were ok and the light is still on. maybe the sensor was damaged when the tech was putting on the new tire? i bought the extended warranty so hopefully it's covered.
jndimaria is offline   Reply With Quote
Old 02-16-2009, 06:45 PM   #19
Kean
Member#: 25187
'08 Foz Prem TGM
...if you bought it new and/or you're still within the 3/36 warranty, of course it should be covered. I would take it right back. .....assuming the tires are all properly inflated.
tire pressure warning light is on DCsubieSTI Newbies & FAQs 6 12-29-2009 11:58 PM
oil pressure warning light on when engine cold usenet4life Normally Aspirated Powertrain 10 01-14-2008 09:00 AM
oil pressure warning light Sublime5260 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-12-2004 05:07 AM
Help please Oil Pressure warning light blueimpreza25rs Tri-State Area Forum 4 10-27-2003 01:10 PM
Oil Pressure warning light WRX_junkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-25-2002 05:44 PM
