Old 12-15-2008, 11:16 AM   #1
lostdrift
Member#: 192325
1998 98 2.5GT Legacy
Snow White
Default BD5 lacking power.
I drive my Legacy about everyday but all of sudden the car feels very very very under powered. I was thinking maybe it's the trans, spark plugs, spark plug wires, or just the motor going bad. Has any ever gone thru this or knows what's happening? All help welcome and Thank you in advance.
lostdrift is offline   Reply With Quote
Old 12-15-2008, 02:56 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
engines typically don't just "go bad" all of a sudden, unless it's electrical. when was the last time any service was done? did you get a bad tank of gas?
Old 12-15-2008, 07:33 PM   #3
lostdrift
Member#: 192325
Snow White
I got the standard gas for the car. It now feels like maybe the trans is going. Not sure what I might need. When I really step on the gas most of the time the car will just rev but it won't pick up speed.
Old 12-15-2008, 08:16 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
i have had 2 vehicles do similar things, especially the revving but not downshifting when given full gas (auto trans). They were both very restricted Cats. How many miles on the cat? neither were subaru's, however. one was a pontiac the other a ford ranger.
GrundleJuice is online now   Reply With Quote
Old 12-15-2008, 09:27 PM   #5
lostdrift
Member#: 192325
Snow White
197XXX and counting. I hope my car not dying already cause I don't have the cash yet for the WRX swap.
Old 12-15-2008, 09:41 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
well IF it turns out to be the cat, thats hardly "your car dying". and for 197,000 miles, id say you were fortunate to have it last that long. A new cat isnt that expensive, even if you go OEM. Or going catless is an option. Here in FL (hello neighbor), they dont give a **** about the environment.
Old 12-15-2008, 09:57 PM   #7
lostdrift
Member#: 192325
Snow White
Where are you located in FL. Maybe you can drive my car and get a feel for what I'm talking about. I'll go under my car in the mourning and remove the cat and drive around to see if it fixes the problem.
Old 12-16-2008, 07:30 AM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
im in orlando, so i dont think that will work. Keep in mind, removing the cat may cause no O2 sensor data to the ECU (depends on your O2 sensor locations), which in itself, can cause other problems.
Old 12-16-2008, 08:47 AM   #9
lostdrift
Member#: 192325
Snow White
Don't think maybe it can be the auto trans fuse? Or maybe another fuse?
Old 12-16-2008, 10:45 AM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
If the engine revs freely, it may be the trans (do you have a 5MT or a 4EAT?).
If the engine won't rev freely, it could be:
Bad gas
Bad plugs
Clogged CAT
Etc.......
Old 12-16-2008, 11:27 AM   #11
lostdrift
Member#: 192325
Snow White
I have 4EAT. The car won't rev freely. When I watch the RPM it will jump then stop, the jump then drop, then jump up high. I had a guy tell me it maybe the #3 plug wire or plug itself not firing. And now when I idle it has a thumping sound and I can feel it in the car.
Old 12-16-2008, 08:13 PM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
If it's a bad plug or ignition wire, you should get a misfire CEL.
How many miles on the fuel filter?
The thumping sound, is it a solid sound or more like a metallic sound?
Any recent work done on the car, if so, what work?
Lacking Power 05 Impreza Sport AB-737 Normally Aspirated Powertrain 43 06-04-2010 07:13 PM
Lacking power! subiefreak52 Service & Maintenance 1 02-19-2010 05:21 PM
lacking power maybe boost leak? taeyax82 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-08-2005 10:49 PM
lack of power at 4000rpm racer12b Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-29-2002 01:13 AM
WRX lacks high speed power? WRX_man20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 05-15-2002 01:18 AM
